Any guess about new DIYSG speakers? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #31 of 41 Old 12-28-2019, 10:41 AM
Zarkoff500's Avatar
Quoted: 239 Post(s)
Liked: 183
Those turned out great.
Zarkoff500 is offline
post #32 of 41 Old 01-07-2020, 07:12 AM
Quoted: 18 Post(s)
Liked: 6
Originally Posted by Prana Ferox View Post
I have one of the Kuda kits put together.
Do you remember if the depth of your side rabbit joints was oversized compared to the depth of the side braces? Mine has a large gap but maybe that's normal.
Boschpants is offline
post #33 of 41 Old 01-07-2020, 07:52 AM
Erich H's Avatar
Quoted: 1917 Post(s)
Liked: 2764
The braces were shortened a little so people could install a plate amp between the braces.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #34 of 41 Old 01-07-2020, 07:54 AM
Quoted: 18 Post(s)
Liked: 6
Makes sense. Thanks!
post #35 of 41 Old 01-07-2020, 09:50 AM
trilkb's Avatar
Quoted: 705 Post(s)
Liked: 370
That Kuda Enclosure....
I wonder what 2 jbl 12's would do in it. One on the back side between the braces as well as the one in front?
Good idea? Bad idea?
- 6 x Boston Acoustic CR6 Frankencenter, Boston Acoustic CR8 L/R, 4 jbl 8330a surr , 8 x jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #36 of 41 Old 01-07-2020, 10:22 AM
Quoted: 18 Post(s)
Liked: 6
Do you recommend lining the walls at all? If so, should the rear wall be lined as well?
Ian
post #37 of 41 Old 01-08-2020, 06:54 AM
Quoted: 32 Post(s)
Ian
I lined mine with denim insulation and it ended up being more constrained than it should be around the port mouths - not quite as bad as the pic looks but not optimal. If I did it again I'd avoid at least the lower half of the rear wall.
I didn't model adding another 12 to this cab but I would suspect you'd run into trouble with port velocity pretty quickly.
Prana Ferox is offline
post #38 of 41 Old 01-08-2020, 10:03 AM
Erich H's Avatar
Liked: 2764
I have one of the Kuda kits put together. Like all of Erich's kits it went together extremely quickly and easily. Right now it's just waiting on sanding before finishing. I have a gel stain + amber poly method that's worked well on BB before.
Some minor notes:
- I'm using an Infinity 1260w because I already have it, but the Dayton RSS315HF models well (exactly the same as the Infinity). An Ultimax in this cabinet could get a few more dB on the low end (with more watts) but would probably overwhelm the ports.
- Erich says it's tuned for 20hz. It comes with stock-length Precision Ports, i.e. a 12" connector for, according to PP, 18" effective length and a little over 22hz tune. WinISD seems to agree, but WinISD tends to be pessimistic on port length. That, of course, is before any cabinet stuffing. I've lined mine with denim insulation and will do a bead test once actually assembled. 2x3" ports model to 27m/s port velocity at power levels pushing the Infinity or RSS315HF to excursion limits, so I'm hoping the PP magic works. (The Ultimax model is hitting 40m/s which is way too much.)
The port length calculators do not take into account where the port is in the cabinet. Closer to the walls and/or closer to the back panel will lower the tuning versus what the calculators give. A very good example of this is with the VBSS cabinet where two 4" ports tune the 6cuft cabinet at 20hz due to placement of the ports.
Port velocity calculators do not account for the huge flares on the Precision Ports. There are well known companies using single 4" Precision Ports with Lab-15's and the two 3" ports in the Kuda-12 are bigger than the single 4" port. The Ultimax will have no issues and the port size is what Parts Express recommends.
One of the designers and I worked on the ported 18" cabinet that uses three 4" ports. Tuning ended up being 4-5hz lower than what the calculators figured. We maxed out an 18" Stereo Integrity HST-18 with it's 38+mm X-max and it had no port noise issues. Pretty sure we took videos of it and will upload them if I can find them.
Erich H is offline
post #39 of 41 Old 01-09-2020, 06:35 PM
Liked: 0
Just wondering, will the ported Kuda 18 kits be in stock soon?
ssg99si is offline
post #40 of 41 Old 01-10-2020, 08:10 AM
Erich H's Avatar
Liked: 2764
I've had the flat packs here for a while but it took a little while to figure out packaging and shipping on the Kuda 18's due to their weight. The custom shipping boxes were ordered and should be here next week. The cabinet will have to be shipped in 2 boxes.
Erich H is offline
post #41 of 41 Old 01-10-2020, 09:58 PM
Quoted: 32 Post(s)
Erich, thanks for the further info in post #38 . I edited my earlier post to avoid giving bad advice.
I tried bead testing mine now that it's finished, my test amp doesn't have the power for cone movement to really dial in, but it's right around 20hz.
