PL3 question - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 3 Post By eng-399
  • 3 Post By asarose247
  • 3 Post By Purenv
post #1 of 18 Old 11-05-2019, 07:13 PM - Thread Starter
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 142
PL3 question
How much time does it take for PL3 to cure before I can remove the weight?
Purenv is offline
post #2 of 18 Old 11-05-2019, 07:23 PM
eng-399's Avatar
Quoted: 2444 Post(s)
Liked: 5070
I wait 8 hours when it’s 60 degrees or colder outside. Removing the weights can probably happen after a few hours I just wouldn’t try to pick up the box or move much around. Push on the pl and see if it hardened if it’s hard your good to go.
eng-399 is offline
post #3 of 18 Old 11-05-2019, 07:59 PM
johnson636's Avatar
Quoted: 1299 Post(s)
Liked: 769
There should be recommendations on the bottle.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #4 of 18 Old 11-05-2019, 08:11 PM
asarose247's Avatar
Quoted: 1260 Post(s)
Liked: 1105
If there's been some additional form of ensuring panels staying put / positioned / in contact as intended,
not just weights or clamps
maybe like right away . . .
we've got stuff to build,
that stuff will expand, seal and adhere wherever it can
ID:	2637036   Click image for larger version
ID:	2637038   Click image for larger version
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #5 of 18 Old 11-05-2019, 08:34 PM
lawdogx's Avatar
Quoted: 176 Post(s)
Liked: 213
There’s been some pretty smart guys chiming in before me with lots more experience than I have, but I treat things differently depending on what part of the build I’m doing. If I’m going to be moving the box or flipping it over I do the full 24 hrs like it says on the label. If I’m not stressing the joint or moving the box (like just adding a piece to the same panel) I might do like 6-8 hrs, like glue and clamp a piece in the morning then add another after work. Then again, I don’t use Kregs or brads, so I’m really relying on those clamps.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is online now
post #6 of 18 Old 11-05-2019, 08:37 PM
eng-399's Avatar
Liked: 5070
That exactly what I do glue before work then once I get home continue. Better off safe then sorry. I did that today on a current 21” driver build.
eng-399 is offline
post #7 of 18 Old 11-06-2019, 05:32 AM
johnson636's Avatar
Liked: 769
I caught that. Did I miss the build thread?
post #8 of 18 Old 11-06-2019, 05:34 AM
eng-399's Avatar
Liked: 5070
I’ve been lazy I need to get a thread going on it
eng-399 is offline
post #9 of 18 Old 11-06-2019, 05:46 AM
johnson636's Avatar
Liked: 769
Will this be for yourself? A friend? Mains using 21" drivers
post #10 of 18 Old 11-06-2019, 06:42 AM
eng-399's Avatar
Liked: 5070
PL3 question
Not for me a box build for Wayne that’s in Madison Wisconsin. I’m building two 11 cubic ft boxes tuned at 17hz using the LaVoce 21” drivers. Then going to EQ his room. Using Dirac live for his mains and another mini dsp Dirac live for his subs. I’ll get a thread going today on it. Getting paid for it... trying to make my car fast...
johnson636, jevchance and JCJetta like this.
eng-399 is offline
post #11 of 18 Old 11-06-2019, 09:11 AM
Quoted: 12 Post(s)
Liked: 5
Sorry for this, but what is PL3?
HurricaneDitka is online now
post #12 of 18 Old 11-06-2019, 09:15 AM
johnson636's Avatar
Liked: 769
Polyurethane Construction Adhesive. Do a quick google.
post #13 of 18 Old 11-06-2019, 10:04 AM
asarose247's Avatar
Liked: 1105
https://www.homedepot.com/p/Loctite-...0595/202020473
always release the pressure when in a caulk gun
have a place to put the gun where the tip will drip - and it will
a roll of 2" package tape nearby will let you seal that cut end very tightly
and you should do it , even if for just a brief, like 5 minute pause, in the action end
get a box of latex disposable gloves- that stuff will invade your skin
a good pumice handcleaner will help get most of it off
the gloves are good for when you want to groom the fillet
as I pidtured above, a good fat 3/8" bead will squish to the full width of the surfacesand do it's thing.
"I love the smell of PL3X in the morning"
"Smells like Victory"
post #14 of 18 Old 11-06-2019, 12:51 PM
Quoted: 453 Post(s)
Liked: 380
If your project is big and requires you to put the gun down a few times, get a spare bucket and angle it in there. I find its much nicer to have to a secure place that will contain the PL3 without it getting anywhere, ESPECIALLY the floor where it inevitable gets on someones shoe.
Trimlock is online now
post #15 of 18 Old 11-06-2019, 07:34 PM
Bigus's Avatar
Quoted: 660 Post(s)
Liked: 597
I avoid pl3. Wood glue for glue. Sealant to seal. Sorry, not very helpful for the OP question I guess.
Bigus is online now
post #16 of 18 Old 11-07-2019, 10:20 AM - Thread Starter
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 142
Thanks guys for all your advice. 1099s turning out fairly well for my 1st DIYSG experience.
Purenv is offline
post #17 of 18 Old 11-07-2019, 02:24 PM
Quoted: 224 Post(s)
Liked: 214
Looking good so far!
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #18 of 18 Old 11-08-2019, 11:16 AM - Thread Starter
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 142
Thank you.
Purenv is offline
