Eminence Delta Pro-18C vs PA460 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-15-2019, 06:33 PM - Thread Starter
a77cj7's Avatar
Quoted: 195 Post(s)
Liked: 162
Has anyone tried the Delta Pro 18c?
I’m currently building some mini devastators, so my brand new MBM is loosing its woofer. It’s too nice of a box to waste, so I started playing in WInISD. By plugging one of the two ports, it gives me a 26hz tune. With a PA460 on 500w, port velocity is well under 20 m/s. Should make a killer music sub for my shop.
Now the problem. I have a dayton 500w plate amp. Specs are 273w at 8ohm and 540w at 4ohm.
After cruising PE for a bit, I discovered the Eminence Delta Pro-18C. Plugging it into WinISD shows a 3.5db advantage. However, the woofer is $80 more. Its also hitting 10mm excursion on 540w (xmax 6.7, xlim 19)
Does anyone have experience with the Eminence, or any reason not to use it?
Does anyone have a 500w @8ohm amp suggestion for around $80? (Hah, but thought I’d ask)
I plan to use an audiocontrol 2xs crossover I have from an old car install. I will have adjustable lowpass and highpass for the woofer, and highpass for the speakers.
Chris
a77cj7 is online now
