AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   He's dead Jim, he turned the knob to 11 - A Dual Mini Devastator Build (https://www.avsforum.com/forum/155-diy-speakers-subs/3098414-hes-dead-jim-he-turned-knob-11-dual-mini-devastator-build.html)
Red Five 10-26-2019 09:33 AM
The build is on! Just picked up materials from Lowe's, now for the long building process. The SAF184.03 is out of stock everywhere I looked, so I had to go with the SAN184.03. Both handle in a similar manner in the Mini Devastator. The design for the Mini Devastator is found here - https://www.avsforum.com/forum/155-d...l#post58654500
https://uploads.tapatalk-cdn.com/201...8f4a7534e5.jpg
Red Five 10-26-2019 04:49 PM
I think the guy missed 48.5".... At least the tallest panel is 40", so I can work around this. https://uploads.tapatalk-cdn.com/201...b828071580.jpg
a77cj7 10-26-2019 05:07 PM
Wow, thats bad. I watched them measure on mine. Wasn’t perfect, but nothing like that.
At least you have an extra half sheet to work with.
Chris
Red Five 10-26-2019 05:17 PM
Chris
The nice thing with the Mini is not being 48" tall, if it were 48" tall I would have to custom adjust the design. I can still get 2x 24" wide pieces that are greater than 40" out of each half :) I still have some Stormbreaker scraps for bracing if it comes to it.
a77cj7 10-26-2019 05:22 PM
He's dead Jim, he turned the knob to 11 - A Mini Devastator Build
And here I was wishing it was 48” tall, would perfectly match my 96” horizontal screen. ;)
I wouldn’t worry about being short on material, I had plenty of scraps. And you have a half sheet of extra anyway.
Chris
Red Five 10-26-2019 05:37 PM
Chris
I was thinking about doing that, only adds 1.5 ish cubic feet to the rear chamber and pushes the front resonator response down. I would call it a full Devastator lol. It would be nice if a 21" could work in it.
a77cj7 10-26-2019 05:49 PM
Apparently I should have asked BEFORE I built mine, lol.
Then again, I just swapped them and will probably swap them back depending on measurements. I think they’re heavy enough.
Chris
Red Five 10-26-2019 05:56 PM
Chris
After wrangling Stormbreaker (40x30x24) up the steps something smaller all of a sudden sounded like a great idea lol. The wife is game for me getting the speakers behind the screen. Which would make room for two more Mini Devs someday :)
a77cj7 10-26-2019 06:01 PM
More cones! More powah! More Output!
Chris
Kothoga 10-27-2019 06:59 AM
And here I am also wanting something to replace the V3611s in front of my screen. Issue is, I can't go taller than ~23".
https://i.imgur.com/KvhdMvO.jpg?1
Red Five 10-27-2019 08:57 AM
How deep can you go? An 18" can easily fit in 23" wide.
Kothoga 10-27-2019 11:28 AM
I could go deeper, the V3611s are 25"D x 20"W x 44"H. Thing is, they are hard to beat in this form factor; quad 18"s, 3,800rms, 8,600max, tuned to 16Hz. As crazy as it sounds, I was thinking quad 24"s mounted firing up with ports facing forward. The box design could be like Life of Bliss' and hold the RC64 center.
Red Five 10-29-2019 06:22 PM
LTD02 10-29-2019 07:20 PM
"I think the guy missed 48.5"
a77cj7 10-30-2019 09:44 AM
Originally Posted by Red Five (Post 58750098)
A lot more progress than anticipated! Took a half hour at my buddies cabinet shop to cut the MDF.
Showoff ;)
Nothing like a professional shop to make it go smoothly.
At this rate I expect to hear your listening impressions tomorrow.
:D
Chris
Red Five 10-30-2019 09:47 AM
Originally Posted by a77cj7 (Post 58752792)
Showoff ;)
:D
Chris
We have odd stuff going on tonight, tomorrow night I am stopping by my other buddies shop. His response "So you saved us the hard stuff." this was after I sent him the pictures. Getting the baffle cutout perfect was the tricky part on the last build and he remembers that lol.
Red Five 10-30-2019 09:48 AM
1 Attachment(s)
Since Home Depot is a long drive for paint, I am looking at this. Thoughts?
https://www.avsforum.com/forum/attac...1&d=1572454108
a77cj7 10-30-2019 09:57 AM
If you don’t have a jasper jig, you really should get one.
https://www.amazon.com/Jasper-200J-C...jasper+&sr=8-3
Made my baffle cutout a 10 minute job. Find center of panel, measure down from top for driver offset. Drill 1/8 hole, and run the cut.
https://uploads.tapatalk-cdn.com/201...86d1a28ba8.jpg
It’s been a handy tool for years, but recently splurging on the dewalt 20v router and plunge base made it really fast and simple.
Chris
Red Five 10-30-2019 10:01 AM
Chris
I do not have a router, just a variable speed jigsaw with an orbital action. It is very precise, but it takes a bit to make the cut. The holes are smaller this round lol.
a77cj7 10-30-2019 10:02 AM
Ahh, well that makes it more difficult.
I couldn’t function without one, I like round-overs way too much.
Luckily not too small, I hate cutting tight radius’ with a jigsaw.
Chris
Red Five 10-30-2019 10:21 AM
I could see getting one if I did wood working projects more often. Right now I need a few toys to sell, subs ate my budget.
Red Five 10-30-2019 05:17 PM
A couple sheets together on the first box!
https://uploads.tapatalk-cdn.com/201...30001d9cdc.jpg
superkyle 10-30-2019 05:23 PM
Originally Posted by Red Five (Post 58755254)
A couple sheets together on the first box! https://uploads.tapatalk-cdn.com/201...30001d9cdc.jpg
Glad to see it going together! Also I agree with Chris when you get some savings back you must pick up a router and jig! Makes life so much easier.
Red Five 10-30-2019 05:31 PM
That money will be diverted for a 2x4HD MiniDSP :)
superkyle 10-30-2019 05:32 PM
Oh yeah those are a must for sure. Make sure to keep an eye on the marketplace. I’ve seen some good deals on them here and there.
Red Five 10-30-2019 07:52 PM
I have noticed that. I am mostly interested for BEQ reasons and getting around the ULF filters.
Red Five 10-31-2019 06:42 PM
hd0823 10-31-2019 06:48 PM
Looking great. Your moving right along
Sent from my SM-N950U using Tapatalk
johnson636 10-31-2019 06:53 PM
Originally Posted by Red Five (Post 58760212)
Progress update, some more cuts have been made! https://uploads.tapatalk-cdn.com/201...8cd95bb9e4.jpg
Serious skills with that jigsaw. Who needs a router when you can cut holes that cleanly:)
Red Five 10-31-2019 06:59 PM
That saw is so easy to handle, the variable speed on it is awesome!
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
