Most economical way to 7hz - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #1 of 96 Old 10-18-2019, 08:50 AM - Thread Starter
fj6474's Avatar
Quoted: 31 Post(s)
My room is 21 x 23 x 8. Enclosure size is no issue however money is. I am trying to replicate the schumann resonance for some experiments. I was thinking about a 45 cubic foot sealed enclosure with 22 of those jbls when they go back on sale. Any suggestions would be appreciated.
fj6474 is offline
post #2 of 96 Old 10-18-2019, 09:00 AM
Quoted: 294 Post(s)
Liked: 203
How loud does it have to play?
anjunadeep is online now
post #3 of 96 Old 10-18-2019, 09:11 AM
johnson636's Avatar
Quoted: 1273 Post(s)
Liked: 753
You require 7Hz and money is an issue...good luck.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #4 of 96 Old 10-18-2019, 09:12 AM
Quoted: 200 Post(s)
Liked: 201
This is a trap. I will not help you with your doomsday machine.
stegen and STL D like this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS on the Way
DIY 110" AT Screen
jevchance is offline
post #5 of 96 Old 10-18-2019, 09:13 AM
Quoted: 1808 Post(s)
Liked: 1395
Why do you need specifically 7 hz?
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #6 of 96 Old 10-18-2019, 09:15 AM
Quoted: 200 Post(s)
Liked: 201
https://en.wikipedia.org/wiki/Schumann_resonances
Looks like 7.83 Hz, specifically.
DIY 110" AT Screen
post #7 of 96 Old 10-18-2019, 09:17 AM
Mr. Electric Wiz's Avatar
Quoted: 119 Post(s)
Liked: 67
Infinite baffle isn’t all that expensive. You just have to have the “right room” for it.
I was able to get down to single digits easily with 4x18”
Mr. Electric Wiz is offline
post #8 of 96 Old 10-18-2019, 09:18 AM
Quoted: 158 Post(s)
Liked: 466
Irene scene on repeat all day duh!!
GatoGoat is offline
post #9 of 96 Old 10-18-2019, 09:19 AM
Quoted: 200 Post(s)
Liked: 201
Is there anything I should know before Googling this? Am at work.
DIY 110" AT Screen
post #10 of 96 Old 10-18-2019, 09:19 AM
Quoted: 2886 Post(s)
Liked: 12281
Do a ported "IB" and tune it at 7Hz. Any space 200cf+ for this would work really well.
16 JBLs in this sort of alignment will outperform 64 JBLs in a regular IB at 7Hz.
LTD02 likes this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #11 of 96 Old 10-18-2019, 09:19 AM
Liked: 1395
Completely missed that.
I’m surprised that no one has maid the comment that most subs can play 7hz, just not that loudly :P
post #12 of 96 Old 10-18-2019, 09:21 AM
Quoted: 158 Post(s)
Liked: 466
Yeah , you need 7hz on your computer speakers lol...
stegen likes this.
GatoGoat is offline
post #13 of 96 Old 10-18-2019, 09:22 AM
Quoted: 200 Post(s)
Liked: 201
LOL is it the scene from Sherlock Holmes? Apparently my headphones have failed the test.
DIY 110" AT Screen
post #14 of 96 Old 10-18-2019, 09:25 AM
Quoted: 158 Post(s)
Liked: 466
Nah...Black Hawk Down , F-in Irene Scene....Make sure you spell Hawk correctly if you are at work
GatoGoat is offline
post #15 of 96 Old 10-18-2019, 09:25 AM
smcmillan2's Avatar
Quoted: 949 Post(s)
Liked: 814
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #16 of 96 Old 10-18-2019, 09:31 AM
corradizo's Avatar
Quoted: 1549 Post(s)
Liked: 1606
corradizo is online now
post #17 of 96 Old 10-18-2019, 09:46 AM
Red Five's Avatar
Quoted: 738 Post(s)
Liked: 525
Single digits are not cheap, if you have a lot of space to work with for woofers I would attack it with cone area. Think 20+ PA460s, that is about as cheap as you can get.
Stormbreaker | Wisconsin Home Theater Meet Thread | The Devastator Index | Dev Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #18 of 96 Old 10-18-2019, 09:55 AM
Quoted: 294 Post(s)
Liked: 203
See the second post of the thread.
Depends on the experiment. He could potentially do it in a very small space at a reasonable volume. With reasonably powerful drivers in a sealed box he could apply boost. I mean even a storage closet with concrete walls, stack sealed subwoofers in there and apply boost.
I spent quite a bit of time in research and sometimes just by scaling things down your economics get a lot better. Also making sure the room is quiet, turn off the A/C, do it very late at night, seal the door for the experiment... then you get some free headroom by lowering the noise floor.
notfastenough likes this.
post #19 of 96 Old 10-18-2019, 09:59 AM
Liked: 1395
Hidden in plain sight!
post #20 of 96 Old 10-18-2019, 10:49 AM
Zarkoff500's Avatar
Quoted: 222 Post(s)
Liked: 166
I'm using 12 of the JBL's for IB and can confirm they work just fine.
Zarkoff500 is offline
post #21 of 96 Old 10-19-2019, 03:42 PM
Bigus's Avatar
Quoted: 659 Post(s)
Liked: 597
SPL at a given frequency for sealed (or IB) alignment is a function of displacement. Therefore, for budget minded builds, displacement per dollar rules. Still hard to do better than Fi IB3-18 there. One, two, three, sixteen, however many you need to get to your desired output in a given room is about the cheapest way to do it... sealed. Unless you don't need as much output as a single IB3-18 can provide, then look at cheaper subs. Keep in mind though that for any sealed design, larger enclosure (up to it becomes an IB) means less power and thus less cost required for amplification.
Ported can get you there with less expense in drivers and a larger enclosure. Here it isn't just all about displacement per dollar (still important) as you need resonances to be compatible, and the amount of power required to get you there adds to cost as well.
I guess if space was truly unlimited an insanely large horn(s) tuned to 7Hz might be the least expensive way to get to a certain SPL, at least for driver and amplification. Wood isn't exactly peanuts and the cost becomes significant when looking at massive enclosures. May ultimately be cheaper to have a much smaller enclosure with more drivers, or use an IB design that has an effectively huge enclosure without much cost.
Bigus is online now
post #22 of 96 Old 10-19-2019, 05:04 PM
asarose247's Avatar
Quoted: 1257 Post(s)
Liked: 1103
"I guess if space was truly unlimited an insanely large horn(s) tuned to 7Hz"
A Submaximus horn can be fitted with a 24" . . .
The cab would be 120 ft^3,
this idea explored by @hd0823 with @LTD02 ,
the tuning was never expounded upon
but inquiring minds might like to know
stegen likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #23 of 96 Old 10-19-2019, 05:11 PM
hd0823's Avatar
Quoted: 858 Post(s)
Liked: 1616
I dont think we even got that far lok. I seen 120 cubic ft and chickened out lol
Sent from my SM-N950U using Tapatalk
asarose247 and jevchance like this.
hd0823 is offline
post #24 of 96 Old 10-19-2019, 08:21 PM
kwoody51's Avatar
Quoted: 57 Post(s)
Liked: 38
Same here!
Running an IB setup with 4-18” subs.
Room is 22 by 20 with 9’ ceilings and completely open on one side.
kwoody51 is offline
post #25 of 96 Old 10-19-2019, 08:33 PM
MKtheater's Avatar
Quoted: 2557 Post(s)
Liked: 2732
Best way is to build false walls and make the room smaller. Within those false walls can be your subs. Big enclosure, less amp power, smaller room, and bingo! You could port at 10hz even but I would keep it sealed depending on drivers.
LTD02 likes this.
Building the room, speakers, and subs.
MKtheater is online now
post #26 of 96 Old 10-19-2019, 09:24 PM
noah katz's Avatar
Quoted: 2105 Post(s)
Liked: 763
Originally Posted by Bigus View Post
...for budget minded builds, displacement per dollar rules. Still hard to do better than Fi IB3-18 there.
Better than x number of 12" $29 JBL's?
Noah
noah katz is online now
post #27 of 96 Old 10-19-2019, 09:38 PM
Liked: 12281
Nah, the JBLs win even at $40 per.
post #28 of 96 Old 10-19-2019, 09:47 PM
MKtheater's Avatar
Liked: 2732
Are they even available anymore?
post #29 of 96 Old 10-19-2019, 09:51 PM
Bigus's Avatar
Quoted: 659 Post(s)
Liked: 597
Seems like I did that math. At $29 maybe better but would run into practical mounting area constraints for ambitious builds. Tha pa460 is about even but takes 3 to 1 so again mounting issues may become important.
Bigus is online now
post #30 of 96 Old 10-19-2019, 10:04 PM
Bigus's Avatar
Quoted: 659 Post(s)
Liked: 597
And yeah, even at $40 still just edges out. Definitely a difference in accommodating 8 x 18" subs vs 50 x 12" subs. All depends on what one thinks is reasonable. A 4 x 18" IB build isn't that uncommon. 24 x 12" manifolds might be just within reason, 12 per manifold with a "sub that shook the world" 3 deep all 4 sides construction. Then again, a few around here have more than 8 x 18" IB's. Hmm... 16 x 18" is crazy. 100 x 12" is beyond crazy.
Bigus is online now
