AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   Hardwood Blocks behind baffle noob question (https://www.avsforum.com/forum/155-diy-speakers-subs/3103396-hardwood-blocks-behind-baffle-noob-question.html)
ratm 11-19-2019 12:09 PM
What is the general consensus on the type of hardwood to use for blocks glued to my baffle before I screw in my drivers? I am using 3/4 MDF now.
johnson636 11-19-2019 12:15 PM
Your build thread look like you're using mdf for your enclosures, why wouldn't you just use the mdf:confused:
ratm 11-19-2019 12:18 PM
Another noob question here, but is MDF considered hardwood? I would totally use that if that would be ok.
a77cj7 11-19-2019 12:19 PM
Any type will work. Plywood is fine too, as is pine (though it can split).
Any decent wood will hold the screw many times better than mdf.
Chris
a77cj7 11-19-2019 12:20 PM
Lol, no, mdf isnt hardwood. A mdf block is better than nothing, but worse than pretty much any other option.
Chris
eljaycanuck 11-19-2019 12:21 PM
Dunno about consensus, but IIRC I cut up a ~3/4" x 2" x 4' strip of birch hardwood (from HomeDepot) and it worked very well.
Trimlock 11-19-2019 12:27 PM
MDF is an engineered product, uses wood dust but isn't called wood. Paper is made from wood as well.
jevchance 11-19-2019 12:47 PM
But, on the hardness scale, it'd be considered a very soft wood.
asarose247 11-19-2019 02:05 PM
3 Attachment(s)
the birch hardwood suggestion will be quite adequate
predrill undersized, shoot a bit of WD-40 into the hole and work the screws in about 3/4's of the way
Kregs screws or button head hex-drive screws will eliminate any cam-out issues
i had oak available- bradded, PL3'd and clamped
ratm 11-20-2019 05:32 AM
2 questions.
1. Why WD-40?
2. Could I use wood glue and not PL3? I have to think titebond 3 would work fine.
a77cj7 11-20-2019 06:48 AM
Originally Posted by ratm (Post 58847394)
2 questions.
1. Why WD-40?
Titebond is fine.
WD would reduce wall friction on the screw, but not something I’ve ever tried.
Chris
eljaycanuck 11-20-2019 08:34 AM
… 2. Could I use wood glue …
I used wood glue, then drilled a small (3/32") pilot hole before inserting the screws and had no problems. :)
Zarkoff500 11-20-2019 08:37 AM
I've done the same and sometimes shoot a 1" to 1.25" brad to hold the block while it dries so I don't have to clamp/clamps aren't in my way etc.
ratm 11-20-2019 07:28 PM
Once again, my FD friends come through. One of the guys at my station had some 3/4 inch Oak lying around. So I'll be gluing that to my MDF and then using 2 inch wood screws.
jevchance 11-21-2019 08:25 AM
WD40 is a good idea. Predrilling is a must. Blocks that small will split easily.
Augerhandle 11-23-2019 04:17 AM
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
