Cmax 1299 build - AVS Forum | Home Theater Discussions And Reviews
 13Likes
  • 4 Post By Chris Maxey
  • 3 Post By Kevin4730
  • 1 Post By Chris Maxey
  • 3 Post By blister64
  • 1 Post By Rowan611
  • 1 Post By eng-399
post #1 of 25 Old 10-11-2019, 07:29 AM - Thread Starter
Quoted: 22 Post(s)
Cmax 1299 build
After much deliberation (and probably more to come, let's be real) I've decided on building 3 (LCR) of the 1299's. They'll be total overkill for my current setup, but oh well. My decision process started with the HTM12's, then the HT12's, then the 1099's and finally the 1299's ( @tuxedocivic ). The HTM's are tempting, but I like the idea of the three-way design and the horizontal center combo, which led to the 1099's. Pre-upgraditis then made me think if I went that way I should just do the 1299's for better midbass and the larger wave-guide, and so I won't have regrets down the road.
My next thought was that I'd just build the 1299's sealed for ease of assembly, but after reading a ton of the 1299 build threads on here ( @blister64 @Rowan611 @Jk7.2 ) , I've decided to do ported instead. There's a ported design by @baniels that looks great, double slot port tuned to 47 Hz. I'm a bit partial to the double slot port design.
https://www.avsforum.com/forum/155-d...s-trilogy.html
I was thinking of co-opting his dimensions, bracing and port placement (and possibly the removable back portion for the crossover). Unfortunately his build thread was never updated with results after the build was completed. I'd like to confirm the box design with WinISD, but I don't run Windows so I'll have to find a work around. Can anyone provide some insight on this design or just a good ported design in general? If I make the ports slightly longer, that should lower the tune correct? I figure I'd port the center as well, unless that isn't advised.
The only issue I can see with these 1299's is that they'll make my 55" TV look like a fisher-price toy. I'll be replacing two bookshelf SVS Ultra speakers for what it's worth.
Jk7.2, lawdogx, blister64 and 1 others like this.
Chris Maxey is offline
post #2 of 25 Old 10-11-2019, 08:36 AM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 712
I ended up building mine sealed....and, I only regret it when I want to listen to music without subs. I’m still debating weather or not to rebuild them. In my 1299 thread I list all the dimensions of my 1299 ported boxes. Feel free to use those. But, you need dsp to prevent over driving the drivers.
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #3 of 25 Old 10-11-2019, 09:15 AM
lawdogx's Avatar
Quoted: 175 Post(s)
Liked: 208
Great thread topic, I'll be following with interest. I've been trying to come up with a ported solution that uses the baffle that comes with the kit. Looking forward to seeing what you come up with!
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is online now
post #4 of 25 Old 10-11-2019, 02:50 PM
Erich H's Avatar
Quoted: 1889 Post(s)
Liked: 2706
You can use the standard baffle on a taller cabinet. Build the cabinet about 12" taller than the baffle, glue the baffle up towards the top and then put ports on the 12" section below the baffle. A little bit like the following picture, but I don't like how they made the baffle narrower than the cabinet.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #5 of 25 Old 10-11-2019, 03:05 PM - Thread Starter
Quoted: 22 Post(s)
Thanks Erich! Would doing two slot ports on the top and bottom be not ideal?
post #6 of 25 Old 10-11-2019, 03:06 PM - Thread Starter
Quoted: 22 Post(s)
I can confirm that Wine for Mac does not run WinISD. I did find this tutorial to help with manually calculating port length:
https://www.jlaudio.com/header/Suppo...e+Ports/287541
post #7 of 25 Old 10-11-2019, 03:26 PM
Quoted: 51 Post(s)
Liked: 45
Have you tried Unibox? If your mac runs Excel, you might be able to use this. Not quite as many tools as WinISD, but gives you your box response and some excursion and port velocity info.
http://audio.claub.net/software/kougaard/ubmodel.html
scottvalentin is offline
post #8 of 25 Old 10-11-2019, 03:33 PM
Quoted: 159 Post(s)
Liked: 91
Here is a picture of what Erich is describing. Built by @Jk7.2 , designed by @eng-399
Jk7.2, eng-399 and kagtha like this.
TV: Panasonic 60" VT60 Plasma Surround: Yamaha RXA3050 5.1.2 Definitive Technology BP7006 (front), DefTech studio 350's (rear), Def Tech Di6.5r (ceiling) Players: Raspberry Pi running OpenElec/Kodi, Roku, Sony Blu-ray Control: Control4, whole house automation
Kevin4730 is online now
post #9 of 25 Old 10-11-2019, 04:45 PM - Thread Starter
Quoted: 22 Post(s)
Thanks, I'll give that a look.
post #10 of 25 Old 10-11-2019, 04:49 PM - Thread Starter
Quoted: 22 Post(s)
Thanks, I've read that build thread and maybe I'll end up doing something similar, but I was hoping for 2 ports (for symmetry) tuned to ~45 Hz or so. I don't plan on running them full range, I just want them to have good extension up to 60-80 Hz.
post #11 of 25 Old 10-11-2019, 04:59 PM
smcmillan2's Avatar
Quoted: 959 Post(s)
Liked: 818
Put a runner in the middle. Or are you saying you want the port(s) in a different location?
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #12 of 25 Old 10-11-2019, 06:04 PM - Thread Starter
Quoted: 22 Post(s)
Yea I was thinking one on the top and one on the bottom. I'll make a mock-up soon and post it.
post #13 of 25 Old 10-11-2019, 07:30 PM - Thread Starter
Quoted: 22 Post(s)
Here is @baniels design. I plan on doing something similar, but perhaps with slightly different dimensions. I'll draw it up in solidworks but it'll most likely look fairly identical.
post #14 of 25 Old 10-12-2019, 01:48 PM - Thread Starter
Quoted: 22 Post(s)
Here is a first pass at a design. The box is 47" H x 14.75" W x 16" D. The ports are 2" x 13.25" in cross section and 9" in length, for a tune of roughly 45 Hz if my maths are correct.
Jk7.2 likes this.
post #15 of 25 Old 10-13-2019, 08:01 AM - Thread Starter
Quoted: 22 Post(s)
So I was able to find my Windows recovery disk for an old laptop I had put Linux on and I reloaded Windows onto the laptop. So now I have access to WinISD! Huzzah!
The port lengths matched my excel sheet, which is nice, but the additional calculations from WinISD were really helpful. Since I had to look up the parameters for the Delta 12B woofer used in the 1299, I noticed that it doesn't really seem to like low Hz at all (at least from the specs, that is how it appeared to me). Though they rate the speaker for 400W RMS, when used with a vented box at specific tunings, it looks like max power is around 60-100W to avoid over excursion (this is from WinISD AND their own box build spec sheet). According to WinISD, at around 100W you can still get SPL of about 120 dBs from 1 meter away, so it really shouldn't be an issue, it's just an interesting thing to note.
So after all this and playing around with box parameters, I found that the original tuning of 45 Hz seemed to hurt performance compared to a higher tuning of 55 Hz for instance, at least as far as some extension into the lower Hz was concerned. Below are comparisons between the two from WinISD with the only difference being the port tuning (and also obviously the port length). The bold green line is the box tuned to 55 Hz. For graphs that take signal into account, the signal is at 80 W and the SPL is measured at 1 meter. There is also a 2nd order HPF at 60 Hz for both. The HPF at this frequency is needed to keep excursion in check.
ID:	2627280   Click image for larger version
ID:	2627282   Click image for larger version
ID:	2627284   Click image for larger version
post #16 of 25 Old 10-14-2019, 01:45 PM - Thread Starter
Quoted: 22 Post(s)
So it's always good to follow up if things don't seem to make sense. From Erich, the 2.7 mm xmax for the Delta 12B is a bit conservative and these should be able to handle more than that. He recommended a tuning of 40-45 Hz for a 4.5 cuft box. From this info, it's back to the 45 Hz tuning!
post #17 of 25 Old 10-14-2019, 02:15 PM
Quoted: 262 Post(s)
Liked: 326
My box was designed for about 35 Hz tuning (thanks @eng-399 for the help!). They handle it very well. I've thrown some power to them (Emotiva XPA-7, 300 wpc 2 channel) running full range testing bass songs and they get to moving pretty well. I don't have exact measurements for movement but it is more that 2.7mm xmax. I have no fear running these full range as loud as I can stand even with the bass boosted a bit to fill in the low end. These are pretty solid drivers that will take a beating. Just my .02
Chris Maxey, Erich H and eng-399 like this.
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva XPA-7 Gen3 | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Three Stereo Integrity HS-24 mkIII's sealed | Sinbosen FP20000Q
YouTube Channel for builds and reviews Life Of Bliss YouTube
blister64 is offline
post #18 of 25 Old 10-14-2019, 02:28 PM - Thread Starter
Quoted: 22 Post(s)
Thanks! I was sticking too close to the published specs when trying to design a box. Shows my noob status, ha.
post #19 of 25 Old 10-14-2019, 03:25 PM
Quoted: 262 Post(s)
Liked: 326
Hey I don't blame you! I got a lot of help with mine as well, all a learning process
post #20 of 25 Old 10-15-2019, 10:22 PM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 712
In my sealed configuration I can’t even get my drivers to barely move. They’re hooked up to a Crown 1502. I’ll have to check my MiniDSP, but I think I have them protected with a high pass filter. On top of that they’re crossed over at 80hz for the sub out. I don’t think you need to be concerned about overdriving the drivers. Just make sure they’re protected below the tune and you should be fine.
Chris Maxey likes this.
Rowan611 is offline
post #21 of 25 Old 10-16-2019, 09:50 AM - Thread Starter
Quoted: 22 Post(s)
My most recent design thought was making the ports sealable with a panel. This way, with two ports open I'd have a tune of ~45 Hz and with only one port open I'd have a tune of ~32 Hz (or I could go sealed). I figured this would allow me some flexibility and the ability to play around with different port tunings for my own learning's sake.
post #22 of 25 Old 10-16-2019, 11:02 AM
Quoted: 262 Post(s)
Liked: 326
You could also try to do the route that SVS does and cut some foam plugs for the ports. I don't know how "sealed" it makes it, but I'm sure it'd be pretty close if they were decently think (5+ inches maybe?). No panels/screws on the front of the enclosure that way. Just another idea
post #23 of 25 Old 10-16-2019, 01:34 PM - Thread Starter
Quoted: 22 Post(s)
I keep going back and forth on that method or panels. It'd certainly be easier to make with the plugs, but I'm worried with a big slot port, a foam plug might look kind of odd. I'll have to think about it some more.
post #24 of 25 Old 10-17-2019, 04:29 AM
eng-399's Avatar
Quoted: 2440 Post(s)
Liked: 5065
I’ll check winisd with your design to see how everything looks. You can go a little higher with the drivers than 2.7 mm for xmax they have a little more left in them.
eng-399 is offline
post #25 of 25 Old 10-17-2019, 05:44 AM - Thread Starter
Quoted: 22 Post(s)
Thanks, that'd be great!
