He's dead Jim, he turned the knob to 11 - A Dual Mini Devastator Build - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 197Likes
post #151 of 255 Old 11-18-2019, 11:40 AM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
Originally Posted by johnson636 View Post
You don't think 4 mini devastators (B&C 21DS115-4) along with 2 ported 24s would be enough I could do 3 front row near field.
Now that we’ve thrown this discussion all over the place...
You are probably better off using the LaVoce drivers with your amp. If you want to use the 21mini, You’re going to be port velocity limited by either driver, so might as well save some money.
Chris
a77cj7 is online now
post #152 of 255 Old 11-18-2019, 11:54 AM
johnson636's Avatar
Quoted: 1500 Post(s)
Liked: 987
Originally Posted by Red Five View Post
@johnson636 how soon do you plan on cutting things?
Probably early December.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #153 of 255 Old 11-18-2019, 11:56 AM
johnson636's Avatar
Liked: 987
How soon will a cut list be available?
post #154 of 255 Old 11-18-2019, 11:58 AM - Thread Starter
Red Five's Avatar
Quoted: 1136 Post(s)
Liked: 1010
Very soon.
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #155 of 255 Old 11-18-2019, 12:04 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
It is attached
Thank you sir.....for the RSS460HO it's only different above 150Hz in this XL box....
Juju
Red Five likes this.
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20Hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #156 of 255 Old 11-18-2019, 12:09 PM - Thread Starter
Red Five's Avatar
Liked: 1010
This is the cut list for it. I will have to do some more screen grabs for the more formal post when I get to it. Edit: Fixed.
johnson636 likes this.
This is the way...
post #157 of 255 Old 11-18-2019, 12:10 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
Juju
Interesting, first I’ve heard of a “HT” driver modeling well in a Dev. Most seem to be ridiculously peaky, though I guess the HO tends to act more like a PA driver.
Chris
jujuman200 likes this.
post #158 of 255 Old 11-18-2019, 12:11 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
This is the cut list for it. I will have to do some more screen grabs for the more formal post when I get to it. Edit: I see a typo.
You sir, are completely ridiculous. Keep up the good work!
Chris
jujuman200 and Red Five like this.
post #159 of 255 Old 11-18-2019, 12:12 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
RSS460HO in a MINI
I don't remember if I posted this before.....
Black is the 460HO.... Grey is the SAF184.03.... left side looks real nice.... no added eq on the 460HO BTW....
Juju
Name:	460HO MINI  PLOT.jpg
post #160 of 255 Old 11-18-2019, 12:13 PM
johnson636's Avatar
Liked: 987
I know you said soon, but DAMN!!!
post #161 of 255 Old 11-18-2019, 12:14 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
Chris
You are correct sir.... it get peaky around 90Hz or so..... but very use able....
I'm about to put 2 in MINIs.... will keep you all posted....
Juju
post #162 of 255 Old 11-18-2019, 12:16 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
Juju
Can’t wait to see measurements on that.
Chris
post #163 of 255 Old 11-18-2019, 12:20 PM - Thread Starter
Red Five's Avatar
Liked: 1010
Juju
I think the added mass of the HT driver is what is causing that spike. The Qts looks good on that sub, just a bit more weighty than a Pro sub. Port velocity might get very hot with the Fs around 19Hz.
This is the way...
post #164 of 255 Old 11-18-2019, 12:22 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
Shouldn’t be any crazier than the 18ds fed adequately. The way cheaper and easier to drive aspects are nice though.
Chris
post #165 of 255 Old 11-18-2019, 12:42 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
At that volume, I doubt you will hear a peep from this sub.... just bass...
Juju
post #166 of 255 Old 11-18-2019, 12:53 PM - Thread Starter
Red Five's Avatar
Liked: 1010
Juju
On that sim what is the voltage and excursion? The bummer is the 460HO might run out of power handling before excursion unlike the Pro subs.
This is the way...
post #167 of 255 Old 11-18-2019, 01:30 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
Here are the MAX spl charts for the SAF and 460HO....
They have about the same excursion at 13mm and 12.75mm respectively.... let me know what you think..
The SAF takes 3000 watts MAX Peak and the 460HO takes 1800 watts MAX peak..
Juju
ID:	2642756   Click image for larger version
post #168 of 255 Old 11-18-2019, 01:45 PM - Thread Starter
Red Five's Avatar
Liked: 1010
Juju
Dayton does not have the winding height and gap depth for the RSS460HO out there at least not that I found. 2/3 gap on the SAF should be around 19.4mm. The HO has to be somewhere in that area.
This is the way...
post #169 of 255 Old 11-18-2019, 01:47 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
Juju
Those are rated, though safer to stay toward RMS.
The question is how the drivers model with excursion at rated power.
Chris
post #170 of 255 Old 11-18-2019, 03:18 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
Chris
Didn't forget to answer.... just want to make sure I'm doing it correctly...
Juju
post #171 of 255 Old 11-18-2019, 05:59 PM - Thread Starter
Red Five's Avatar
Liked: 1010
I can't push them but I like them so far without calibration.
DigiWega, jujuman200, femi and 3 others like this.
This is the way...
post #172 of 255 Old 11-18-2019, 06:25 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
Bout friggan time. And I’d hope you like them, after the work you put into designing em.
Better get calibrating.
Chris
post #173 of 255 Old 11-18-2019, 06:32 PM - Thread Starter
Red Five's Avatar
Liked: 1010
For those concerned about the low end they have more meat than the 21DS115 Stormbreaker. I am pleased with that!
Edit: they have not been broken in get either.
This is the way...
post #174 of 255 Old 11-18-2019, 06:34 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
So much for not pushing them, lol. What was the tune on stormbreaker?
Chris
post #175 of 255 Old 11-18-2019, 07:02 PM - Thread Starter
Red Five's Avatar
Liked: 1010
Chris
18 or 19Hz a little lower than the Mini. I have a 17Hz 4th Order HPF so the sub can flap around more since 1000 watts to each is expected to each driver. It has good weight, ran 2049 in quiet mode, I know what to expect on that one.
This is the way...
post #176 of 255 Old 11-18-2019, 07:07 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
18 or 19Hz a little lower than the Mini. I have a 17Hz 4th Order HPF so the sub can flap around more since 1000 watts to each is expected to each driver. It has good weight, ran 2049 in quite mode, I know what to expect on that one.
Not sure how you can tell at quiet volumes. Sounds more like level is slightly higher to me.
Just by displacement, I would expect the pair of mini’s to have more low end though. (Math: Not even once!)
The mini’s might have a slight advantage up top as well
So when do ya get to go war mode?
Chris
post #177 of 255 Old 11-18-2019, 07:19 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
During WAR MODE...please give me your impressions of the helicopter scene in Lone Survivor.... I know what that does to my place with Full Martys....Thanks
Juju
post #178 of 255 Old 11-18-2019, 07:46 PM - Thread Starter
Red Five's Avatar
Liked: 1010
Two 18 ported is > 1 21 ported most likely lol. The bottom light on the Nuke was barely flickering, the 21 would need a bit more juice than that for the level I was at. Gain and trim I think are in the ballpark, but with two 2 year olds tearing it up only so much can happen down there....
The filters are on for the old sub on the AVR, so it is killing the mid bass in conjunction with the filters setup in the Nuke. I left the 21" alone when I set it up and the AVR trimmed the mid bass hotness. This round using the Nuke to trim the mid bass first. The AVR probably did other stuff, no one knows what it did on the FIR filters on top of the aforementioned stuff I did and I know the AVR did first time.
I do not have that movie in the collection. JW1, JW2, and 2049 are the ones I play with the most. I know what the 21" would do with them very well. War mode maybe this weekend, see if the two year old handles it We might watch the Toy Story 2 intro a few times...
jujuman200 and a77cj7 like this.
This is the way...
post #179 of 255 Old 11-18-2019, 08:24 PM
a77cj7's Avatar
Quoted: 781 Post(s)
Liked: 812
Just a warning, bass scenes seem to be getting hotter, lol.
I had my setup tuned using JW1 and oblivion. Had run JW2 also, good to go.
Then ran RP1. Yeah, sealed HT-18’s attempting to melt down, hitting clip lights on mini’s. That was unexpected.
I’m currently rewiring for 2500w to each mini, see if the extra 3db helps. Only issue with phoenix amps and minidsp, wiring isn’t quick plug and play.
I’ll have to pick up 2049, haven’t seen that one yet.
At least mini dev’s should be more child-proof than stormbreaker.
Chris
post #180 of 255 Old 11-18-2019, 08:47 PM
jujuman200's Avatar
Quoted: 339 Post(s)
Liked: 312
[Snip]....
This has awesome bass and is actually a good movie..... I think Netflix has it...
It's called "9" https://www.imdb.com/title/tt0472033/
Yes it's kid friendly....my kids loved it when they were small...
Enjoy
Juju
devastator , lavoce san184.03 , mini devastator
