DIY sound group's VOLT 6 Version 2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-08-2019, 06:18 AM - Thread Starter
Liked: 3
I'm building a set of these in the angled form for surrounds. How much poly fill material should I put in them?
morrisseysb is offline
post #2 of 10 Old 11-08-2019, 06:25 AM
Quoted: 208 Post(s)
Liked: 205
With ported enclosures a foam lining or insulation lining is better, but I use poly on my ported subs. You want a good layer of coverage on all the walls of the box, ensuring a good clean, unobstructed airway between the back of the driver and the port. On a speaker that small I probably wouldn't attempt to add any to the baffle. I find if I get the poly out of a pillow, it sort of unrolls to a single layer and that layer is what glue in with some spray mount. HTH.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is online now
post #3 of 10 Old 11-08-2019, 06:49 AM - Thread Starter
Liked: 3
Do you have a product you recommend? The last ones I built were the VOLT 10's and they are sealed...
post #4 of 10 Old 11-08-2019, 06:51 AM - Thread Starter
Liked: 3
OH never mind I see you said poly out of a pillow. Hmmm. Anything else worth looking at and what is the spray mount you are talking about?
post #5 of 10 Old 11-08-2019, 06:54 AM
Quoted: 208 Post(s)
Liked: 205
I haven't used anything except the $2.50 pillows at Walmart lol.
Spray mount is just spray glue, spray adhesive, whatever you want to call it. I like the 3M stuff.
DIY 110" AT Screen
post #6 of 10 Old 11-08-2019, 07:19 AM - Thread Starter
Liked: 3
Gotcha. I'll see what I can find. Thanks for your input I appreciate it.
post #7 of 10 Old 11-08-2019, 08:53 AM
smcmillan2's Avatar
Quoted: 955 Post(s)
Liked: 816
For ported speakers/subs I use these: https://www.target.com/p/comfy-foam-...04#lnk=sametab, making sure to keep it away from the port ends.
I attach the pieces to the box with an electric stapler.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #8 of 10 Old 11-08-2019, 09:55 AM
Erich H's Avatar
Quoted: 1888 Post(s)
Liked: 2706
If you don't have any spray adhesive just wipe some spare wood glue on the inner panels and the polyfill will stick to it.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #9 of 10 Old 11-08-2019, 07:26 PM - Thread Starter
Liked: 3
I totally forgot I have some of this in the 1/2 inch version. Would this work?
https://www.parts-express.com/sonic-...-x-24--260-520
post #10 of 10 Old 11-08-2019, 07:44 PM
smcmillan2's Avatar
Quoted: 955 Post(s)
Liked: 816
Given the size of the Volt-6 box I think that would be fine.
