Who's built the HTM-1010 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By johnson636
  • 1 Post By bac2040
post #1 of 11 Old 10-09-2019, 08:17 AM - Thread Starter
JohnDean's Avatar
Quoted: 546 Post(s)
Liked: 255
Where are the pics? I saw 1 review on DIYSG but haven't seen a pic in the wild of a single one.
Surely someone has built these.
JohnDean is offline
post #2 of 11 Old 10-09-2019, 09:45 AM
johnson636's Avatar
Quoted: 1235 Post(s)
Liked: 716
Well there you go. Build them and post pics...you'd be the first
ian#77 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 11 Old 10-09-2019, 02:56 PM
Erich H's Avatar
Quoted: 1880 Post(s)
Liked: 2694
One person built one for a center channel.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #4 of 11 Old 10-09-2019, 05:36 PM
smcmillan2's Avatar
Quoted: 902 Post(s)
Liked: 793
That's unfortunate. And with all the demand for horizontal centers (among the guilty) to go with the DIYSG designs surprising to me as well.
I hope you're able to re-purpose the investment into other existing/new designs if they don't sell as the 1010.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 11 Old 10-09-2019, 08:09 PM
Craig S King's Avatar
Quoted: 408 Post(s)
Liked: 522
Looks like the HTM 1010 is pretty similar to the Cinema 10.... finally, a horizontal Cinema 10??!?!
Craig S King is offline
post #6 of 11 Old 10-10-2019, 06:59 AM
Quoted: 170 Post(s)
Liked: 171
The one review was in September. I don't think these have been on the site very long.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS on the Way
DIY 110" AT Screen
jevchance is offline
post #7 of 11 Old 10-10-2019, 04:42 PM
bear123's Avatar
Quoted: 2653 Post(s)
Liked: 4147
I could be wrong, but I think a center channel with 10" woofers, making it 12+" high is too big for most folks' living rooms. Not an issue for dedicated theaters, but many of them can use vertical centers.
Don't get me wrong...time and effort was put into the design and I hope it sells well. I just feel like a lot of folks who require a horizontal center are limited on height.
I'd like to see a quad 6.5" design 2.5 way, which would keep the height under 8". Capability should be better than an MTM 8" woofer design, and just a little under a dual 10" center. Sensitivity should be crazy good with four 93 dB or so woofers(99 dB). Cost should be reasonable when you compare to something like the Klipsch RC-64 III which sells for $1500 and is only 93 dB. If I thought I had the time and ability to invest in such a project, I'd do it myself. But I fear I'm lacking on both departments.
bear123 is online now
post #8 of 11 Old 10-10-2019, 05:01 PM
asarose247's Avatar
Quoted: 1244 Post(s)
Liked: 1090
coupla things . . .
" making it 12+" high is too big "
BLASPHEMY , Yeah! . . .
No . . .
though it could be a personal call. . .
and a pair also at only 6+' from the MLP,
very convincing as surrounds- with some a aiming and such
Breaking Bad , the BD disks and the upmixed sound-
totally
reviving ( only) the F4Q4 make take some sleuthing about- designer is Curt Cambell
no doubt he has all specs, etc.
which leaves pretty much just basic carpentry/ router work for the baffle
I'd love to get another for the mancave CC,
tho the F6 has no complaints
we need a Sherlock . . .
Name:	88  new grill.jpg
ID:	2626378   Click image for larger version
Name:	88 on 3411.jpg
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #9 of 11 Old 10-12-2019, 09:39 AM
Liked: 4
Erich said they were having difficulties finding an 8 inch driver that would work for the HTM center channel speaker so that is why the 10 inch driver and the box ended up being 12 inches high.
For a build and review of a lower profile DIY center (9 inches high and you might be able to shave that down a bit) and quad 7 inch woofers with a tweeter and mid-range drivers:
https://www.highfidelityreview.com/d...-champion.html
Unfortunately, kit doesn't come with cabinets.
asarose247 likes this.
bac2040 is offline
post #10 of 11 Old 10-12-2019, 02:18 PM
asarose247's Avatar
Liked: 1090
thanks for the link
that is some kit tho some graphs would have been nice
post #11 of 11 Old 10-12-2019, 03:31 PM
Liked: 4
Some graphs on page 4. I assume more details are available if you actually buy the kit
http://www.clearwavespeakers.com/upl...s/4_Series.pdf
bac2040 is offline
