DIY Soundgroup Build Issue - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By mtg90
  • 1 Post By Darrel Drake
post #1 of 8 Old 11-07-2019, 06:18 PM - Thread Starter
Darrel Drake's Avatar
Alright guys I need some help. I'm having an issue with the response on some Helix Dome MTMs I built, and I'm not sure what is wrong. This is my first speaker build, so I'm not very versed on trouble shooting.
I'm thinking the roll-off on the low end could be overstuffing/blockage of ports, but the 6 db rise up top has me for a loop....or is all this because I am awful at soldering?
Note -- Response is in a shoe box of a room, using a UMIK and the 9 placement response.
Any help would be greatly appreciated.
ID:	2637930   Click image for larger version
ID:	2637932   Click image for larger version
ID:	2637934   Click image for larger version
Darrel Drake is offline
post #2 of 8 Old 11-07-2019, 06:25 PM
asarose247's Avatar
Quoted: 1260 Post(s)
Liked: 1105
post all available info about the room and placement of everything
and build pics
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #3 of 8 Old 11-07-2019, 06:38 PM - Thread Starter
Room set-up is odd to say the least. They are on the long wall of a rectangular room that is ~8' x 12' and are touching the TV and about a foot off the back wall...I don't have the room to move them at the moment.
Powered by an Outlaw 976 to Mini-DSP 88A/BM to Outlaw 7000x
ID:	2637958   Click image for larger version
ID:	2637960   Click image for larger version
Last edited by Darrel Drake; 11-07-2019 at 06:41 PM. Reason: It didn't like my pictures...
post #4 of 8 Old 11-07-2019, 06:42 PM
smcmillan2's Avatar
Quoted: 965 Post(s)
Liked: 825
Is that polyfill covering the port opening inside the box? If so, that would be a problem.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 8 Old 11-07-2019, 08:58 PM
mtg90's Avatar
Quoted: 790 Post(s)
Liked: 1625
The rise above 2k certainly isn't correct. The drop below 250 could be placement/room/SBIR rather then an issue with the speaker. 1/4 wavelength at 150hz is ~22.5" so if the front of the baffles are around that distance from the wall that would be why you see a cancellation in that range.
Can you take a measurement with the mic placed about 1.5-2' in front of just one speaker centered on the tweeter? Even better pull the speaker out into the room and place it on a chair or stool to do this.
You are using the miniDSP to take the measurements correct?
mtg90 is online now
post #6 of 8 Old 11-07-2019, 09:56 PM - Thread Starter
This measurement is taken about 2' in front of the speaker--only a single pass. I did pull quite a bit of the stuffing out and try to keep it out of the way of the ports.
Yes, I am measuring with the minDSP, and this room is definitely a nightmare for room response.
I appreciate the help!!
post #7 of 8 Old 11-07-2019, 11:19 PM
mtg90's Avatar
Quoted: 790 Post(s)
Liked: 1625
Are both woofers wired in phase? You don't have the wiring to one reversed do you?
jevchance and bochoss like this.
mtg90 is online now
post #8 of 8 Old 11-08-2019, 11:29 AM - Thread Starter
That was definitely the issue. I managed to do it on both speakers
Lesson learned: Use wire with super obvious tracers.
Also, super-slow video makes it really easy to tell if something is wired out of phase.
I will update when a new set of measurements later this weekend.
bochoss likes this.
