Tekton Enzo xl vs 1099 vs titan xl for music - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #1 of 32 Old 11-01-2019, 08:36 AM - Thread Starter
frankie2075's Avatar
Quoted: 478 Post(s)
Liked: 116
Which do you guys believe would be winner based off what experience you had with them?
frankie2075 is offline
post #2 of 32 Old 11-01-2019, 03:38 PM
Quoted: 501 Post(s)
Liked: 445
Not sure about the Tekton but the 1099 and Titan are geared for HT but have heard they are also good for music. Some build the 1099/1299 with a bigger enclosure to get some more low end that would be better for music listening.
You came to the right place to ask. Hopefully some others have some more to chime in.
cocrh is online now
post #3 of 32 Old 11-01-2019, 04:26 PM
Liked: 5
Will you use them with a sub?
My 2.1: Minidsp2x4 HD,Hypex UCD400HxR,SI HT-18,HTM-10
HTM 10 build
felix94 is offline
post #4 of 32 Old 11-01-2019, 04:44 PM - Thread Starter
Quoted: 478 Post(s)
Liked: 116
I don’t really want to use a sub but possibly if I really have too
post #5 of 32 Old 11-01-2019, 04:47 PM - Thread Starter
Quoted: 478 Post(s)
Liked: 116
I owned the 1099 I thought they were pretty good for music but definitely needs subs. I don’t want to build a whole new cabinet cause I don’t have the tools or time. Prefer the kits. It’s says the titans go down to 30hz which isn’t to bad. Hoping some more guys do chime in.
post #6 of 32 Old 11-01-2019, 04:54 PM
Quoted: 135 Post(s)
Liked: 42
Depending on the music choice I’d definitely recommend a sub. No matter what speaker you have a sub will really improve the experience with anything under 60hz. I have the titans and for me they have been the best I’ve owned, but I have yet to hear anything over $400 per speaker. But being about $650 for each titan they are easily 4x better so definitely worth the price.
[email protected] is online now
post #7 of 32 Old 11-01-2019, 05:54 PM
smcmillan2's Avatar
Quoted: 965 Post(s)
Liked: 825
I've not heard the Titans, but here is one forum member's perspective (potentially useful given your specific "for music" question): https://www.avsforum.com/forum/155-d...stics-vr3.html
AFAIK ALL DIYSG HT offerings are designed to be used with sub(s).
Given that, I have found our HTM-10s to be terrific for both HT and music (with subs). These are in our living room with no treatments, so take that with a grain of salt.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #8 of 32 Old 11-01-2019, 06:41 PM
mtg90's Avatar
Quoted: 790 Post(s)
Liked: 1625
The Titan's bass level is still rather lean compared to more music focused speaker designs. I find my Nexus tower designs to have much more enjoyable full range bass performance with music then the Titan as the Nexus tower was designed to play full range and uses woofers that naturally extend to those low frequencies. The Titan was designed as a high sensitivity high power LCR which could be crossed down to 40hz if needed but still designed to be used with subs.
If you don't want to use subs then you will want EQ to boost and extend the bottom end much like running subs hot.
mtg90 is online now
post #9 of 32 Old 11-02-2019, 05:59 AM - Thread Starter
Quoted: 478 Post(s)
Liked: 116
What if I use another mbm15 with it? So each has 2 15”mbm? Can I re work the xover to incorporate the 2nd mbm
post #10 of 32 Old 11-02-2019, 10:09 AM
Erich H's Avatar
Quoted: 1892 Post(s)
Liked: 2722
At some point in early 2020 some of the Fusion models will make a comeback as full range speakers.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #11 of 32 Old 11-02-2019, 10:52 AM
mtg90's Avatar
Quoted: 790 Post(s)
Liked: 1625
Building it with the extra 15" does increase the bass level but at the same time does not give it any more extension. The Titan woofer in the flat pack begins to roll off around 50-55hz so you still don't authoritative bass below that range without EQ or getting lucky with lots of room gain. Depending on the music you like that might be good enough but I'd say a 6dB PEQ filter at 40hz with Q = 1-2 would make things much more satisfying. If you are going to be using mains full range and want good bass you should be using EQ on them at least for room correction at low frequencies much like a subwoofer system.
mtg90 is online now
post #12 of 32 Old 11-03-2019, 04:38 PM - Thread Starter
Quoted: 478 Post(s)
Liked: 116
Hmmm.. 2 ways? 15?
post #13 of 32 Old 11-04-2019, 03:52 AM - Thread Starter
Quoted: 478 Post(s)
Liked: 116
Eqing like AUD or Dirac?
post #14 of 32 Old 11-04-2019, 10:24 AM
mtg90's Avatar
Quoted: 790 Post(s)
Liked: 1625
Yes if you have the ability to set a target curve either in Audyssey or Dirac you will be able to contour the bass response and level to your liking. Just don't boost much below 40hz (the tuning frequency of the Titan flatpack) unless you extend the ports.
mtg90 is online now
post #15 of 32 Old 11-04-2019, 11:37 AM
notnyt's Avatar
Quoted: 3829 Post(s)
Liked: 3781
Tektons are trash and the design stinks of ineptitude.
notnyt is offline
post #16 of 32 Old 11-04-2019, 04:37 PM
dasa2131's Avatar
Quoted: 75 Post(s)
Liked: 75
Could you elaborate on your comment? Please understand I don't have a dog in this fight - I'm just curious what design details or features are questionable on the Tektons.
Dave
dasa2131 is online now
post #17 of 32 Old 11-04-2019, 04:41 PM
notnyt's Avatar
Liked: 3781
Dave
The tweeter array is idiotic, the off axis is horrid, The FR is pretty bad, and there are bad resonances to boot. It's just not good. All that, and this is one of their less horrible models.
BigJake82 and Chris Popovich like this.
notnyt is offline
post #18 of 32 Old 11-05-2019, 06:27 AM - Thread Starter
Quoted: 478 Post(s)
Liked: 116
Matt so I’m about to order the titans615lx can I extend the low Fq of the woofer if I tune the box so I can have it dig a little deeper?
post #19 of 32 Old 11-05-2019, 08:29 AM
kaiforce's Avatar
Quoted: 129 Post(s)
Liked: 181
I think you'll find the titans to be a significant step up in the bass department compared to 1099's, especially if the ones you had were the standard design. In my space with corner loaded titans and a seating position against the wall, they pumped out plenty of bass when I demo'd EDM music, to the point that I had to triple check my subs weren't on. If you're worried you can always build the Titan 630LX dual woofer versions: https://www.avsforum.com/forum/155-d...uned-25hz.html
Pair of Titan 615LX
8x Full Marty (6x UM18-22, 2x SI HT-18) on 4x Inuke6000DSP
4x Sealed Dayton 460HO on Crest Audio ProLite 5.0
4x Volt 10LX
kaiforce is offline
post #20 of 32 Old 11-05-2019, 09:08 AM
bear123's Avatar
Quoted: 2754 Post(s)
Liked: 4230
Subs will always provide better sound for music. It makes no sense to insist on no subs if you want good sound quality. Good placement for imaging and soundstage often = poor placement for bass. Cross ANY speaker at 80 Hz to well integrated subs and sound quality will be better
bear123 is offline
post #21 of 32 Old 11-05-2019, 10:33 AM
notfastenough's Avatar
Quoted: 196 Post(s)
Liked: 224
Amen to placement/seating position. I have some tiny Polk Monitor 50 towers that were 'lost' in the movie room with seating near the center of the mostly closed room. But when I put them into a living area spaced off the front wall and the seating position is against a back wall, they really opened up. Also, the new room is completely open to the house with much reflection.
To the OP, certainly heed the advice given here!! If you're after music without subs, you really should consider the other offerings DIYSG has on offer as well, Cobalts, Apollos, etc.
notfastenough is online now
post #22 of 32 Old 11-05-2019, 11:00 AM
mtg90's Avatar
Quoted: 790 Post(s)
Liked: 1625
You can tune the box lower (around 32hz) if you purchase the 4" precision port extension tube cut it in half and attach it with a pair of extra couplings. That said you won't really gain additional extension, if fact the f3 point moves up a couple hz, f6 stay about the same and f10 drops a few hz. What it does allow is more boost/EQ at lower frequencies without getting below port tune.
If you want more natural extension you would have to use a larger enclosure. Something like 8cuft would result in an f3 is the mid 30's rather then an f10 in the mid 30's that the stock cabinet provides.
mtg90 is online now
post #23 of 32 Old 11-05-2019, 01:50 PM - Thread Starter
Quoted: 478 Post(s)
Liked: 116
Couldn’t I use flat pack from gsg like this
https://shop.gsgad.com/collections/15-inch-marty-sub-flat-packs/products/marty-15
To use instead of the one that comes with to get a lower tuning for music?
post #24 of 32 Old 11-05-2019, 04:21 PM
dasa2131's Avatar
Quoted: 75 Post(s)
Liked: 75
NotNYT,
Thanks for your explanation. By the way, I really enjoyed your comment, "Tektons are trash and the design stinks of ineptitude"! The next time my wife asks my opinion about new drapes/candle holders/rugs/whatever, I'm gonna drop that line. I can't wait!
Dave
notfastenough likes this.
post #25 of 32 Old 11-07-2019, 01:28 PM
DavidinGA's Avatar
Quoted: 423 Post(s)
Liked: 140
Towers?
Source: HTPC w/madVR, Video: Epson 5040, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofer: MiniMarty um18 w/NX3000D.
DavidinGA is online now
post #26 of 32 Old 11-16-2019, 02:22 PM
DavidinGA's Avatar
Quoted: 423 Post(s)
Liked: 140
Approximate price point?
Give us something
Sent from my Pixel 2 XL using Tapatalk
post #27 of 32 Old 11-18-2019, 05:11 PM
chadsmith013's Avatar
Quoted: 2352 Post(s)
Liked: 2393
Eric...whats up with the Kuda, Sledge and Impact?
jevchance likes this.
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP Channel A
Nearfield: 4 B-52 SP-1804 18s w/Inuke 6000DSP Channel B
chadsmith013 is online now
post #28 of 32 Old 11-19-2019, 12:50 PM
Quoted: 224 Post(s)
Liked: 214
Will you use them in a tub?
Sorry, too many kid's books.
Kevin4730 likes this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #29 of 32 Old 11-19-2019, 02:46 PM
MKtheater's Avatar
Quoted: 2570 Post(s)
Liked: 2762
I built a pair of speakers with a line array of 4 tweeters and they measured really smooth on axis and sound awesome in room.
Building the room, speakers, and subs.
MKtheater is online now
post #30 of 32 Old 11-19-2019, 03:38 PM
notnyt's Avatar
Liked: 3781
Except for the combing in the direction of the array.... Curved line arrays with increased padding as distance from the center increases are the solution to that problem. Keele's CBT papers highlight this issue.
notnyt is offline
