Dayton Audio HF-4 12" or HO-4 12" in old REL Q100E enclousure? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-09-2019, 02:19 PM - Thread Starter
kujina's Avatar
Question Which Dayton Audio 12" Subwoofer (HO-4 or HF-4) in old REL Q100E enclosure?
Hi
I'm going to upgrade my old REL Q100E!
Its been used for movies and will continue to be used for movies.
Enclosure: 50 litre (1.7 ft.³), sealed box, Dimensions: 400 x 415 x 400mm
I've got a Monacor SAM-300D/Yung SD300-6 plate amp I'm going to install.
I'm wondering whether I should put in a...
Dayton Audio RSS315HF-4 12"
or
Dayton Audio RSS315HO-4 12"
Any advice appreciated, thanks!
kujina is offline
post #2 of 2 Old 11-09-2019, 02:35 PM
Liked: 2
HO. Made for smaller boxes. Is the simple answer I think. But someone will be along to model it soon I’m sure.
Maybe a possibility for a higher excursion driver to work in this box if you wanting to push loads of power and go lower but I don’t know really.
Safe bet is the HO but it won’t go massively low. Then again neither does the q100 driver so you should get a decent upgrade with the HO
trojantrow is offline
