For info on my dual BMD Alpha devastators, scroll to near the end of this thread!
Update: devastators are done! Gtg scheduled to show others what they added to my system. Gtg is 1-11-20! So far the attendees are: @hd0823 @imrf @VicTorious1 @brian6751 @thisismyname123 @Soloact @Jefro6996
Please let me know if you want to join in!
Thanks to the devastator index, I found a design I can actually fit and integrate into my theater system. I’ve been considering swapping my hst’s for 24’s or 21’s, and thanks for @eng-399 I’ve been able to see that with my size cabs, I only get marginal improvements. So for a little wood, and the cost of a couple drivers, I decided to go with a couple devastator micros. That’s the back story. Here’s the fun part, I’ll be taking and sharing a lot of pics, and maybe a vid or two. @Red Five suggested I run these from 60-90hz ish, though they are designed to run up to 120hz, I will crossover to my mains lower then that. And my hst’s will handle 12-60hz. They take care of that range with authority, so these devastators will amp up the midbass a lot. With 2000 watts, one will hit 135db in the range I will use them for, and I’ll have 2. So if I understand correctly, this should make for a fun time. Driver is the Lavoce WAF154.00 these are heavy. And I put a little power into them and wow. They look sweet with that cone moving.
Thanks also to @hd0823 for the bad influence, and for building his devastators. His are insane with the 21’s. I know mine will be too.
