DIY outriggers for floor standing speaker? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-08-2019, 09:48 AM - Thread Starter
Liked: 0
I have the Elac Debut 2.0 F5.2. Generally it stable enough, but I'd really like to add a little more stability for when the nieces and nephews come. I've seen a site or two where people sell outriggers, but they are $100+, and that just seems unreasonable. I feel like if I could get like 4 pieces of flat metal in like 4" x 2", drill holes that would fit the screws for the spikes that come with the speaker, I could get some matching threaded bolts to bolt the metal to the speaker and either the original spikes or some better larger ones to the other ends to create the outriggers myself. My issue is that although I read up on DIY projects, I don't really do them myself. So I don't know where to get the metal to make the outriggers. Some place local like Lowes would be great, but I was hoping someone here might be able to point a newbie DIYer towards something that would work well and make my life easier in building it out. The concept seems simple enough, but as I said this isn't something I do on a regular basis.
Thoughts?
Lenny Scardino is offline
post #2 of 6 Old 11-08-2019, 04:50 PM
jujuman200's Avatar
Quoted: 158 Post(s)
Liked: 129
Originally Posted by Lenny Scardino View Post
[snip]....
Thoughts?
HD/Lowes both have the metal you may need as well as taps if you want threaded holes.....enjoy.
Juju
Wish List: 2- Red Five DEVASTATOR MINI, 2- Red Five DEVASTATOR LFE, 1- BOSS platform.
Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #3 of 6 Old 11-08-2019, 05:05 PM
smcmillan2's Avatar
Quoted: 959 Post(s)
Liked: 819
As well as Lexan/Polycarbonate sheets that are fairly easy to cut with many tools homeowners already have.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #4 of 6 Old 11-09-2019, 03:14 AM
Quoted: 27 Post(s)
Used these on my Marty Subs and they work great. Not the most attractive solution, but very sturdy. But I am also on carpeted concrete basement sloping for drainage and needed inches to level them and my TV stand.
https://www.amazon.com/Rok-Hardware-.../dp/B01N4BUE1P
Bur05XP is offline
post #5 of 6 Old 11-09-2019, 06:44 AM
Quoted: 80 Post(s)
Liked: 38
These are similar to ones i have used in the past. Ebay also has some but cant find the ones i used.
https://www.parts-express.com/dayton...SABEgKbj_D_BwE
Gold87 is offline
post #6 of 6 Old 11-09-2019, 07:44 AM - Thread Starter
Liked: 0
Thanks all for the replies, all very helpful. The parts express option that Gold87 suggested seems really close to what I was thinking and the price is very reasonable. Definitely going to consider that.
