Carpet for BOSS riser - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 2 Post By jevchance
  • 2 Post By Augerhandle
  • 1 Post By smcmillan2
  • 2 Post By dtdfusion
post #1 of 14 Old 10-09-2019, 05:35 AM - Thread Starter
dtdfusion's Avatar
Quoted: 41 Post(s)
hi,
I made a BOSS riser with the drivers flush mounted. I plan to carpet it today and was wondering if I need to cut holes in the carpet for the drivers. I asked in the BOSS thread also but no answer yet. thanks for answering.
dtdfusion is online now
post #2 of 14 Old 10-09-2019, 06:28 AM
Quoted: 203 Post(s)
Liked: 204
I would think if you didn't have holes, the speaker would rattle against the bottom of the carpet. Even worse, the surrounds would rub against the bottom of the carpet, which is quite abrasive, and it would quickly destroy the surrounds on the speaker. I would definitely cut them out.
dtdfusion and Aural_Sex like this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #3 of 14 Old 10-09-2019, 01:51 PM
Chris Popovich's Avatar
Quoted: 219 Post(s)
Liked: 180
I mean, I want to say yes, but really the boss method is more shaking than anything else. You already have the carpet, plop it down on top, put the couch on 'er and give it a whirl.
Chris
Chris Popovich is offline
post #4 of 14 Old 10-09-2019, 03:23 PM
Augerhandle's Avatar
Quoted: 1288 Post(s)
Liked: 1277
One only need carpet the edges, and a bit of the top that might be exposed to view.
johnson636 and smcmillan2 like this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #5 of 14 Old 10-09-2019, 06:07 PM
smcmillan2's Avatar
Quoted: 954 Post(s)
Liked: 815
But not over the drivers. Unless you're (depending on orientation) trying to keep the motors warm, or tear up the surrounds.
Augerhandle likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #6 of 14 Old 10-11-2019, 07:36 AM - Thread Starter
dtdfusion's Avatar
Quoted: 41 Post(s)
i ended up carpeting whole thing and cut out the drivers portions. wish i had made an overhang for some lighting.
ID:	2626490   Click image for larger version
shivaji and Rowan611 like this.
post #7 of 14 Old 10-11-2019, 08:37 AM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 712
Looks good!!
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #8 of 14 Old 10-11-2019, 10:37 AM
Quoted: 203 Post(s)
Liked: 204
Nice work. How well do they work for you?
DIY 110" AT Screen
post #9 of 14 Old 10-11-2019, 11:21 AM
Quoted: 219 Post(s)
Liked: 180
Did you end up trying it before you cut out the holes for the drivers?
post #10 of 14 Old 10-17-2019, 08:44 AM
buggers's Avatar
Quoted: 43 Post(s)
Liked: 29
Slamming a rubber surround against the sharp, hard, carpet backing is probably not a good idea unless you want to replace drivers...often.
buggers is online now
post #11 of 14 Old 10-19-2019, 11:02 AM
Quoted: 146 Post(s)
Hey sorry for the stupid question... what is BOSS? Lol. I've been trying to find what this means but can't break down the acronym.
Snoochers is offline
post #12 of 14 Old 10-19-2019, 11:18 AM
smcmillan2's Avatar
Quoted: 954 Post(s)
Liked: 815
https://www.avsforum.com/forum/155-d...a-drivers.html
post #13 of 14 Old 10-19-2019, 12:20 PM
Quoted: 146 Post(s)
Originally Posted by smcmillan2 View Post
Thanks for the link. So it is just a name a guy made up for a particular layout of subwoofers? Subwoofers under the seating?
post #14 of 14 Old 10-19-2019, 12:38 PM
smcmillan2's Avatar
Quoted: 954 Post(s)
Liked: 815
Basically, yes. BOSS (Baffle Open Sub Shaker) is a name just like the Marty sub, V.B.S.S., Cyclops, Johnny sub, etc. are all made up names for ported subwoofer designs.
