Diy sound insulation for isolating ceiling speaker back waves to floor above? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-05-2019, 06:27 PM - Thread Starter
rr14's Avatar
Quoted: 133 Post(s)
Liked: 32
Hi all,
I’m about to install some speakers in the ceiling (surround speakers) and am wondering if placing pillows above the speakers will quiet down any effects of having ceiling speakers to the floor above? Kind of ghetto but I have the pillows here from my mini Marty builds as extras.
Any other known techniques for dealing with this?
rr14 is offline
post #2 of 5 Old 11-05-2019, 08:19 PM
asarose247's Avatar
Quoted: 1257 Post(s)
Liked: 1103
the lower the FR the more energy there is to be transmitted
can you mount using an isolation / vibration absorbent material
that's only part of the problem
the denser the material , like 703
is that conducive to greater absorption?
what is the suspected xo for these speakers
is it TBD per Audy , etc.?
and the back of the speaker will radiate in a sphere, mol
pack that space ..
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #3 of 5 Old 11-06-2019, 01:50 AM
mhutchins's Avatar
Quoted: 265 Post(s)
Liked: 243
The only method that will have a noticeable effect is to enclose the speakers in a rigid box that is sealed to the ceiling drywall so no rear sound escapes into the ceiling cavity. The next level of sound isolation is achieved by mounting the box with isolation clips to the ceiling structure to minimize the transmission of box vibrations into the ceiling structure which then can be broadcast into the room above via flanking paths.
If you build enclosures for your speakers, remove the stuffing from the pillows and put it inside your speaker enclosures, otherwise, leave the pillows on the bed.
Mike
mhutchins is offline
post #4 of 5 Old 11-07-2019, 01:16 PM - Thread Starter
rr14's Avatar
Quoted: 133 Post(s)
Liked: 32
Mike
Thanks for the info. I ended up going ahead without them at the current time to see how much of an issue it even is before making an effort
rr14 is offline
post #5 of 5 Old 11-07-2019, 02:23 PM
Quoted: 208 Post(s)
Liked: 205
Sounds like a great place for the mice to call home.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is online now
