sunfire True Subwoofer EQ - 10 inch amp power question? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-07-2019, 06:23 PM - Thread Starter
thejck's Avatar
Any idea how powerful that plate amp actually is? it says 2700 RMS but I find that hard to believe. I want to replace this with something external (pro amp) since its bad and was wondering what (power wise) I should look for.
thejck is offline
post #2 of 4 Old 11-07-2019, 06:38 PM - Thread Starter
thejck's Avatar
from the manual
Amplifi er Output
2,700 watts rms (3.3Ω impedance
Line Power Consumption:
600 watts average, at maximum continuous output. 8 watts at idle.
2,700 watts peak, time limited basis
so maybe 600 only
thejck is offline
post #3 of 4 Old 11-07-2019, 11:02 PM
Quoted: 198 Post(s)
Liked: 164
I always thought that seemed like a if hit by lightning rating.
Randy_J is offline
post #4 of 4 Old 11-08-2019, 08:21 AM
Bigus's Avatar
Quoted: 660 Post(s)
Liked: 597
Both ratings are likely correct.
It used to be common years ago (maybe still is?) for cheap car amplifiers to list peak power not RMS, which usually meant combination of not RMS, one cycle only, and even then still probably fudging a bit.
We could argue semantics but peak or burst power isn't all smoke and mirrors marketing jargon. It all depends on the time duration. Peak for one cycle not so useful. But the LabGruppen and clones have significantly higher burst power than continuous power ratings and that is useful because there is (generally) enough capacitor supply to sustain that for a meaningful period and the output devices can handle it.
Knowing the time duration it can sustain 2700W would be helpful if you're looking to match or exceed that with a replacement. When looking at prosound amps, you will find plenty that have lower continuous output ratings than their burst power. That continuous should match or better the 600W rating (if that is your goal), but the burst will have a lot of variation from brand to brand and model to model.
Bigus is online now
