NX6000D Settings Check - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By aron7awol
  • 1 Post By LTD02
  • 1 Post By LTD02
post #1 of 7 Old 11-12-2019, 12:17 AM - Thread Starter
TheWarrior97's Avatar
Quoted: 106 Post(s)
Hello,
Do these settings look okay for my HST-18 subwoofer?
Do I set the Peak Limiter Dial under the confirguration tab to something. Do I put 4 ohms below it and make it show 3020 watts?
I have already changed the gain on the Filter/Crossover tab to +8db to counteract the changes i made to make the HPF at 13hz.
Once all 4 of these check out, I will then do the REW program with UMIK CSL calibration to get my subwoofer graphs.
Thanks in advance.
Name:	NX DSP Configuration Tab.jpg
ID:	2639986   Click image for larger version
Name:	NX DSP Dynamic EQ Tab.jpg
ID:	2639988   Click image for larger version
Name:	NX DSP Filter&Crossover Tab.jpg
ID:	2639990   Click image for larger version
Name:	NX DSP Parametric Tab.jpg
Yamaha Aventage 3070
5.1 Surround Sound. (Klipsch RC 62II center, 4 JBL SP8II, HST-18 Vented Subwoofer 12.5)
Sony XBR-55x850b
PS4 Pro
TheWarrior97 is offline
post #2 of 7 Old 11-12-2019, 09:32 AM
Quoted: 2944 Post(s)
Liked: 12549
You can leave the limiter at 0dB, no need to limit this amp with it powering an HST-18.
LTD02 likes this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #3 of 7 Old 11-13-2019, 09:41 PM
LTD02's Avatar
Quoted: 2992 Post(s)
Liked: 3732
+1 to the comment above.
it's typically best to start with the phase on the NX6000 set to 180.
aron7awol likes this.
Listen. It's All Good.
LTD02 is offline
post #4 of 7 Old 11-14-2019, 10:38 AM
Colticus's Avatar
Quoted: 30 Post(s)
Liked: 41
What about with the um18-22?
*Representing Team AVS*
- KillerPoptart -
Halo 2 Stats
Colticus is offline
post #5 of 7 Old 11-14-2019, 01:34 PM
Liked: 12549
Personally, I'd still be comfortable running with the limiter at 0dB, but if you want to be conservative you could set it to something like -2dB.
LTD02 likes this.
post #6 of 7 Old 11-14-2019, 09:44 PM
LTD02's Avatar
Liked: 3732
if blasting music, then i'd stay under the rated driver power. for movies most folks just let 'em rip. i've not heard of a um18 being cooked on movie content, though there have been a couple of high spl music casualties.
LTD02 is offline
post #7 of 7 Old 11-16-2019, 12:39 AM - Thread Starter
Quoted: 106 Post(s)
Thank you both for the replies. Would you mind checking out my thread to see my results with REW and if its all good to go?
thank you
https://www.avsforum.com/forum/155-d...l#post58813624
Sony XBR-55x850b
PS4 Pro
