It’s going Down… Operation SledgeHammer—Quad DEVASTATOR BUILD & some other things… - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 56Likes
post #61 of 73 Old 12-02-2019, 07:02 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
Originally Posted by Red Five View Post
Did more stuff happen with the Devastators over the last few days?
Nothing interesting..... just paint prep. I will be posting the measurements that you asked for the end of the week... work is crazy this week...may start building the 2nd LFE on Sunday.
Juju
Red Five likes this.
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #62 of 73 Old 12-08-2019, 11:29 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
@Red Five
Ok RF;
the moment that you have been waiting for......
I setup the system to play PINK NOISE at 75Db....close mic is about 1 foot from the mouth of the Mini then I shut off all the speakers except the subs.
The first sweep I did was withe the iNuke 3k reset to factory spec out of the box..... no HPF, NO EQ. Just the initial setting which is the PLAIN.jpg which is the maroon one. This is just the MINI 460HO and nothing else.
Second is the settings I use for the Mini, which is the green one... this is also just the Mini. The file name is Plain + Dev-1.jpg
The last one is all the subs measured from MLP.... same volume which is the blue one. That response is no where near flat..... but I'm also NOT trying to be flat... I think that ruler flat response sounds too dry and lifeless for me.....YMMV...
I also have a funky room to work with.... the main part is 17 X 21... the middle of the right wall facing the screen opens to a 7 foot wide hall way that is 8 feet long and turn to the right and becomes a 4 foot wide hall to the rest of the apt. I would say that right now I have about 35% of the walls/ceiling treated with Diff/Ab.... soon to add more.
Despite the looks of the charts, It sounds great in here and the 460HO in a Mini works well..... some of the best sounding speakers measure like a$$ so there's that....
UPDATE::
Looks like this build will be stopping at 2 Devs for right now... the LFE and a Mini w/460HO. I took the second LaVoce 21" and retrofitted one of my Full Marty boxes.... so now I have an 18" Full Marty & a 21" Full Marty. They play really nicely with the Devs in my space. Since they are all tuned in the 17-20 Hz range, the integration was fairly straight forward.
In my experimentation, I have found the Devs to be a little too laid back from a tone perspective for the genres of music that I like.... but for movies, the Devs ROCK. They hit those low notes with ultra clean authority. I managed to find an AWESOME medium ground with the ported/Dev combo in my space.....
I would NOT hesitate to build the Devs again, they are great sounding boxes that will bring a smile to your face every time you fire them up.....
Juju
Name:	plain + Dev-1.jpg
ID:	2651430   Click image for larger version
ID:	2651432   Click image for larger version
filtor1 and Red Five like this.
post #63 of 73 Old 12-09-2019, 06:39 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
BOSS Platform
Hello All;
I have started and finished my BOSS platform and I can say that the hype is REAL..... they feel very natural when used with your far field subs [all of mine are far field]. They give a nice addition to the impact of the bass without feeling gimmicky or mechanical. I used one sheet of 3/4 ply but I doubled up on the front and rear edges to give the platform more rigidity. USE the isolators that are recommended in the thread.... you will be glad you did. I'm very happy that I built them and recommend that you do as well.....
ID:	2651794   Click image for larger version
Name:	DIY COUCH ON DIY BOSS.jpg
ID:	2651796   Click image for larger version
ID:	2651798   Click image for larger version
Name:	BOSS STARTED.jpg
ID:	2651800   Click image for larger version
Name:	BOSS BUILT.jpg
OJ Bartley, Red Five and a77cj7 like this.
post #64 of 73 Old 12-09-2019, 08:22 PM
Red Five's Avatar
Quoted: 958 Post(s)
Liked: 773
Are you sure you can't do four Devs still? I just finished up the Micros
a77cj7 likes this.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is offline
post #65 of 73 Old 12-09-2019, 08:25 PM
a77cj7's Avatar
Quoted: 440 Post(s)
Liked: 377
And the BMD Omega, that seems apartment-worthy.
Chris
jujuman200 likes this.
a77cj7 is online now
post #66 of 73 Old 12-09-2019, 08:28 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
Four... nope.... maybe 3... but if do, I will build a second Mini..
Juju
post #67 of 73 Old 12-09-2019, 09:06 PM
Quoted: 1129 Post(s)
Liked: 331
Originally Posted by jujuman200 View Post
Hello All;
Yep. BOSS is not joke. Also, I have used them with devs only 60" away from MLP and they still work amazing. I run them with CO @20hz LR24. You can even go up to 25Hz but no more. Also have a LowShelf 10dB at 20Hz with Q=1. Gain you can set to your liking. With this setting, BOSS brings very nice wobbly effect. Anything above 25-30Hz and it becomes too much. One of the best scene I can recommend you to try out BOSS is from Tron the motor bike scene. This whole scene has tons of low bass and you should get wobbly effects from BOSS (not shaky). Too much shake will take away the bass sound as well because you'll be shaking so much that you won't hear as much bass. One way to test is to first play without BOSS and then with BOSS and then again without BOSS to see if BOSS shake is taking any hearing away. Having low CO like around 20-25Hz brings tons of wobbles without taking the bass sound away. Good luck.
harrisu is offline
post #68 of 73 Old 12-09-2019, 09:36 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
Thank you for your input... I will try your suggestions..
Juju
post #69 of 73 Old 12-13-2019, 04:48 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
Cool Made the LFE pretty.....
@Red Five
Hello All;
just an update..... the DEVs rock and I have taken the time to put some trim on the LFE so that it looks more like furniture.... and added the final touch
Juju
ID:	2653632   Click image for larger version
Name:	LFE CORNER.jpg
ID:	2653634   Click image for larger version
post #70 of 73 Old 12-13-2019, 09:03 PM
Red Five's Avatar
Quoted: 958 Post(s)
Liked: 773
Looking good!
Red Five is offline
post #71 of 73 Old 12-18-2019, 08:38 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
Center Channel & DIY RPG BAD PANELS
So the quest continues.....
I recently finished my center channel which is 2way in a 1 cuft box tuned to 50Hz. Since I changed out one of the midbass for the Faitals, the midrange just opened up and is much more crisp and clear. The Peerless[buyout sale] and the Faital are wired in series and sound awesome in this configuration.
NEXT::
I just took on a project of INSANITY..... DIY RPG BAD Panels.....a hole drilling bonanza.....
If you have a drilling fetish..... this is the project for you. The 48x60 panel has well over 2K holes
I manages to drill 1- 48x60 and 2- 30x30 panels in 3 days...basically it took 3 days to do the 48x60 as I had the panels stacked to drill multiple panels at once. I have one more big panel to drill out for the rear of the room.... I MAY start that next week. Frame construction for the current panels will begin tomorrow...
UPDATE::
Here is the first 30x30 panel almost complete... just need to paint the trim..... It is filled with 4" of ROXUL Safe 'N' Sound edge to edge. I still have not decided if I want to cover the screw heads or not......
UPDATE::
All the panels are finished... it was a labor of love but they add a great dimension to my space... it opens up the space and it sounds like a MUCH bigger room.... WELL worth the effort.
Onward....
Juju
Name:	Completed center.jpg
ID:	2655866   Click image for larger version
Name:	Almost there.jpg
ID:	2655868   Click image for larger version
Name:	48x60 BAD PANEL.jpg
ID:	2655870   Click image for larger version
Name:	30x30 BAD PANEL.jpg
ID:	2655872   Click image for larger version
Name:	Bad Panel installed.jpg
kevings, OJ Bartley and Red Five like this.
post #72 of 73 Old 12-22-2019, 05:29 PM
OJ Bartley's Avatar
Quoted: 553 Post(s)
Liked: 645
Juju, the panel looks great! That is a ton of drilling. I've contemplated these but every time I read how long the drilling actually takes, I get scared off again. Lol.
But the Important thing... How does it SOUND?
Sent from my SM-A520W using Tapatalk
OJ Bartley is offline
post #73 of 73 Old 12-22-2019, 06:05 PM - Thread Starter
jujuman200's Avatar
Quoted: 212 Post(s)
Liked: 204
@OJ Bartley
Hey OJ;
YES the panels are a PITA to build.... the 48X60 took me 3 days with over 2K holes.... yes on the first day you will have to soak your wrist in a warm salt bath....
BUT..... the way it opens up the space and makes the midrange and upper end come into focus makes it well worth the effort. The sound is to kill for....NOW I understand why they are so expensive and popular....
OJ..... DO IT!!
I don't know anyone who has built / purchased them that doesn't like their results....
As with anything YMMV... but I'm pretty sure that these are a solid winner....
I got them printed here https://blueprintsprinting.com/ FULL SIZE for a reasonable price.... use PLAIN PAPER....Just upload the file as is and you will be fine.... FYI.... the dots WILL be larger than 1/2" on the print but when you use a 1/2" drill bit placed on the crosshair it comes out correctly....
P.S I also added the plans for the diffusor you see to the right at the first reflection point.... those are an easy-peasy build.....hope that helps.
The black BAD panels 30x30 are behind my mains on the screen wall.....
Juju
ID:	2657584   Click image for larger version
ID:	2657586   Click image for larger version
