Titan lx build in NJ - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #31 of 74 Old 11-25-2019, 12:24 PM
Black95tt's Avatar
I mounted mine inside the box (on one of the braces), and ran a 4 pole speakon connector to connect the mid and tweeter to the crossover over inside the box.
Black95tt is offline
post #32 of 74 Old 11-25-2019, 12:56 PM
smcmillan2's Avatar
Quoted: 1026 Post(s)
Liked: 866
Originally Posted by frankie2075 View Post
All I need is a positive and negative for the woofer couldn’t I just use 2 pole?
Because
Leaves you with options down the road.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #33 of 74 Old 11-25-2019, 02:08 PM - Thread Starter
frankie2075's Avatar
Quoted: 493 Post(s)
Liked: 119
That's what cabinet makers would call a 'racked cabinet' and can happen if parts aren't glued up square and flush. It mostly happens if your rear panel isn't kept flat as you glue parts to it. If you haven't glued the front baffle on you can fix it.
Looking at the pictures you posted: Take a long clamp going from the top of the cabinet to the bottom of the cabinet and put the pad of the clamp half way on the baffle section that is sticking out, and halfway on the panel it needs to flush up with. As you tighten the clamp it will pull those pieces together. If you do that on the right and left side of the cabinet, it will square it up. After you do that to make sure it works okay, unclamp, add glue, then reclamp to square up the cabinet and obviously lightly clamp the baffle on from front to back as well.
If that's not easy to understand, I'll try to draw some pictures or explain it with more detail.
Okay got the to big claps going to attempt to fix this
Sent from my iPhone using TapatalkClick image for larger version
ID:	2645598Click image for larger version
ID:	2645596Click image for larger version
I have a little overhang on one side now not to bad much better then before but I can your a bit trim router bit to make it even and take that off
frankie2075 is offline
post #34 of 74 Old 11-25-2019, 02:29 PM
a77cj7's Avatar
Quoted: 429 Post(s)
Liked: 365
Sent from my iPhone using TapatalkAttachment 2645598Attachment 2645596Attachment 2645594
Attachment 2645600
If you haven’t glued it yet, try running a single clamp diagonal corner to corner. Put the pads completely below the baffle. It should pull it all the way back in.
Chris
a77cj7 is online now
post #35 of 74 Old 11-25-2019, 04:26 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Chris
I did it already thanks for the advise tho. It’s more tolerable now. But going to buy the trimming bit for the router hopefully it’s helps even more
post #36 of 74 Old 11-25-2019, 04:31 PM
a77cj7's Avatar
Quoted: 429 Post(s)
Liked: 365
Flush trim bits do a nice job. Makes finishing much easier.
Chris
frankie2075 likes this.
post #37 of 74 Old 11-26-2019, 06:18 AM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Chris
Freud 1/2" (Dia.) Bearing Flush Trim Bit with 1/2" Shank (42-114) https://www.amazon.com/dp/B0000225YC..._Nws3Db9C1T73G
Something like this correct?
post #38 of 74 Old 11-26-2019, 06:20 AM
a77cj7's Avatar
Quoted: 429 Post(s)
Liked: 365
Yup, as long as your router takes 1/2 shank bits. Otherwise need the same thing with 1/4 shank.
Chris
post #39 of 74 Old 11-26-2019, 06:21 AM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Chris
Yes it does both anything I need to be Cautious about when doing this?
post #40 of 74 Old 11-26-2019, 06:24 AM
a77cj7's Avatar
Quoted: 429 Post(s)
Liked: 365
Not really, just keep the router squared up on the panel. Super easy to use a flush trim.
Chris
post #41 of 74 Old 11-26-2019, 07:14 AM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Just got this sample disc from Mark Waldrep owner of AIX records met him at NY audio show. Can’t wait to hear it on the new system
post #42 of 74 Old 11-26-2019, 11:21 AM
notfastenough's Avatar
Quoted: 211 Post(s)
Liked: 229
BTW, didn't see anyone mention, but the K2 amp is waaaayyyy overkill for these high efficiency speakers. No need for anything that powerful, you'll NEVER push the speakers that hard.
Several Titan owners have used solid 200wpc amps with high praise. If you're running active, I believe you can benefit from higher power amps for the LF driver with a HPF applied.
notfastenough is offline
post #43 of 74 Old 11-26-2019, 03:31 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Happy with the results
post #44 of 74 Old 11-29-2019, 11:43 AM
Quoted: 31 Post(s)
Did you use brad nails? Could be wrong but it looks like a chunk of your flush bit blade broke off. Might have been going too fast. Be careful using the bit in future might fail completely.
Bur05XP is offline
post #45 of 74 Old 12-01-2019, 03:09 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Nope no nails. Bit is fine not broken at all.
post #46 of 74 Old 12-17-2019, 05:57 AM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Both speakers done hooked them up to XMC-1 and XPA-2 and not so happy. I though I was going to have the same smile on my face as I did with my 1099s. 1099s I was using denon 4311ci and XPA-2 and loved it. But I’m not sure if it’s the XMC-1 that I’m not liking or just the speakers. Sound very harsh on some music. No life to the sound. Just blah. I have Dirac live full I’m going to run and see if that helps. The room I have them in is much smaller then the room I had 1099s and I’m going to try the denon with them.
post #47 of 74 Old 12-17-2019, 09:35 PM
MKtheater's Avatar
Quoted: 2614 Post(s)
Liked: 2866
Did you measure them?
Building the room, speakers, and subs.
MKtheater is online now
post #48 of 74 Old 12-17-2019, 09:36 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
No not yet had to get another computer
post #49 of 74 Old 12-17-2019, 09:40 PM
MKtheater's Avatar
Liked: 2866
Yeah, I would not panic yet. Different room and setup. There were many changes than just speakers. Take your time, you will figure it out. Make sure the crossover and all connections are correctly wired too.
post #50 of 74 Old 12-17-2019, 09:42 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Will do MK good to hear from you again. I’m going to work with them for a while I have DIRAC hope that can help some. Then placement and stuff. I will look over the crossovers again to make sure can also my ears being use to what I been hearing. So a little “break in time”. Thinking I need a amp with more juice they sound like they are running out of steam sometimes. But we shall see.
post #51 of 74 Old 12-17-2019, 09:47 PM
MKtheater's Avatar
Liked: 2866
Keep us posted, I like the idea of swapping in your denon just to setup everything like before since you were used to it. The room changing will be the biggest factor though. Going to bed, will check up tomorrow.
post #52 of 74 Old 12-17-2019, 09:49 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Yea have to. Will keep you posted. Prob won’t hear much until end of week. Started work on Monday won’t be home until Thursday. Curious as to know what your running now. Have a good night.
post #53 of 74 Old 12-18-2019, 05:46 AM
MKtheater's Avatar
Liked: 2866
Good morning, Take your time and enjoy the process. I am running a completely DIY room, I just built a new room, speakers, and subs. Also treatments and speaker grills, they are all in wall.
post #54 of 74 Old 12-18-2019, 05:52 AM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
Any pics? Your always up to something crazy. Do you have any of those eD subwoofers?
post #55 of 74 Old 12-18-2019, 07:16 AM
MKtheater's Avatar
Liked: 2866
my avatar is the front wall. Just two RE XXX 18 drivers that kick serious butt. 5 of my speakers have a 12 and the rest have a 10. Nothing crazy, just reference capable . The two drivers are impressive though. My thread is Theater 10.0. It shows some measurements and pics of the build process. My computer won’t let me take sweeps of the center or any surrounds so I have that to figure out.
post #56 of 74 Old 12-23-2019, 04:41 AM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
So I ran Dirac with the xmc-1 but still not crazy about the sound. It seems very harsh to me on some material esp with the volume a little hot. Then after I shut everything down and came back to give my self a break I turned of the XMC-1 and now it won’t load and just gets stuck on the “rethink high end”. So I replaced it with my 4311ci for now to have something but haven’t done any listening with it to compare. But now I have to send out this unit back to emotiva and wait prob 2 weeks to get it back. I think the sound that I’m not liking has to do more with the speakers then the XMC-1. I definitely miss my 1099s and wish I never sold them. If they take my XMC-1 back which I don’t think they will I will use that money and might buy my 1099s.
post #57 of 74 Old 12-23-2019, 08:01 AM
MKtheater's Avatar
Liked: 2866
Hurry up and test the denon on your speakers to make sure it is the speakers then you could go from there. I personally never liked the sound of Emotiva, I always preferred outlaw, I wish they made an Atmos processor. My favorires were Krell, ADA, and Meridian which outlaw reminds me of those.
post #58 of 74 Old 12-23-2019, 05:55 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
I’m not looking for atmos right not just 2 channel and something I can use to watch movies with in 2 channel.
post #59 of 74 Old 12-23-2019, 06:00 PM - Thread Starter
Quoted: 493 Post(s)
Liked: 119
How do you feel about classe? Looking at the classe sigma I think it’s called
post #60 of 74 Old 12-23-2019, 10:00 PM
MKtheater's Avatar
Liked: 2866
Just stereo, try the Outlaw 975, you can get one for around $200. It sounds excellent.
