Dual Devastator micro build - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #1 of 92 Old 11-03-2019, 12:46 PM - Thread Starter
Jk7.2's Avatar
Quoted: 1570 Post(s)
Liked: 2790
Thanks to the devastator index, I found a design I can actually fit and integrate into my theater system. I’ve been considering swapping my hst’s for 24’s or 21’s, and thanks for @eng-399 I’ve been able to see that with my size cabs, I only get marginal improvements. So for a little wood, and the cost of a couple drivers, I decided to go with a couple devastator micros. That’s the back story. Here’s the fun part, I’ll be taking and sharing a lot of pics, and maybe a vid or two. @Red Five suggested I run these from 60-90hz ish, though they are designed to run up to 120hz, I will crossover to my mains lower then that. And my hst’s will handle 12-60hz. They take care of that range with authority, so these devastators will amp up the midbass a lot. With 2000 watts, one will hit 135db in the range I will use them for, and I’ll have 2. So if I understand correctly, this should make for a fun time. Driver is the Lavoce WAF154.00 these are heavy. And I put a little power into them and wow. They look sweet with that cone moving.
Thanks also to @hd0823 for the bad influence, and for building his devastators. His are insane with the 21’s. I know mine will be too.
imrf, femi, OJ Bartley and 4 others like this.
Jk7.2 is online now
post #2 of 92 Old 11-03-2019, 01:03 PM
Mahuzz13's Avatar
Quoted: 399 Post(s)
Liked: 750
2 devastators WOW that is awesome!!!
Game changer
I would hate to take credit for something I said to both Mike and Jeremy and not directly to you but it’s true. Jermey and Mike both said that you wanted to change something in you setup to make it more impactful, I said why doesn’t he just build 2 V3 put them in his furnace room and call it a day. Look now you are doing it but in a smaller but an amazing way.
I look forward to hearing these in person
Jk7.2 likes this.
Mahuzz13 is offline
post #3 of 92 Old 11-03-2019, 01:05 PM
imrf's Avatar
Quoted: 220 Post(s)
Liked: 157
Pretty sweet. Can’t wait to hear your thoughts on the room once they’re done.
Jk7.2 and Mahuzz13 like this.
imrf is online now
post #4 of 92 Old 11-03-2019, 01:14 PM
Red Five's Avatar
Quoted: 772 Post(s)
Liked: 569
The SAN184.03s are pretty beefy too. Looking forward to seeing the build thread!
Jk7.2 likes this.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #5 of 92 Old 11-03-2019, 01:19 PM - Thread Starter
Jk7.2's Avatar
Liked: 2790
Game changer
Yeah, swapping out drivers in the subs wasn’t exactly what I’m after. Anything I did wouldn’t hang with the hst’s down low in my size cabs. This way I’ll keep that performance, and up the midbass like I want.
I’ve also been tweaking the mains and adding boosts to the midbass. I watched the original Jurassic Park last night with some fresh boosts and dang, the thunder storm and t-Rex scene was excellent.
kevings, Mahuzz13 and Falonious like this.
Jk7.2 is online now
post #6 of 92 Old 11-03-2019, 01:29 PM
johnson636's Avatar
Quoted: 1296 Post(s)
Liked: 763
Adding Devastators...well that didn't take long
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #7 of 92 Old 11-03-2019, 01:30 PM - Thread Starter
Jk7.2's Avatar
Liked: 2790
Lol guys. Have you seen the size of the micro? It’s only 18 wide. That makes it a winner.
Jk7.2 is online now
post #8 of 92 Old 11-03-2019, 01:37 PM
imrf's Avatar
Quoted: 220 Post(s)
Liked: 157
I may have to take a peek at those for my room once I start working on it.
Jk7.2 likes this.
imrf is online now
post #9 of 92 Old 11-03-2019, 01:38 PM - Thread Starter
Jk7.2's Avatar
Liked: 2790
Or just wait 5 min until I sell these. Hahahaha!
No, for real
Jedi940 and chadsmith013 like this.
Jk7.2 is online now
post #10 of 92 Old 11-03-2019, 02:28 PM
Craig S King's Avatar
Quoted: 430 Post(s)
Liked: 539
Looking forward to seeing the progress!
Craig S King is offline
post #11 of 92 Old 11-03-2019, 03:14 PM
smcmillan2's Avatar
Quoted: 959 Post(s)
Liked: 819
Probably this...
Seriously though, I'll probably hear/feel Jared's setup at my place now, once these are in place.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #12 of 92 Old 11-03-2019, 03:16 PM
johnson636's Avatar
Liked: 763
Or you could sell me the HST18s and get yourself 4 21s
post #13 of 92 Old 11-03-2019, 03:27 PM
Mahuzz13's Avatar
Quoted: 399 Post(s)
Liked: 750
Do give him any ideas now
Even thought that’s an awesome plan
Mahuzz13 is offline
post #14 of 92 Old 11-03-2019, 04:55 PM - Thread Starter
Jk7.2's Avatar
Liked: 2790
I seriously considered selling the hst’s. I just love them though. And every model shows other subs just hanging in with them below 20-25 hz, then rising. So I think this path is best. I’m not lacking 12-60hz. I can’t wait to see where these put me.
Jk7.2 is online now
post #15 of 92 Old 11-03-2019, 05:01 PM
superkyle's Avatar
Quoted: 1009 Post(s)
Liked: 456
Following this for sure! I’ve been debating back and forth between the micro and mini but believe I have settled on the mini due to the same tune as the larger version. I’m very interested in how well these integrate between the low end and you mains. A couple of us have has issue with some cancellations playing with the multiple tunes but playing with the slope of the crossover should provide excellent results!
Jk7.2 likes this.
Always destroying exergy!
superkyle is offline
post #16 of 92 Old 11-03-2019, 05:25 PM
imrf's Avatar
Quoted: 220 Post(s)
Liked: 157
No, for real
Haha. I was going to say that but didn’t want to be a jerk. BUT, yes when you’re ready to sell them, shoot me a text. Lol
Jk7.2 likes this.
imrf is online now
post #17 of 92 Old 11-03-2019, 05:33 PM
johnson636's Avatar
Liked: 763
I actually considered two ported 21s, but if I do that, I would have enough space for 2 more HS24s
post #18 of 92 Old 11-03-2019, 05:47 PM
hd0823's Avatar
Quoted: 858 Post(s)
Liked: 1627
Just throw the 21s in some v3s way cheaper and downright crazy output
Sent from my SM-N950U using Tapatalk
hd0823 is online now
post #19 of 92 Old 11-03-2019, 05:50 PM
hd0823's Avatar
Quoted: 858 Post(s)
Liked: 1627
Yeah I cant wait to see these done. I'm going to have to come down and here them in the room.
imrf likes this.
post #20 of 92 Old 11-03-2019, 06:44 PM
imrf's Avatar
Quoted: 220 Post(s)
Liked: 157
I sense a mini GTG. Lol
imrf is online now
post #21 of 92 Old 11-03-2019, 06:51 PM
hd0823's Avatar
Quoted: 858 Post(s)
Liked: 1627
Lol we will probally do another one next fall time I wont have many upgrades done but Jared looks like he will lol. I'll probally only have the motion sensored movie posters added actually by this week . I was going to go with a 16ft scope screen but dont want to drop the crazy money it will cost for the projector and anamorphic lens. Just gotta give it a few years. Jared's upgrades do give me the sub building itch lol but my wife would kill me
Jk7.2 likes this.
post #22 of 92 Old 11-03-2019, 06:52 PM
imrf's Avatar
Quoted: 220 Post(s)
Liked: 157
Lol. Yeah, might be time for you to build that kid playroom she wants and just enjoy your amazing theater as is for a while.
imrf is online now
post #23 of 92 Old 11-04-2019, 05:22 AM
johnson636's Avatar
Liked: 763
And stay away from this place. If not, we'd upgrade something every six months BTW, you have one of the best looking theaters here. And from talking to a fellow Georgian who attended you and Jared's gtg, the bass in your room is absolutely insane
post #24 of 92 Old 11-04-2019, 05:40 AM
eng-399's Avatar
Quoted: 2440 Post(s)
Liked: 5065
Can’t wait to see this build Jared
Your room is going to be insane! Will these go in the back of the room.
Jk7.2 likes this.
eng-399 is offline
post #25 of 92 Old 11-04-2019, 06:05 AM - Thread Starter
Jk7.2's Avatar
Liked: 2790
Mike these are going in the front. I know there’s no room, but there actually is just enough on the outsides of the screen. I just hope it’s ok to fire them through velvet. Otherwise I’ll have to do black grill cloth.
Jk7.2 is online now
post #26 of 92 Old 11-04-2019, 06:12 AM
johnson636's Avatar
Liked: 763
If its stretched velvet then you should be fine. I've had some vbss's behind velvet and there were no ill effects.
Jk7.2 likes this.
post #27 of 92 Old 11-04-2019, 06:29 AM - Thread Starter
Jk7.2's Avatar
Liked: 2790
Ok good. I know the bass frequencies usually fly through thin stuff like fabric.
A key thing for my room is having all the speakers hidden. I love to surprise people that haven’t been over before with a loud explosion or something.
johnson636 and corradizo like this.
Jk7.2 is online now
post #28 of 92 Old 11-04-2019, 07:40 AM - Thread Starter
Jk7.2's Avatar
Liked: 2790
That was before the jeremys devastators were built. Now it’s crazy.
Jk7.2 is online now
post #29 of 92 Old 11-04-2019, 07:48 AM
Red Five's Avatar
Quoted: 772 Post(s)
Liked: 569
The only question mark I would have with a material in front of the mouth of the horn is whether or not you get the TR from the air particle movement. That should be easy enough to test though
post #30 of 92 Old 11-04-2019, 07:50 AM
hd0823's Avatar
Quoted: 858 Post(s)
Liked: 1627
Yeah the devastors did push it over the top. I remember me and you where both suprised what they added
Jk7.2 and Falonious like this.
