Modeled stuffing in WinISD (I think). Thoughts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-16-2019, 05:36 PM - Thread Starter
ratm's Avatar
Quoted: 259 Post(s)
Liked: 108
In my build post, I talk about some of the snafu's I've encountered during the build, specifically the addition of polyfill (dual 6 cubic foot sealed boxes, with about 5.75 internal volume). I started to think if I needed it in the first place, as more than a few said I didnt. I have read countless threads about using fill in the first place (Ricci's article was really good). Anyways, I modeled my driver (FiCar Audio HT-3) to see the difference if I added fill or pillows verses nothing.
Red
No fill
5.75 cubic foot
Fsc - 34.74 hz
Qtc - 0.689
109 db @ 20 hz
Blue
Fill to get to about 5.33 cubic foot (so a little less than 1/2 pound)
Fsc - 35.55 hz
Qtc - .703
107.8 db @ 20 hz
I am unsure about what the impedance model means or how to read it. I am leaning towards not using any fill at all, or possibly one small pillow. What say any of you?
ID:	2641990   Click image for larger version
ratm is offline
post #2 of 7 Old 11-16-2019, 05:45 PM
LTD02's Avatar
Quoted: 2992 Post(s)
Liked: 3732
if using with standard 80hz crossover, i don't think your enclosures are large enough to have internal resonances in that range, so do whatever makes you feel best. :-) seriously, if you feel they will sound better with stuffing do that. if not, don't.
Listen. It's All Good.
LTD02 is offline
post #3 of 7 Old 11-16-2019, 05:55 PM - Thread Starter
ratm's Avatar
Quoted: 259 Post(s)
Liked: 108
if using with standard 80hz crossover, i don't think your enclosures are large enough to have internal resonances in that range, so do whatever makes you feel best. 🙂 seriously, if you feel they will sound better with stuffing do that. if not, don't.
Are you talking about the 80hz crossover that I’ve set on my AVR?
ratm is offline
post #4 of 7 Old 11-16-2019, 06:00 PM
LTD02's Avatar
Liked: 3732
yes, if you were going to run them up to something like 140 or 160Hz, then i'd need to take a more careful look. for 80hz, no stuffing is needed in a box your size if it is roughly square (not a long tube type enclosure).
LTD02 is offline
post #5 of 7 Old 11-16-2019, 06:12 PM - Thread Starter
ratm's Avatar
Quoted: 259 Post(s)
Liked: 108
Are you talking about the 80hz crossover that I’️ve set on my AVR?
Nope, all my speakers are set to small, so it’s at 80hz. Thanks John for all of your help.
ratm is offline
post #6 of 7 Old 11-17-2019, 04:14 AM
Quoted: 13 Post(s)
Liked: 6
Red
No fill
5.75 cubic foot
Fsc - 34.74 hz
Qtc - 0.689
109 db @ 20 hz
Blue
Fsc - 35.55 hz
Qtc - .703
107.8 db @ 20 hz
Made a small calculation in another program that I know corresponds to 90% it shows measurements that have been made.
look at viso% which shows how many% filling there is in the box.
And how it changes on Effective vb.
And Q in closed box.
ID:	2642092   Click image for larger version
Lars Bergvall is offline
post #7 of 7 Old 11-23-2019, 04:18 AM
Augerhandle's Avatar
Quoted: 1331 Post(s)
Liked: 1307
https://www.avsforum.com/forum/155-d...l#post58861042
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
