4 x Sealed Dayton Audio Ultimax UM18-22 18" (Build Thread) - AVS Forum | Home Theater Discussions And Reviews
 71Likes
post #1 of 66 Old 10-31-2019, 07:21 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
4 x Sealed Dayton Audio Ultimax UM18-22 18 (Build Thread)
Hey Guys,
Thought it would be fun to create a build thread for my new crazy build which will consist of 4 x Dayton Ultimax 18" in sealed enclosures. The dimensions of each enclosure is 560mm (height) x 560mm (wide) x 548mm (deep), technically a traditional cubic style sub which is just over 4cu feet (could be slightly larger), which is the recommended sealed enclosure size for this driver.
I have been extremely happy with my Mini Marty for the past (almost) 2 years, however as you guys know you can never have enough bass so I have been on the hunt for something new and also I needed something to build anyway so this was an excuse in a way too
Now as per my previous thread I was in two minds whether to go for 2 x larger ported 21" B&C subwoofer design or 4 x smaller sealed Dayton Ultimax 18" subwoofer design. In the end I decided to go ahead with 4 slightly smaller sealed subwoofers which I believe and hope will give me more controlled and consistent bass in my room. My room is 6.5m deep and approx. 4m wide. Initially I will be placing two upfront and two behind my seating area, however things may change and I may re adjust my screen wall to accommodate all four subs to be placed directly under my screen.
I will need to read up on REW and MSO in order to learn how to time align and integrate all four subwoofers into my system. I would really appreciate any tips and tricks along the way.
I will try to update this thread with pictures on a regular basis as and when I start and proceed with the build. Thank you in advance for all your support, help and advice
mkohman is online now
post #2 of 66 Old 10-31-2019, 07:23 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Couple of pics. The build has started. Fingers crossed will go all well but definitely a challenge as I have 4 to build
Got delivery for my remaining 3 subs and couple of other bits this morning
ID:	2634496   Click image for larger version
ID:	2634498   Click image for larger version
ID:	2634500   Click image for larger version
ID:	2634502   Click image for larger version
OJ Bartley and kagtha like this.
post #3 of 66 Old 10-31-2019, 07:24 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
OK guys I decided to start making my double front baffle for my 4 x Ultimax 18s. I have attached some pictures for reference. Tomorrow I aim to make my internal bracing in a similar fashion
ID:	2634506   Click image for larger version
ID:	2634508   Click image for larger version
ID:	2634510   Click image for larger version
ID:	2634512   Click image for larger version
ID:	2634516   Click image for larger version
post #4 of 66 Old 10-31-2019, 07:31 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
I had to get really creative when deciding on how I was going to build the bracing. I decided that I was going to build interlocking bracing for maximum strength and stability. This was actually a much harder task then yesterday when building the double front baffles. It is very time consuming and really had to put my brain to work lol calculating the shape and design of the bracing. I always enjoy doing these things but today was a bit too much
ID:	2634522   Click image for larger version
ID:	2634524   Click image for larger version
ID:	2634526   Click image for larger version
ID:	2634528   Click image for larger version
ID:	2634532   Click image for larger version
ID:	2634534   Click image for larger version
ID:	2634536   Click image for larger version
ID:	2634538   Click image for larger version
post #5 of 66 Old 10-31-2019, 07:34 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
I finally finished the bracing for all four boxes. I had an idea last night that I wanted to use pocket hole screws for my bracing along with wood glue to make it extra strong. Again, a very time consuming process yet was worth in the end. All four boxes bracing complete and I can now proceed to glue on the double baffles
ID:	2634542   Click image for larger version
ID:	2634544   Click image for larger version
ID:	2634546   Click image for larger version
ID:	2634548   Click image for larger version
ID:	2634552   Click image for larger version
ID:	2634554   Click image for larger version
ID:	2634556   Click image for larger version
post #6 of 66 Old 10-31-2019, 07:56 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
post #7 of 66 Old 10-31-2019, 08:38 AM
Zarkoff500's Avatar
Quoted: 228 Post(s)
Liked: 173
This is looking great. Thank you for the detailed pictures and commentary. Everything looks very precise and to have gone together well. None of my builds have had such precision . I saw on one of the baffles there was a router gouge, did you end up filling that? I ask because I have done the same thing and had to fix it to prevent air leaks around the driver.
I did an UM18 flat pack build a few years ago and ended up doing a triple front baffle to recess the driver. Turned out ok, but I like the look of the double baffle better. These UM18's should be on display.
Name:	20171103_171225 (resized).jpg
OJ Bartley and mkohman like this.
Zarkoff500 is offline
post #8 of 66 Old 10-31-2019, 08:55 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Thank you for your kind words. Your build also looks lovely
That is not a gouge it is a burn mark from the router. It hasn't penetrated the wood as I use the routers stopper but it did mark it.. there is no hole and even if there were it wouldn't really matter too much as that is the lip and directly under that is the 18mm thick first baffle which will be sandwiched onto , glued and clamped but thank you for bringing that to my attention, I appreciate it
I do have a question though.. My screws for the baffle are 32mm long and the MDF is 18mm + another 5mm for the lip on the top baffle so total of 23mm. This means the screw will be penetrating into the box by 9mm .. Would this be ok? or shall I cut small 18mm thick blocks and glue them directly under where I will be screwing in the driver so the screws will be going into 18mm+5mm+18mm = 41mm thick MDF? or better yet I may be able to make some plywood blocks to glue under where the screws will screw into? Any thoughts would be appreciated .. thank you
post #9 of 66 Old 10-31-2019, 09:17 AM
a77cj7's Avatar
Quoted: 323 Post(s)
Liked: 263
Screws penetrating into the box isn’t a problem at all. However, adding plywood blocks behind will give you greatly improved holding power and strip resistance.
Chris
mkohman likes this.
a77cj7 is offline
post #10 of 66 Old 10-31-2019, 09:39 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Chris
Thank you Chris, would MDF blocks behind be sufficient? or would you recommend plywood? thank you
post #11 of 66 Old 10-31-2019, 09:42 AM
a77cj7's Avatar
Quoted: 323 Post(s)
Liked: 263
More MDF is better than nothing. Plywood or solid wood holds many times better.
Chris
mkohman likes this.
a77cj7 is offline
post #12 of 66 Old 10-31-2019, 09:56 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Chris
Thank you Chris, much appreciated, I will more than likely do this with plywood!
post #13 of 66 Old 10-31-2019, 10:04 AM
kgveteran's Avatar
Quoted: 803 Post(s)
Liked: 239
Congrats on the Quad build ! I’ve been using (4) “Sealed” 15’s for the better part of 15 years, been quite happy with their performance it my two last houses.
As you know they require more power to get where ur going, did i miss how you were gonna power them. I use QSC 1450’s bridged and fan modded :0)
With great luck im about to disconnect my MiniDSP2x4 because i found a great location for all (4) which requires no EQ.
Looking forward to your completion and setup !!!
mkohman likes this.
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
post #14 of 66 Old 10-31-2019, 10:31 AM
OJ Bartley's Avatar
Quoted: 530 Post(s)
Liked: 622
Excellent job on the bracing, that's quite a bit beyond the basic required technique, but it looks fantastic. Great build so far.
mkohman likes this.
OJ Bartley is offline
post #15 of 66 Old 10-31-2019, 10:32 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Thank you so much for your kind words and wishes I am also looking very much forward to finishing and actually integrating them into my system
I am going to use 2 x inuke NX 6000 with miniDSP 2x4HD. I hope this will be sufficient to power these beasts!
post #16 of 66 Old 10-31-2019, 10:34 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Thank you OJ
post #17 of 66 Old 10-31-2019, 11:02 AM
Zarkoff500's Avatar
Quoted: 228 Post(s)
Liked: 173
Two 6000 inukes should do well. In terms of backing blocks, like Chris said, solid hardwood > plywood > mdf. I have used all three and oak blocks work a treat.
mkohman likes this.
post #18 of 66 Old 10-31-2019, 11:13 AM
kgveteran's Avatar
Quoted: 803 Post(s)
Liked: 239
Congrats on the Quad build ! I’️ve been using (4) “Sealed” 15’️s for the better part of 15 years, been quite happy with their performance it my two last houses.
As you know they require more power to get where ur going, did i miss how you were gonna power them. I use QSC 1450’️s bridged and fan modded :0)
Thank you so much for your kind words and wishes [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG] I am also looking very much forward to finishing and actually integrating them into my system [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
You should have no problem with that power and four 18’s in ur 21’x13’ room. Mine are at the 1/3rd point in the room and the best i’ve ever seen em measure. I use an OmniMic with the newer multich disc.
mkohman likes this.
post #19 of 66 Old 10-31-2019, 11:42 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Your room looks really nice
post #20 of 66 Old 11-01-2019, 11:45 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Guys, quick question.. what do I use to line up the inside of the cabinets? Will Egg Crate Foams be ok?
https://www.amazon.co.uk/Hemore-Soun...57055891&psc=1
If so , how much do I use? Do I just line up the back or the back and sides and top and bottom? Thank you.
post #21 of 66 Old 11-01-2019, 12:00 PM
smcmillan2's Avatar
Quoted: 987 Post(s)
Liked: 836
For sealed? About 3 standard size polyfill pillows per box, the cheapest you can find. Here in the states: https://www.target.com/p/plush-pillo...E&gclsrc=aw.ds
mkohman likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #22 of 66 Old 11-01-2019, 12:04 PM
Quoted: 195 Post(s)
Liked: 72
This is what I use for all my projects
https://www.walmart.com/ip/Poly-Fil-...d-Box/20713592
mkohman likes this.
Remy.Alexander is offline
post #23 of 66 Old 11-02-2019, 01:07 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Thank you! Does it have to be Polly fill or can I actually line up the side, back and top and bottom walls with acoustic foam (spray glued onto the panels)? or is there a reason why Polly fill should be used? Thank you.
Also any pics for example as to how to place within inside the cabinets please? thank you.
post #24 of 66 Old 11-02-2019, 02:37 PM
kgveteran's Avatar
Quoted: 803 Post(s)
Liked: 239
I stuff mine with pink fluffy insulation, my guess polly fill will do the same.
Same amount in each :0)
Not too much, but def not just stapled to the sides, fill it up !
mkohman likes this.
post #25 of 66 Old 11-03-2019, 02:46 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Thank you.. Do I just stuff it loose or do I staple it down or something? Thanks
post #26 of 66 Old 11-03-2019, 02:48 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
I glued on the last subs second baffle this morning before I headed off to work. I am pleased that all the gluing and clamping is over now next will be sanding, rounding over all the edges and cutting out for speak on connectors followed by painting
ID:	2635820   Click image for larger version
ID:	2635822   Click image for larger version
post #27 of 66 Old 11-04-2019, 10:33 AM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
Quick update on the build.. All the double baffles were glued on and finished yesterday so today I had some time to take the boxes to the garage and give them a good sanding. For this I used my Bosch Orbital Sander (I absolutely love that machine) and I did grit numbers 80, 120, 240 and 320 in those exact orders all over each box. I then used my router and a 9.5mm rounding bit to round over every edge and then re sanded the whole box with 320 grit to finish off. Each box took almost 2 hrs as I was taking my time in order to get a smooth/perfect finish. Today I was only able to finish off 2 boxes and plan on tackling the other 2 tomorrow. Here are some pictures for now
Sent from my SM-N960F using Tapatalk
OJ Bartley likes this.
post #28 of 66 Old 11-04-2019, 10:39 AM
Quoted: 225 Post(s)
Liked: 215
I think I read somewhere that if you stuff it with poly, it acts like a bigger box. I'm not sure the science involved, or if another kind of insulation will achieve the same effect.
mkohman likes this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #29 of 66 Old 11-05-2019, 12:55 PM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
https://www.youtube.com/watch?v=INM0g1JeMLY
I remember hearing that too
post #30 of 66 Old 11-05-2019, 12:56 PM - Thread Starter
mkohman's Avatar
Quoted: 441 Post(s)
Liked: 395
All boxes rounded over and final sanding with 400 then 600 grit complete. I only have to do the speakon connectors tomorrow then fully ready for painting. I also did the threaded inserts for the rubber feet
