Help with my first box design. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-18-2019, 05:10 AM - Thread Starter
ratm's Avatar
Quoted: 238 Post(s)
Liked: 102
https://subbox.pro/en/design/?bt=1&b...&pa=150&pp=100
I have decided to go with Dual FiCar HT3 subs. Still toying on what to power these with. Per FiCar (super awesome customer service btw), they suggested 6 cft sealed boxes and this is what I came up with. The depth is only 22 ish inches which mirrors my JTR that I have currently.
My question is about bracing. How much? What shaped? Where do I place them?
ratm is offline
post #2 of 10 Old 10-18-2019, 06:10 AM
Quoted: 51 Post(s)
Liked: 45
Those are really nice looking subs!
I would reconsider the choice of sealed. Here's why:
WinISD models of that sub with 1000w input.
12 Cubic foot tuned to 18hz and 6 cu. ft. sealed. The sealed only has more output below 13hz, but at tuning, ported has 12 dB more output.
Room gain will close that gap some, and if size is a constraint, then you will be able to add more power for more output with the sealed sub.
Some more info such as what you are using for an amp and what your desired/max box sizes would be will help to nail down a good box design.
But for starters, you should download WinISD and try modelling a bit. Use this thread and BTH's method for entering parameters:
https://www.avsforum.com/forum/155-d...to-winisd.html
scottvalentin is online now
post #3 of 10 Old 10-18-2019, 06:41 AM - Thread Starter
ratm's Avatar
Quoted: 238 Post(s)
Liked: 102
Thank you for modeling that. A couple of things. I plan on building 4 of these. 2 right now for my front stage and 2 in the future nearfield(ish). I am not looking for crazy SPL. In fact, maybe once or twice a year will I be alone in my house to crank it to reference level. Plus I just want to go the sealed route.
That said, (and forgive my noobness), but I noticed that you entered the Fsc @ 34.49 hz. The specs on the HT3 say the FS is 21.2 hz for sealed. Are they the same thing? Also, how does that graph change by modeling 2 subs? And finally, isnt QTC .707? or does that change with the driver?
ratm is offline
post #4 of 10 Old 10-18-2019, 07:29 AM
smcmillan2's Avatar
Quoted: 963 Post(s)
Liked: 825
They are not. https://www.diymobileaudio.com/forum...54-post53.html
Changes in box size for a given driver affect Qtc.
As you are not after high SPL you'll likely be just fine with the HT3s in 6cuft (net) sealed boxes. And if there comes a time down the road that you do want high SPL you can make new boxes for them.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 10 Old 10-18-2019, 07:40 AM - Thread Starter
ratm's Avatar
Quoted: 238 Post(s)
Liked: 102
Or just add more sealed. Which is the plan for equal dispersion. Side note, referencing the above graph, how many db's would I add if it was modeled with duals? Or is it already modeled with duals and I'm just too dumb to notice that.
ratm is offline
post #6 of 10 Old 10-18-2019, 07:54 AM
smcmillan2's Avatar
Quoted: 963 Post(s)
Liked: 825
Sorry, should have said "higher SPL in the 15 - 50Hz range" (the difference in the ported vs. sealed graphs scottvalentin posted). That knee on the ported graph shows quite a bit more in that range, but of course the box is twice the size too.
Might be duals, Scott would have to answer that. Doubling the cones should give you ~3dB increase, but the curve remains the same.
post #7 of 10 Old 10-18-2019, 08:14 AM - Thread Starter
ratm's Avatar
Quoted: 238 Post(s)
Liked: 102
Sweet. Back to part of my original question. How do I figure out bracing in this box? It cant be random.
ratm is offline
post #8 of 10 Old 10-18-2019, 10:08 AM
smcmillan2's Avatar
Quoted: 963 Post(s)
Liked: 825
It can be, mostly in regards to style. Window, spine, stick, etc. Personally I try to make sure no panel section within 10" is without some type of bracing. Combination of window and spine braces.
Others duplicate what they see in commercial offerings, such as:
https://www.parts-express.com/denovo...seri--300-7079
https://shop.gsgad.com/collections/m...eight-shipping
post #9 of 10 Old 10-18-2019, 11:17 AM
Quoted: 453 Post(s)
Liked: 380
Every 6-8" try to have some type of cross bracing, for the areas that prevent cross bracing, use angle bracing and wall to wall material.
Trimlock is offline
post #10 of 10 Old 10-18-2019, 02:33 PM
Quoted: 51 Post(s)
Liked: 45
Sorry I was away from the computer since the AM.
I just modeled ONE driver. Keep in mind the SPL levels shown are at 1 meter (I think), so the level at the listening point will be lower.
The FS you were reading above is the FS of the sealed box system, same as the QTC being .67 as a system with that driver in that size box.
The advice on bracing is good - every 8-10" have some form of cross or window bracing, front to back, side to side, and some top to bottom, etc. Even just some 2X4's work well.
With 4 of these units in sealed boxes, you will have a LOT of headroom assuming they are sufficiently powered, so you could EQ them very flat in room to very low frequencies. So you may be perfectly happy with them sealed. As @smcmillan2 says, if you aren't happy, you could then build ported boxes to get the output you need.
Good luck!!
