Neutrik connector drill size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-16-2019, 08:38 AM - Thread Starter
ratm's Avatar
Quoted: 274 Post(s)
Liked: 113
Please forgive this redundant post, but I can’t seem to find it, but what size do I drill the back of my box for my neutrik connector?
ratm is offline
post #2 of 11 Old 11-16-2019, 08:52 AM
smcmillan2's Avatar
Quoted: 1026 Post(s)
Liked: 866
15/16" is what I use.
ETA: According to the drawings here https://www.neutrik.com/en/product/nl4mp a 24mm hole would work as well.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #3 of 11 Old 11-16-2019, 09:12 AM - Thread Starter
ratm's Avatar
Quoted: 274 Post(s)
Liked: 113
Thanks man!
ratm is offline
post #4 of 11 Old 11-16-2019, 09:25 AM
N8DOGG's Avatar
Quoted: 1391 Post(s)
Liked: 1637
Anything a touch bigger than spec can easily fit with a wrap or 2 of electrical tape around the base of the plug. Makes it snug in the hole.... Just a fyi if you don't have the exact size needed.
N8DOGG is offline
post #5 of 11 Old 11-16-2019, 11:34 AM - Thread Starter
ratm's Avatar
Quoted: 274 Post(s)
Liked: 113
I ended up going to get 15/16 hole bit. I have enough little things going wrong with this build, I didnt want another thing.
ratm is offline
post #6 of 11 Old 11-18-2019, 02:03 PM
Quoted: 234 Post(s)
Liked: 221
Pretty sure I used a 1" spade bit with no problems, but the tighter the better.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #7 of 11 Old 11-18-2019, 02:11 PM
dlinsley's Avatar
Quoted: 581 Post(s)
Liked: 451
I bought a 24mm bit, but I wouldn't recommend it for continued use. It got dull quickly when cutting just three holes (one in each of the LCR) in the baltic birch of the original DIYSG Titan 615LX flat packs, but not dull that I couldn't use it on my BOSS platforms too.
https://www.amazon.com/gp/product/B00CCBHR7E
dlinsley is online now
post #8 of 11 Old 11-19-2019, 06:35 AM
JohnDean's Avatar
Quoted: 566 Post(s)
Liked: 262
That's an interesting looking Forstner bit. I've been using the same 2 bits for a while now. One for counter-sink and one for the through hole. More like below, but I have no experience with the differences.
https://www.amazon.com/MLCS-9212H-16...6&s=hi&sr=1-12
JohnDean is online now
post #9 of 11 Old 11-19-2019, 07:32 AM - Thread Starter
ratm's Avatar
Quoted: 274 Post(s)
Liked: 113
Do you use the counter-sink bit so the connector sits flush with your cabinet?
ratm is offline
post #10 of 11 Old 11-19-2019, 09:42 AM
smcmillan2's Avatar
Liked: 866
They both get the same job accomplished. The one you linked is HSS vs. the carbide-tipped version dlinsley is using.
Typically the carbide bits stay sharper longer, but that doesn't seem to be dlinsley's experience with the one he linked to.
post #11 of 11 Old 11-23-2019, 04:18 AM
Augerhandle's Avatar
Liked: 1349
https://www.avsforum.com/forum/155-d...l#post58861042
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
