AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   It’s going Down… Operation SledgeHammer—Quad DEVASTATOR BUILD & some other things… (https://www.avsforum.com/forum/155-diy-speakers-subs/3103776-ita-s-going-downa-operation-sledgehammera-quad-devastator-build-some-other-thingsa.html)
jujuman200 11-20-2019 09:12 PM
It’s going Down… Operation SledgeHammer—Tri DEVASTATOR BUILD & some other things…
5 Attachment(s)
Correction/Update::
As of 12/09/2019... Looks like this build will be stopping at 2 Devs for right now... the LFE and a Mini w/460HO. I took the second LaVoce 21" and retrofitted one of my Full Marty boxes.... so now I have an 18" Full Marty & a 21" Full Marty. They play really nicely with the Devs in my space. Since they are all tuned in the 17-20 Hz range, the integration was fairly straight forward.
In my experimentation, I have found the Devs to be a little too laid back from a tone perspective for the genres of music that I like.... but for movies, the Devs ROCK. They hit those low notes with ultra clean authority. I managed to find an AWESOME medium ground with the ported/Dev combo in my space.....
I would NOT hesitate to build the Devs again, they are great sounding boxes that will bring a smile to your face every time you fire them up.....
As of 11/24/2019.... I will be building 3 Devastators and not 4 as per the original plan..... They will consist of 2 LFE and 1 Mini due to unforeseen circumstances that require that extra space..... all else is the same.....
@Red Five
First off:
I would like to thank the main dudes responsible for this build LTD02 & Red Five.
LTD02 created the initial design and Red Five took it and RAN with it….. Thank you both for your support to our community…. LTD02 & Red Five have been a GREAT help to me on my bass journey….
On to the business at hand:
Currently I have 2 Full Martys with the RSS460HO which are AWESOME in their own right in my space.
The room dimensions are 17 x 22 x 8 with old school plaster walls and suspended floor….
I’m just looking to take my system up to the next level in WOW factor…. Not that I NEED more output…. I would just like it to be more “in your face”, mid bass that feels like body shots.. etc. If you are here, you KNOW what I’m talking about….
So, I will be building 2-- Devastator LFE, 2-- Devastator MINI, a BOSS platform, a VBSS for the center channel & new rear surrounds. The LFE will have the Lavoce 21”, the MINI will get the RSS460HO & the BOSS gets 4 JBL 12”.
The new SEOS surrounds will have the same mid-bass drivers as my mains and be 2way (mid-bass drivers are in series). My mains are 3way and consist of a mid/high top and a VBSS 31Hz for bass section. The center channel will end up being a 3way (to match the mains) with the same drivers as the mains as well + a VBSS on the bottom.
So far I have managed to build only 1 surround from the wood I had on hand at the moment…. So here is a sneak preview….
I’m picking up the wood for this major undertaking on Friday….. wish me luck….
P.S That is an older pic of my mains before I changed 1 of the mids..... same design though....
Juju
jorisdriesen 11-20-2019 11:59 PM
:eek: subscribed
Jefro6996 11-21-2019 04:28 AM
Can't wait to see the results on the LFE version. I don't think I've seen any built yet, but plan on doing 4 myself next year.
Sent from my SM-N950U using Tapatalk
jevchance 11-21-2019 08:13 AM
I'm intrigued by those mains. Looking forward to the build!
Red Five 11-21-2019 08:23 AM
1 Attachment(s)
Juju, have you looked at the new Mini for the 21s? This is the RSS460 vs the 214.50. This also begs the question do I design an LFE Mini? The 460HO would most likely enjoy added rear chamber volume.... box would be 40x25.5x42, basically 8" chopped off the top of the LFE.
https://www.avsforum.com/forum/attac...1&d=1574349761
jujuman200 11-21-2019 12:17 PM
That Mini 21" looks awesome...... Yes please... a LFE Mini would be great...
Juju
domdomdom01 11-21-2019 12:19 PM
Jesus christ, dude
jujuman200 11-21-2019 12:51 PM
1 Attachment(s)
@jevchance
This is what the mains look like now…..
CD: B&C DE360 1" Polymer Horn Driver 8 Ohm 2-Bolt [EXCELLENT DRIVER]
Horn: RCF H100 90 x 75
Upper mid-bass driver: FaitalPRO 6FE200 6" Professional Midrange Speaker 4 Ohm [CRYSTAL CLEAR & CLEAN]
Lower mid-bass driver: Peerless 835004 SDS 6-1/2" Woofer 4 Ohm [NO LONGER AVAILABLE]
Bass Section: 31Hz VBSS
Crossover: Dayton Audio XO3W-375/3K 3-Way Speaker Crossover 375/3,000 Hz
The mid/high box is 1 Cu Ft sealed
This set of drivers sound GREAT together….. one of my best builds….. hits reference, no problem.
I changed out one of the mid-bass to get better vocal clarity and now I have it in spades…..
And depending on the mix.... they can "disappear" in the room like a mini monitor....:D
Juju
BassThatHz 11-21-2019 06:16 PM
Will the SEOS's be mounted sideways?
My only recommendation would be to replace the Dayton XO with custom, as I highly doubt it has optimized inductance and FR as-is for the previous or new drivers.
Other than that, it looks like a fun project.
jujuman200 11-21-2019 06:30 PM
No.... the SEOS will not be sideways.... the 2nd pic is correct top to bottom.... the other pic came out sideways....
I agree with you on the XO..... looking to go active after this build is done... I have a few old school Crown Macrotech 2400 sitting around doing nothing
Juju
AudyoVidyo 11-21-2019 10:36 PM
Awesome :cool:
jevchance 11-22-2019 07:07 AM
Originally Posted by jujuman200 (Post 58854136)
@jevchance
Juju
They're also great looking. Nice work.
Do you have specs for the crossover?
jujuman200 11-22-2019 07:56 AM
Thank you Sir.....
Crossover info....https://www.parts-express.com/dayton...00-hz--260-150
Juju
elusiveis 11-22-2019 08:23 AM
This is going to be awesome! Following.
OJ Bartley 11-22-2019 01:00 PM
Well this sounds like it's got some potential... Wow, dude. Consider me subscribed.
Red Five 11-22-2019 01:36 PM
Counting down the days till the sawdust flies? :) I am adding the build thread to the Index, looking forward to the build pictures!
tential 11-22-2019 10:27 PM
Juju
So you're using 4 LaVoce 21s then?
I think you NEED LaVoce 21s. And they need you. Please save them from the cardboard box they are currently in... they miss you :(
jujuman200 11-23-2019 12:31 AM
1 Attachment(s)
This is what went down earlier..... not all of that is for speakers..... that stack is about 1 foot high.....lol
Cutting begins on Saturday.....
Juju
jujuman200 11-23-2019 12:34 AM
Nah.... ONLY 2- 21" in LFE Devs and RSS460HOs going in Minis.... I really like the curves of the LFE response.... should be wicked in my apartment....:D:D:D Only the reg size Minis will fit in the designated spots.....
Juju
jujuman200 11-23-2019 03:22 PM
3 Attachment(s)
UPDATE:
Everything is cut for 1 LFE except the rear panels... Going to start the glue-up after dinner tonight, should be completed by tomorrow night..... soon we go BOOM!!!
Hopefully I'll get them all done by next weekend being off work and all next week....
Yes I did BUILD a table saw that works very well I might add. I used it to rip the front to back 2x4 in half.
Setbacks: In measuring the wood once I got it home, They blew one of the cuts by ONE INCH so I had to rework my cut sheets with wood that was already cut..... that was just a PITA. Oh and their panel saw is NOT SQUARE!!! It was off by 3/16 over 4 feet......Alas, we move on....
Juju
Kothoga 11-23-2019 03:41 PM
Four Devastators in an apartment??!!
jujuman200 11-23-2019 06:22 PM
YEP!!
I have 2 full martys now....
Juju
jujuman200 11-24-2019 12:56 PM
1 Attachment(s)
@Red Five
UPDATE:
So we are now at the sanding and priming stage for the internals.....
TRIGGER WARNING::
If you build the LFE, the BASS will come..... but just be warned that this thing is cartoon-ishly large. When you do the mock up, all you can do is laugh.... and say wow...... That pic doesn't really give the scale..... that is a 45Lb Kettlebell on top.... not a small object....
As for the build.... It's not difficult at all.... IF you can do IKEA stuff, then you can do this....
Compared to a Marty build, this is not harder... it just takes more time..... I could have built 3 Martys by now...lol..
I'm looking to make it go BOOM tomorrow night..... Onward....
Juju
Red Five 11-24-2019 04:31 PM
That is cruising! The thing is a beast, I feel sorry for your back lol.
jujuman200 11-24-2019 07:20 PM
3 Attachment(s)
LOL.... now we wait.....drying paint..... I just used some BEHR Ultra from HD.... that color is Carbon in eggshell.... now all my subs match.
BTW.... there is no way I can keep the Martys and these.... well they served me well....
Juju
Red Five 11-24-2019 08:04 PM
They have such a smooth signature. Best to keep them all Devastators if it is a viable option.
jujuman200 11-24-2019 08:43 PM
Oh they will be.... I was just commenting on the size of the LFE.... I couldn't keep them both if I wanted to...
Juju
jujuman200 11-24-2019 08:45 PM
@superkyle
How did you get that big beast of a woofer in the box.... did you lay it on it's face and let gravity be your friend?
Juju
a77cj7 11-25-2019 12:17 AM
Originally Posted by jujuman200 (Post 58868896)
@superkyle
Juju
I might not count with tiny, insignificant 18’s, but installing them with the cabinet face-down was super easy.
Chris
superkyle 11-25-2019 03:24 AM
@superkyle
Juju
Yup that’s exactly how it’s done! To make alignment easy I did make some pencil marks to ensure the woofer was centered. Outside of that I held it by the magnet and gently lowered it into place.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
