Question about glue vs epoxy for my build. - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By jujuman200
  • 2 Post By noah katz
  • 1 Post By smcmillan2
post #1 of 13 Old 11-07-2019, 02:40 PM - Thread Starter
ratm's Avatar
Quoted: 229 Post(s)
Liked: 102
One of the benefits of a being career firefighter is someone always has or does what I need. Case in point, a buddy does finish woodworking and has all the tools necessary to cut my wood for my dual Fi Car HT-3 sealed build. He suggested epoxy instead of wood glue, thinking it would be stronger at holding everything together.
Good? Bad? Dumb?
ratm is offline
post #2 of 13 Old 11-07-2019, 02:54 PM
a77cj7's Avatar
Quoted: 211 Post(s)
Liked: 176
Good? Bad? Dumb?
Most good quality wood glues are stronger than the wood itself. Titebond III is a favorite around here, good adhesion and longer work time.
Loctite PL3x construction adhesive is a popular wood glue alternative here. It has much longer work times, doesn’t run down panels, and expands to fill and seal small gaps. It has also been tested to be stronger than the wood. It requires much longer cure time before unclamping and handling than wood glue.
I prefer wood glue for simple boxes, and PL for more complex builds with possible slight fitment inconsistencies.
Chris
a77cj7 is online now
post #3 of 13 Old 11-07-2019, 03:00 PM
rec head's Avatar
Quoted: 302 Post(s)
Liked: 273
IAFF Local 2 member here.
Unless your FF friend is going to do the epoxying for you or show you how to use it I would stick to wood glue. Its just easy to work with and plenty strong. The only epoxies I have ever used are not very forgiving.
rec head is offline
post #4 of 13 Old 11-07-2019, 04:18 PM
Bigus's Avatar
Quoted: 659 Post(s)
Liked: 597
Another vote for wood glue. Epoxy may have higher tensile strength but I'm not sure it has a better bond strength to wood substrate. Also, wood glue is already stronger than the wood. More is not needed.
Bigus is offline
post #5 of 13 Old 11-07-2019, 05:09 PM
jujuman200's Avatar
Quoted: 150 Post(s)
Liked: 122
Another vote for wood glue..... because you can actually get off your hands..... don't get me wrong, PL3 is AWESOME for some things, I use it myself ..... BUT you WILL wear it for at least 3 days or so....
IF you have a brad nailer, then wood glue is the way to go.... tack and move on...
Juju
mhutchins likes this.
Wish List: 2- Red Five DEVASTATOR MINI, 2- Red Five DEVASTATOR LFE, 1- BOSS platform.
Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is online now
post #6 of 13 Old 11-07-2019, 05:13 PM - Thread Starter
ratm's Avatar
Quoted: 229 Post(s)
Liked: 102
Wood glue it is!
ratm is offline
post #7 of 13 Old 11-08-2019, 07:03 AM
Quoted: 208 Post(s)
Liked: 205
My concern with epoxy is how well it seeps into the wood grain. That's why wood glue is so strong, it wicks into the wood then makes a super strong bond.
Good choice.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is online now
post #8 of 13 Old 11-08-2019, 07:58 AM
Quoted: 143 Post(s)
Liked: 156
Wood glue and don't look back..take 2 small pieces of wood. Glue and clamp. Wait 24 hours....try to get them apart
Sent from my Redmi Note 5 using Tapatalk
ccssid123 is offline
post #9 of 13 Old 11-08-2019, 10:33 AM
noah katz's Avatar
Quoted: 2116 Post(s)
Liked: 767
Just as a data point, epoxy absorbs very well into wood.
I use it, or polyester resin, to paint around joints to keep the seams from eventually showing.
I agree with everyone else about wood glue being adequate.
I will say though that if a lot of pieces are involved, I find PL more forgiving because the joints can be adjusted for quite some time.
I've had joints come out bad and require a lot of fixing because the wood glue has set too fast and not given me time to get all of the pieces in position.
jevchance and jujuman200 like this.
Noah
noah katz is online now
post #10 of 13 Old 11-08-2019, 02:53 PM
Rickreagan120's Avatar
Quoted: 16 Post(s)
To piggy back on this comment, the wood will break before the glue. I have seen it first hand. Tried to pull 2 pieces of wood apart on one of my home projects and the wood splintered and the glue remained. I had one of those told ya so moments.
Rickreagan120 is online now
post #11 of 13 Old 11-08-2019, 07:27 PM
Quoted: 143 Post(s)
Liked: 156
Regarding seams. I have always used dry-wall mud at the end grain. Lots of primer and then paint. Never an issue. Easy to do. And, it does last.
Sent from my SM-T800 using Tapatalk
post #12 of 13 Old 11-08-2019, 07:37 PM
smcmillan2's Avatar
Quoted: 955 Post(s)
Liked: 816
Yes, this, and easier to smear into those seams than wood filler. Just be sure to let it dry (takes longer than wood filler, being water based).
jujuman200 likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #13 of 13 Old 11-08-2019, 09:34 PM
a77cj7's Avatar
Quoted: 211 Post(s)
Liked: 176
Thats why I prefer to use bondo. Frustratingly short work time, so plan for small batches. Sandable in an hour or so though.
Chris
