Notiiced a sound issue with my Cobalt's - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By smcmillan2
post #1 of 22 Old 11-19-2019, 07:26 PM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
I am running a DIY Soundgroup Cobalt LCR set up. I am powering them with a Denon X3300/XPA 3 combo. The center channel is amazing. Super dynamic, crystal clear, and never gets harsh sounding. When I set the Denon to Pure (which I think is just straight 2 channel), and listened to some music. When I did, the L and R sounded extremely dull and almost zero dynamics compared to the Center. During movies or anything else 5.1, the L and R are fine. AFAIK, I set them up correctly, following the directions from DIY exactly.
Is it something with my settings? I have all speakers set to small, the crossovers at 80. Could it be simply because the center is a MTM configuration with dual 8 inch woofers? Truth be told, I almost never listen to two channel music. It was just something I wanted to try out.
ratm is offline
post #2 of 22 Old 11-19-2019, 07:41 PM
smcmillan2's Avatar
Quoted: 987 Post(s)
Liked: 836
I'm almost positive Pure Direct bypasses Audyssey's corrections. What you are hearing is how your speakers really sound in your room (with existing placement, treatments, etc.).
In other words, your room is at fault (as are most).
John Booty likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #3 of 22 Old 11-20-2019, 03:44 AM
bear123's Avatar
Quoted: 2861 Post(s)
Liked: 4376
You can check the simple and obvious and make sure the tweeters are working. Otherwise, it could be that Audysey is boosting the top end *a lot* as it will try to make the response flat....whereas the native in room response of speakers designed with a flat anechoic response will be gradually declining...so if Audysey is boosting the top end 5-10 dB, it will sound flat when you turn it off.
bear123 is offline
post #4 of 22 Old 11-20-2019, 05:22 AM
corradizo's Avatar
Quoted: 1551 Post(s)
Liked: 1612
corradizo is offline
post #5 of 22 Old 11-20-2019, 05:25 AM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
Originally Posted by corradizo View Post
Doesn’t pure turn off the subs?
I'm not sure. But I am sub-less right now so it's moot.
ratm is offline
post #6 of 22 Old 11-20-2019, 05:27 AM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
They are. Like I said, I rarely listen to 2 channel anything. Could it be too much stuffing in the boxes?
ratm is offline
post #7 of 22 Old 11-20-2019, 06:49 AM
jcmccorm's Avatar
Quoted: 629 Post(s)
Liked: 475
Try listening to two-channel *without* putting it in Pure mode (which disables room correction). In other words, see how the LR sound with room correction enabled.
jcmccorm is offline
post #8 of 22 Old 11-20-2019, 06:52 AM
a77cj7's Avatar
Quoted: 337 Post(s)
Liked: 277
Try swapping the center with L or R. That will demonstrate whether the speaker or the settings sound different.
Chris
a77cj7 is offline
post #9 of 22 Old 11-20-2019, 10:57 AM
notfastenough's Avatar
Quoted: 198 Post(s)
Liked: 225
I'm pretty sure this is by pressing the Music button on the Denon remote until you see "Stereo" on the display.
http://manuals.denon.com/AVRX3300W/E...SYyriqsmlp.php
notfastenough is offline
post #10 of 22 Old 11-20-2019, 12:07 PM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
Chris
I will try all of that. Thank you!
ratm is offline
post #11 of 22 Old 11-20-2019, 12:45 PM
smcmillan2's Avatar
Quoted: 987 Post(s)
Liked: 836
Or just leave it on "Auto" and let it decode based on the source. This way, when I play music through my MythTV box it automatically goes to Stereo, watch a movie and DTS (or other) shows up, etc.
Of course, that depends on how the source is set for output...
notfastenough likes this.
post #12 of 22 Old 11-20-2019, 07:25 PM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
So I tried it in "stereo" mode and it was a huge difference. AKA, my room sucks. Once I get my subs built and hooked up, I will have to to some serious work with REW.
ratm is offline
post #13 of 22 Old 11-21-2019, 04:08 PM
bear123's Avatar
Liked: 4376
So as I suspected, it sounds like Audysey is boosting the upper frequencies *a lot*. I think this is common with Audysey as it will boost the FR at MLP to make it flat, whereas most optimally designed speakers will have a gradually declining response. If you get used to an incredibly boosted Audysey top end, turning it off will sound dull in comparison.
bear123 is offline
post #14 of 22 Old 11-22-2019, 04:14 AM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
Makes perfect sense. Now I need to figure out where my room sucks the most and add a few treatments.
ratm is offline
post #15 of 22 Old 11-22-2019, 12:50 PM
trilkb's Avatar
Quoted: 679 Post(s)
Liked: 356
If it hasnt been answered, hes also hearing the direct source as well. Bad source +no EQ = Not great sound.
To be honest I wouldnt even mess with pure direct. Also theres another trick but you have to go into receiver settings and select 2.1. Some give the option of phantom center, some just defualt to phantom center. I run this mode in my living room since my center had to be in a cubby and sounds crazy bad and boomy.
I dont know if denon saves the audyssey calibration for each mode, like say if you flip from 7.1 to 5.1 and 2.0 on another source, or 7.1 to 2.1. I dont know how that all works, if you need to recalibrate for each setting?
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #16 of 22 Old 11-23-2019, 04:16 AM
Augerhandle's Avatar
Quoted: 1342 Post(s)
Liked: 1314
https://www.avsforum.com/forum/155-d...l#post58861042
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #17 of 22 Old 11-24-2019, 05:26 AM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
Originally Posted by Augerhandle View Post
This doesn't count. It's not a sub related question.
ratm is offline
post #18 of 22 Old 11-24-2019, 08:06 AM
johnson636's Avatar
Quoted: 1317 Post(s)
Liked: 790
As I understand it, that thread is not limited to sub questions.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #19 of 22 Old 11-24-2019, 12:46 PM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
That’s debatable
ratm is offline
post #20 of 22 Old 11-24-2019, 02:04 PM
Liked: 1314
The ratm thread is in the DIY Speakers and Subwoofers section. Cobalts are DIY speakers, so yeah, those questions count. Besides, if the Mods allowed you to chat about Martial Arts, I guess anything can be discussed there.
post #21 of 22 Old 11-24-2019, 02:05 PM - Thread Starter
ratm's Avatar
Quoted: 261 Post(s)
Liked: 109
damn
ratm is offline
post #22 of 22 Old 11-24-2019, 02:32 PM
Liked: 1314
I answered in the ratm Q & A thread.
