Far Beyond Driven build LaVoce 21's slot ported - AVS Forum | Home Theater Discussions And Reviews
 120Likes
post #1 of 63 Old 11-06-2019, 05:50 PM - Thread Starter
eng-399's Avatar
Quoted: 2457 Post(s)
Liked: 5115
Hey guys back at it again this build is for Wayne out in Madison Wisc. he's using the LaVoce 21's for drivers and I'm building his boxes. What he has is a box from @Red Five already that's for nearfield and I'm building 2 slot ported boxes for the front of his room.
Box is 25w/26d/38h which is 11 cubic ft and tuned at 17hz.
Once this is done I'll be incorporating The mini dsp DDRC-88A and Mini dsp 2/4hd with Dirac live for both speakers and LFE channel in his Theater room.
Let the build begin
eng-399 is offline
post #2 of 63 Old 11-06-2019, 05:53 PM - Thread Starter
eng-399's Avatar
Liked: 5115
eng-399 is offline
post #3 of 63 Old 11-06-2019, 05:56 PM - Thread Starter
eng-399's Avatar
Liked: 5115
eng-399 is offline
post #4 of 63 Old 11-06-2019, 06:13 PM
a77cj7's Avatar
Quoted: 425 Post(s)
Liked: 358
Looking good as usual. Any functional reason for the narrower port, or strictly aesthetic?
Chris
a77cj7 is online now
post #5 of 63 Old 11-06-2019, 06:18 PM - Thread Starter
eng-399's Avatar
Liked: 5115
Chris
Hi Chris since the box is 25” wide the first port resonance didn’t look that good being the wide even with some port rails. I needed to keep the first port resonance in check so having a port a 17” wide 3” tall and 41.5 inches long ended up looking really nice on winisd. The air port velocity was low as well. I’ll post all that stuff soon. The plan is to flush trim bit the port out of the first and second baffle. Should look real nice when I’m done.
smcmillan2 and Jan3 like this.
eng-399 is offline
post #6 of 63 Old 11-06-2019, 06:25 PM
a77cj7's Avatar
Quoted: 425 Post(s)
Liked: 358
Ahh, makes sense. I always forget about the resonance issues.
I used a flush trim on baffles for a port that style on my last (and only) ported build. I would recommend jig sawing it most of the way first. Killed a flush trim bit by trying to take too much material.
I did think the look turned out really good though.
Chris
post #7 of 63 Old 11-06-2019, 07:05 PM
EndersShadow's Avatar
Quoted: 1282 Post(s)
Liked: 1546
Mike..... do you wonder how much MDF dust there is in your lungs at this point lol.....
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #8 of 63 Old 11-06-2019, 07:52 PM
smcmillan2's Avatar
Quoted: 1026 Post(s)
Liked: 865
Ditto here, resonances is one of the things a look for when dancing with the model. As you already know, it can be quite the workout!
Did you go through (what looks to me in that pic) 2 layers at once? Yeah, that will tax a trim bit quickly. I usually run them separately, first on the inner baffle then again once the outer has been applied. Much easier on the router/bit (and faster for me).
I built my first 5 - 6 subwoofers with a slot port in the fashion Mike is putting these together. Always liked the look, and they tuned almost exactly as they modeled. Doesn't really add to the thread, but like seeing the same method used here!
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #9 of 63 Old 11-06-2019, 08:02 PM
a77cj7's Avatar
Quoted: 425 Post(s)
Liked: 358
No, cut the first then glued on the second. My routers are all 1/4, so can’t run one of the taller flush trim bits anyways.
Hope we’re not derailing your thread too much @eng-399
Chris
post #10 of 63 Old 11-06-2019, 08:14 PM
smcmillan2's Avatar
Liked: 865
Ahh, yeah, that certainly limits how much you can run through at once. I use one of my 1/2" collet routers to hog out those openings, and that still puts a burden on the bit.
Agreed. Although sharing is caring!
post #11 of 63 Old 11-07-2019, 05:12 AM
dltnjarrel's Avatar
Quoted: 108 Post(s)
Chris
What size round over did you use here?
Sent from my SM-N950U using Tapatalk
dltnjarrel is offline
post #12 of 63 Old 11-07-2019, 05:33 AM
Red Five's Avatar
Quoted: 927 Post(s)
Liked: 735
Looking good Mike
eng-399 likes this.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #13 of 63 Old 11-07-2019, 05:40 AM
a77cj7's Avatar
Quoted: 425 Post(s)
Liked: 358
3/8in.
Chris
dltnjarrel likes this.
post #14 of 63 Old 11-07-2019, 05:56 AM - Thread Starter
eng-399's Avatar
Liked: 5115
I'll only go through one layer of mdf with my flush trim bit at a time. I need to get more pics posted of this build today.
Mike Butny and EndersShadow like this.
eng-399 is offline
post #15 of 63 Old 11-07-2019, 06:11 AM - Thread Starter
eng-399's Avatar
Liked: 5115
Dry fitting bracing and all the holes cut. As you can see on one of the braces my flush trim bit Allen screw on top of it came lose as the washer that guides the bit along the wood wore out glad I didn’t cut my finders off when hit the side of the brace
I cut strips of mdf and pin nail it to the brace then take my flush trim bit to make all my window braces...
eng-399 is offline
post #16 of 63 Old 11-07-2019, 07:58 AM
Hometheater Marine's Avatar
Quoted: 31 Post(s)
Liked: 78
Wayne can you post what your room looks like and your equipment.
Sorry I’m late to the party guys. I’m new to the DIY sub group and have met some really great people along the way. I want to say thanks to SOWK for starting me down this rabbit hole. He introduced me to @Red Five who I had a great time talking to and eventually met with and purchased his Storm breaker sub with the B&C 21” driver. He should have named it “Back breaker”. It’s incredibly built and a monster which will serve as a near field right behind my seating position. I was also introduced to @eng-399 . I was looking for 2 more DIY subs to replace the 2 SVS SB-16 sealed subs that I currently have, but didn’t have the tools, time, patience or technical expertise to do a DIY build so after talking to Mike (eng-399) and then driving to Illinois to meet with him I could tell that he was the one I wanted to do my build. He’s not only knowledgeable but has a genuine enthusiasm and passion. He comes highly recommended and I can see why. I didn’t want to keep upgrading so Mike convinced me to add 2 more 21” subs in front. Total overkill for a 13x18 room but there would be no need for future LFE upgrades in that room. We discussed the design goals and details and with the room being so small for such incredible low frequency firepower, I needed to have as much LFE control as possible. I also wanted to have synergy not only with 3 21” subwoofers but also with my mains as well.
Enter the Minidsp DDRC-88A with bass management plugin and Minidsp 2X4HD.
My room isn’t large like what a lot of you guys have but I’ve crammed a lot in there.
Here’s the room dimensions and equipment.
Room 13x18
3 Seaton Sounds Catalyst powered mains
M&K SS250 side surrounds ( non powered )
2 Adams A7X powered studio monitor rear surrounds
10’ Wide 2:35 screen
ISCO III Anamorphic lens
Cineslide motorized transport for ISCO lens
JVC RS500 projector
Marantz 7703 pre-pro
OPPO 203 4K universal player
Lumagen 4K video processor
2 SVS SB-16 sealed subs ( to be deinstalled just before upgrade )
1-Storm breaker 21” sub- installed behind seats.
2-21” subs with LaVoce drivers- currently being built
1- Chane 3600 sub amp in bridged mode for 21” nearfield sub.
2 NX3000 DSP sub amps for 2 21” subwoofers up front
ID:	2637658   Click image for larger version
ID:	2637660   Click image for larger version
ID:	2637662   Click image for larger version
ID:	2637664   Click image for larger version
ID:	2637668   Click image for larger version
Hometheater Marine is offline
post #17 of 63 Old 11-07-2019, 08:01 AM
Liked: 1546
^Love my Chane 3600 amp! Just need to get the second one up and running so I can bridge em to my JBL CS1214's...
Sorry for the threadjack...
post #18 of 63 Old 11-07-2019, 10:46 AM
JCJetta's Avatar
Quoted: 348 Post(s)
Liked: 698
First off, as per your username, thank you for serving.
Looks like Santa Mike is bringing you the gift of bass this Christmas! You cannot go wrong with Mike's builds; I cannot wait to get the setup he built me back into a proper room again. This is gonna be a fun one to follow, especially with the recent popularity of these hot Italian beauties, no doubt pushed into the spotlight by Mike himself.
Hopefully the weather will cooperate when it is time to transport those monsters home.
Mike Butny, johnson636 and eng-399 like this.
JCJetta is offline
post #19 of 63 Old 11-07-2019, 10:54 AM
johnson636's Avatar
Quoted: 1351 Post(s)
Liked: 834
Yes he did
JCJetta and eng-399 like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #20 of 63 Old 11-07-2019, 12:11 PM
Quoted: 234 Post(s)
Liked: 221
This part is adorable. Welcome to the fold!
mhutchins likes this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #21 of 63 Old 11-07-2019, 08:38 PM - Thread Starter
eng-399's Avatar
Liked: 5115
The 21” crazzz——. For whom the bell tolls—
This was the moment for me.
Story time fellas
I remember when I first had everything going mtg90 and myself were in my room and just got the 21’s going. Integration started rew Audy ect ect...
I remember putting on the Metallica Blu-ray Disc and playing for whom the bell tolls. The volume started creeping up louder and louder the sound of the kick drum was insane. The pod lights in my just started raining drywall dust down from the ceiling we getting the chest slam right into or gut long with the rest of the kirks awesome guitar licks going and then James starts singing. Wow was that a moment I know these 21’s were the real deal! It’s something that just needs to be heard live in concert or in a theater room loaded with 21’s. I’ll always remember that moment and tell that story to anyone in person that’s been over. The John wick gun battle was another that was just fun to hear and feel. These 2-‘s are different than other drivers like the ht-18’s or hst line but man it’s been a fun ride having these drivers. I can’t wait for Wayne to hear them to.
Dan ya dude my lungs are probably filled with mdf. I now a mask sanding all the time.
Picture time
eng-399 is offline
post #22 of 63 Old 11-08-2019, 08:59 AM
OJ Bartley's Avatar
Quoted: 550 Post(s)
Liked: 642
Mike, another Pantera themed sub build? I love it! Wayne, you are in very good hands here, and I'm sure that these, along with a third 21(!) will just crush your room. But in a good way. I'll be watching this one.
Oh, and Mike, I love the stories behind the motivation. My first big OMG HT moment was with my old faithful 15" Tempest when it was new, and firing up the end of Fight Club for the first time. Like you, I'll never forget it.
eng-399 likes this.
OJ Bartley is offline
post #23 of 63 Old 11-08-2019, 01:13 PM
Quoted: 234 Post(s)
Liked: 221
I might be dating myself here, but I remember getting my Eosone home theater set up at my college apartment, and my roommate firing up the original Star Wars trilogy on laserdisc. The room was tiny and that little 10" could really get things rockin.
MKtheater, OJ Bartley and eng-399 like this.
DIY 110" AT Screen
post #24 of 63 Old 11-08-2019, 05:16 PM - Thread Starter
eng-399's Avatar
Liked: 5115
@OJ Bartley
@jevchance
Fight club scene and Star wars movie it's CRazY how we can all relate to this we all have movie clip or moment in our rooms that makes us smile. Who doesn't like a good story to tell your friends it's like buying a classic car with a story behind it.
Mike Butny and OJ Bartley like this.
eng-399 is offline
post #25 of 63 Old 11-08-2019, 05:19 PM - Thread Starter
eng-399's Avatar
Liked: 5115
eng-399 is offline
post #26 of 63 Old 11-08-2019, 05:34 PM
smcmillan2's Avatar
Liked: 865
More pictures, Tomorrow the second baffle will go on.
No MDF dust there, well done!
eng-399 likes this.
post #27 of 63 Old 11-08-2019, 05:48 PM
Quoted: 31 Post(s)
Liked: 78
This guy seems to be working at warp speed. Now that I have most of what I need including odds and ends I better get my tail in gear this weekend. I know I received a link from another AVS forum member about how to wire up the 4 pin Noctua fans but I can’t seem to find it. If anyone has it could you please link it to me. I hope this fan upgrade doesn’t become a big project. It’s just one of the many things on my to do list this weekend.
ID:	2638370   Click image for larger version
ID:	2638372   Click image for larger version
ID:	2638374   Click image for larger version
ID:	2638376   Click image for larger version
post #28 of 63 Old 11-08-2019, 09:06 PM
Red Five's Avatar
Quoted: 927 Post(s)
Liked: 735
Mike, what grit do you like for tearing down the MDF? Does too much speed gum the paper up faster?
post #29 of 63 Old 11-09-2019, 09:54 AM - Thread Starter
eng-399's Avatar
Liked: 5115
I use a flush trim bit first then jump on my orbital sander with 50 grit sandpaper. After that 120 and 220 to finsh
Red Five likes this.
eng-399 is offline
post #30 of 63 Old 11-09-2019, 07:19 PM
LTD02's Avatar
Quoted: 2999 Post(s)
Liked: 3745
nice work mike, as always.
Mike Butny and eng-399 like this.
Listen. It's All Good.
LTD02 is offline
