TSCVR15 sub, 775watt wired at 2ohm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-17-2019, 05:05 PM - Thread Starter
John O'Connell's Avatar
Liked: 0
hey could the TSCVR15 handle 775watt at 2ohms if wired down to a singal 2ohm config the rms per coil is 250watts
combind to 500watts rms ,775 watts is 275 over total but is only 112.5watts over per coil
would this be ok long term use an not kill the sub or the amp the amp is the crown 1502
John O'Connell is offline
post #2 of 6 Old 11-17-2019, 05:34 PM
jujuman200's Avatar
Quoted: 189 Post(s)
Liked: 172
So..... what part of 775 is MORE than 500 are you not getting?? If the MAX is 500, what do you think will happen with 775? I'm curious....
Juju
Wish List: 1- Red Five DEVASTATOR MINI, 2- Red Five DEVASTATOR LFE, 1- BOSS platform.
Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #3 of 6 Old 11-17-2019, 07:36 PM
Chris Popovich's Avatar
Quoted: 236 Post(s)
Liked: 195
Watch the volume and sure.... but careful or you'll let the smoke out.
Chris Popovich is online now
post #4 of 6 Old 11-18-2019, 08:05 AM - Thread Starter
Liked: 0
Juju
iv read an seen some reviews about some speakers an subs that can an benifit from some watts over between rms an peak amount
what im not getting is if this sub is one of those
post #5 of 6 Old 11-18-2019, 08:23 AM
a77cj7's Avatar
Quoted: 333 Post(s)
Liked: 270
Any speaker can benefit from amplifier headroom IMO. Easier to avoid clipping and THD issues when you aren’t pushing the amp to its limits. The problem comes when you try to push the driver too far and exceed either mechanical or thermal limits. Which results in either the mechanical damage, or letting the magic smoke out. Either way, you now have a large paperweight.
Mechanical limits are pretty easy to model, thermal limits are much harder to determine. The question is usually if the manufacturer rated wattage due to mechanical limits in recommend enclosure, or thermal limits. Also, how much of a thermal safety factor, and whether its rated for clean power or assumes clipping.
Chris
a77cj7 is online now
post #6 of 6 Old 11-18-2019, 08:30 AM
jujuman200's Avatar
Quoted: 189 Post(s)
Liked: 172
If you plan on feeding it continuously above RMS..... let us know how many wishes you get.....
Juju
