Speaker wire gauge question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-08-2019, 09:39 AM - Thread Starter
ratm's Avatar
Quoted: 238 Post(s)
Liked: 104
Sorry if this has been asked a bunch. Building dual 6 ft^3 sealed boxes for Fi Car HT 3's that will be powered by an NX6000DSP (one channel each). Was going to get 12 gauge wire to connect the subs to the speakons. Am I right with 12g?
ratm is offline
post #2 of 7 Old 11-08-2019, 09:42 AM
Gamecock24's Avatar
Quoted: 380 Post(s)
Liked: 160
I’d say that’s good considering most speakon cables are 12awg as well.
Gamecock24 is offline
post #3 of 7 Old 11-08-2019, 09:45 AM
eljaycanuck's Avatar
Quoted: 1927 Post(s)
Liked: 2714
Either 12 or 14 should be fine. (FWIW: I used 14ga with my UXL-18s.)
eljaycanuck is offline
post #4 of 7 Old 11-08-2019, 10:30 AM
johnson636's Avatar
Quoted: 1299 Post(s)
Liked: 769
Yes, 12ga will do and evidence is all over the forum. Probably would serve you well to have a thread dedicated specifically for your information acquisition ahead of your build
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 7 Old 11-08-2019, 11:50 AM
lawdogx's Avatar
Quoted: 177 Post(s)
Liked: 213
Short answer would be that 12 gauge will almost certainly work well. Long winded answer is that there are numerous tables that deal with "minimum" acceptable wire gauge for a given run length and ohm load. Unless you're running low ohms for very, very long runs 12 gauge should work great.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is online now
post #6 of 7 Old 11-08-2019, 02:48 PM
Gamecock24's Avatar
Quoted: 380 Post(s)
Liked: 160
Here’s a good read on wire sizes. https://www.audioholics.com/audio-vi...er-cable-gauge
post #7 of 7 Old 11-08-2019, 08:47 PM - Thread Starter
ratm's Avatar
Quoted: 238 Post(s)
Liked: 104
This is true. I'm all over the place with my threads lately. The actual build thread is coming.
ratm is offline
