DIYSG Atmos option/idea - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 3 Post By mindedc
  • 1 Post By mindedc
post #1 of 14 Old 10-22-2019, 09:29 AM - Thread Starter
HurricaneDitka's Avatar
Quoted: 32 Post(s)
Liked: 24
Has anyone ever tried a setup like this for Atmos?
Since DIYSG doesn't seem to make an Atmos speaker like this, does anyone know of another manufacturer?
HurricaneDitka is offline
post #2 of 14 Old 10-22-2019, 09:57 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 24
If no DIY company makes them, I'm considering these from Klipsch. Anyone have experience with these?
https://www.klipsch.com/products/rp-...rround-speaker
https://www.klipsch.com/products/r-4...-atmos-speaker
post #3 of 14 Old 10-22-2019, 10:44 AM
Erich H's Avatar
Quoted: 1917 Post(s)
Liked: 2764
Why can't you use the Cobalt for Atmos like the picture you posted?
_______________________
The SEOS Waveguide Project
Erich H is offline
post #4 of 14 Old 10-22-2019, 10:53 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 24
I worded that poorly. I am absolutely considering using the Cobalts for this purpose. First I was wondering if anyone had ever tried it and their review of it. Second, this would only work (size wise) if you have the 1099s or 1299s. My current mains have a rounded top so they can't be put on them. I eventually would like to get the 893s if they come back and they might not be wide enough.
post #5 of 14 Old 10-22-2019, 11:07 AM
Quoted: 31 Post(s)
I actually thought about this with the Volt-8. But I have a low ceiling and a soffit above my TV so I wrote it off as not working well. So I offer no value with my comment, but wanted to post that it definitely looks cool mocked up and I bet it works very well.
Bur05XP is offline
post #6 of 14 Old 10-22-2019, 11:12 AM
Zarkoff500's Avatar
Quoted: 238 Post(s)
Liked: 183
Is using the angled speaker as a height channel at the sides or front/back of the room an option?
Zarkoff500 is offline
post #7 of 14 Old 10-22-2019, 11:39 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 24
Anything is an option really. Here is my room. I really didn't want to do in-ceiling speakers. The room is 8 foot ceilings.
post #8 of 14 Old 10-22-2019, 12:18 PM
Zarkoff500's Avatar
Quoted: 238 Post(s)
Liked: 183
I was thinking angled on wall mounted high. There was a recent audioholics video on youtube where they talked about how angled on wall may be more immersive/realistic vs in ceiling. https://youtu.be/pOI0T15d4RY
post #9 of 14 Old 10-24-2019, 12:28 AM
mindedc's Avatar
I'm not trying to be debbie downer, but here are some issues I see with what you're looking at doing:
1. Upfiring Atmos speakers are supposed to have a HRTF (Head Related Transfer Function) included in the xover (license fee to Dolby). Generic speakers and certainly DIYSG speakers will lack this
2. Upfiring Atmos generally needs to be carefully constructed of drivers that are only reproducing audio in region where they are "beaming" and are not reproducing sounds below that region of their response. This constrains sounds so you don't hear the direct sound and instead hear only what is reflected. Note that this is the exact opposite of what a good speaker (According to Toole etc) where it should have an even response over the entire listening area so very unlikely that a random speaker will possess those attributes
3. Upfiring Atmos generally have some absorption to kill any direct radiated sound to the listener, you would have to add that to the DIYSG speakers.
on top of all of that, I have heard theaters that have both the "Atmos" module, atmos speakers positioned onwall above the normal L/R and surrounds, as well as my theater has ceiling mounted (volt 6 in atmos format). I can tell you that I always think the modules sound terrible, don't care how expensive or compliant to the design. I find the effect to be weak and not convincing. The wall mounted setup is better, however you will need a REALLY tall room and to drop your side/rear surrounds really low to get enough separation of bed VS height channels.
When designing my theater using CAD, I figured out that getting a ceiling speaker with the proper dispersion pattern to cover your seating can be tough, Coax was the only viable solution for my ceiling mount atmos. I am 100% DIYSG and I love their products, but Atmos modules are possibly a poor (mis)use of their product.
TL;DR: Do ceiling speakers, potentially Coax, potentially sold by DIYSG
dorri732, mhutchins and asarose247 like this.
mindedc is offline
post #10 of 14 Old 10-24-2019, 04:08 AM
Javs's Avatar
Quoted: 6937 Post(s)
Liked: 6651
Build these, they worked really well.
https://www.avsforum.com/forum/155-d...i-modules.html
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #11 of 14 Old 10-24-2019, 06:52 AM
mindedc's Avatar
I haven't heard those or the triads. Based on technical specs those are the only modules I've seen that have a prayer of working properly.
Nice design, nice build. Still won't have the HRTF but I've always been suspicious about the use of HRTF applied across multiple people anyway. Seems like it would need to be tuned to the particular individuals anatomy to work properly but this is a complex topic and I'm an armchair quarterback here.
I would say most of my above comments would not apply to these.
Javs likes this.
mindedc is offline
post #12 of 14 Old 10-24-2019, 10:18 AM
markg35's Avatar
Quoted: 354 Post(s)
Liked: 287
Earlier in the year,I found a great deal on the Klipsch 500SA's from Frys.I tried them out on top of my 893's.
They were an OK addition,but I didn't think they were worth keeping.Not sure about the bounce effect off the ceiling.
I had thought of trying what you're thinking of.Thought I'd try the Klipsch idea first.
When I'm ready for Atmos,I'll go with one of the more standard locations.
markg35 is online now
post #13 of 14 Old 10-24-2019, 10:43 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 24
Thank you for this. This is exactly the kind of info I was after.
post #14 of 14 Old 10-27-2019, 06:11 AM
lemonslush's Avatar
Quoted: 986 Post(s)
Liked: 476
I would say get a volt6 and build a 45 degree angled box then mount that to your ceiling. The bounce atmos stuff doesnt work as well as on ceiling.
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
