Integrating 2 VBSS with Minimarty - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By abpatter
post #1 of 23 Old 11-25-2019, 08:03 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
With the help of this forum, I decided to build 2 VBSS to go along with my existing Minimarty. I put two PA460s into two of the slot port boxes tuned for 20 Hz. The Minimarty uses the UM18, and it's all powered by an Inuke NX6000D (Minimarty on Channel A, 2 VBSS in parallel on Channel B). AVR is a Denon X3400H. I'm going to start setting it all up today, but I was hoping I could get a sanity check on my Inuke settings first. Settings are in the following album:
https://imgur.com/a/sRI7pBE
Knobs on the front of the Inuke will be maxed out (fully clockwise). I used the recommended settings for the VBSS from the master thread, only changing the limiter to 143 per the instructions. I know I'll probably need to bump the gain on my minimarty to compensate for the highpass. Is there anything else I'm missing before I fire these things up?
abpatter is offline
post #2 of 23 Old 11-25-2019, 10:01 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
That limiter setting seems high to me. Am I misunderstanding the VBSS readme? When discussing the 6000dsp, it says "You must add them in pairs for this to work, no using odd number of enclosures. Limiter setting should be 143Vp (168Vp for 31hz)." Is that the limiter setting for adding a single pair? Or for maxing it out at 16 pairs?
Edit: I think I found the answer in the VBSS master thread. I've set the limiter back to 71.5.
Originally Posted by mtg90 View Post
All the settings needed are in the text document on the first post if you didn't already load the preconfigured VBSS DSP profiles from the zip folder.
They are 71.5v for 15 or 20hz and 84v for 30hz tune.
This is for 1, 2 or 4 woofers per channel on the inuke or NX3000.
For the inuke or NX 6000 you can run either one or two woofers in parallel per channel in at those same limiter settings or you can run the woofers in series pairs with the limiter settings doubled. Configured like this you can run up to four series pairs per channel for a total of 16 woofers off one amplifier.
abpatter is offline
post #3 of 23 Old 11-25-2019, 01:24 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
Could use some help here
I'm clipping input to both channels when I set avr volume to -5db, even with my avr sub trim minimized to -12db. Is that normal? Is the best way to resolve it to use the knobs on the front of the inuke?
abpatter is offline
post #4 of 23 Old 11-25-2019, 01:27 PM
smcmillan2's Avatar
Quoted: 1021 Post(s)
Liked: 856
That's what the attenuation knobs are for, yes. Turn them down as needed.
ETA: Be sure to turn the sub trim up to a normal level on the AVR.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 23 Old 11-25-2019, 01:34 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
What would you consider a "normal level" on the AVR?
abpatter is offline
post #6 of 23 Old 11-25-2019, 01:42 PM
smcmillan2's Avatar
Liked: 856
Somewhere around -6 should be a good starting point. Or re-run Audyssey, adjusting the front knobs as needed, until the AVR sets the sub trim into that range for you.
post #7 of 23 Old 11-25-2019, 03:16 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
Ok, I think I've got the input clipping issue solved. Here's my first REW graph. Looks like I've got some work to do. Any suggestions? I'm following mtg90's integration guide.
abpatter is offline
post #8 of 23 Old 11-25-2019, 03:48 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
A picture of my setup is attached. As you can see, it's a pretty small space without much room for rearranging the subs. I'm EQ'ing the 2 VBSS as a pair since they're the same distance from the listening position. The minimarty is about a foot closer, so I added 1ms of delay to it but the effects are negligible.
Name:	Minimarty+VBSS w delay.jpg
ID:	2645650   Click image for larger version
kevings likes this.
abpatter is offline
post #9 of 23 Old 11-25-2019, 05:30 PM
mtg90's Avatar
Quoted: 821 Post(s)
Liked: 1653
Try spinning the two VBSS cabs either 90 degrees (could try inside or outside) or 180 degrees so they face the front wall. I bet you can fix either one or both of those notches.
mtg90 is offline
post #10 of 23 Old 11-25-2019, 05:50 PM
Augerhandle's Avatar
Quoted: 1381 Post(s)
Liked: 1338
Flip the polarity of one sub channel, and take a comparison sweep.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #11 of 23 Old 11-25-2019, 05:53 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
Rotating them certainly seemed to help. Rotating them inward (both facing the minimarty) produced the best results.
abpatter is offline
post #12 of 23 Old 11-25-2019, 05:56 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
VBSS rotated inward, Channel A flipped.
Name:	Ch A flipped.jpg
abpatter is offline
post #13 of 23 Old 11-26-2019, 04:35 PM
AudyoVidyo's Avatar
Quoted: 104 Post(s)
Liked: 143
Looking good mate! Just a tweak of EQ and you'll be spot on. Now, more importantly, how does it sound?
AudyoVidyo is offline
post #14 of 23 Old 11-26-2019, 10:35 PM
mtg90's Avatar
Quoted: 821 Post(s)
Liked: 1653
I'd change channel A back if you haven't already. The reduction in output across the band when flipped shows it was in correct polarity to begin with.
Where are your speakers crossed at? Or are they even running in those measurements?
mtg90 is offline
post #15 of 23 Old 11-27-2019, 08:50 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
Thanks! I haven't had time to mess with it the last couple of days. I'm about to start tinkering now - haven't really tested them out yet.
I've swapped channel A back. Speakers (Elac Debut 2.0) will be crossed at 80 Hz I suppose, but they're not running in these measurements.
Does it matter that my Minimarty is at a much lower dB compared to the VBSS's for combined measurements?
abpatter is offline
post #16 of 23 Old 11-27-2019, 09:46 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
First attempt at EQ didn't go so well.
Before/After EQ on the Minimarty:
REW EQ Filters:
Before/After EQ on the VBSS's:
REW EQ Filters:
Combined Before/After EQ:
As you can see, it barely changed. I followed Chaluga's basic REW guide, but I must have screwed something up. Any ideas?
Name:	Minimarty before_after.jpg
ID:	2646564   Click image for larger version
Name:	VBSS before_after.jpg
ID:	2646566   Click image for larger version
Name:	Combined before_after.jpg
ID:	2646568   Click image for larger version
ID:	2646570   Click image for larger version
abpatter is offline
post #17 of 23 Old 11-27-2019, 10:18 PM
mtg90's Avatar
Quoted: 821 Post(s)
Liked: 1653
You add those filters into the Inuke and save them into a DSP preset?
Disconnect subs, run a very loud sine wave or pink noise signal to the amp and adjust channel levels such that they both hit their individual limiter setting at the same time. This way the two different sub woofers will be loaded the same so that they both hit 100% at the same time rather then maxing out one sub before reaching the limit on the other.
mtg90 is offline
post #18 of 23 Old 11-27-2019, 10:28 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
I've got them loaded in, here's Channel A as an example:
I'm not sure what you mean about the DSP preset (the guide doesn't mention this).
Name:	PEQ example.PNG
abpatter is offline
post #19 of 23 Old 11-27-2019, 10:38 PM
mtg90's Avatar
Quoted: 821 Post(s)
Liked: 1653
Sorry forgot you were using a NX6000 not Inuke. Looks like they removed that feature from the NX line.
Sure doesn't look like any EQ got applied, not sure what's wrong.
mtg90 is offline
post #20 of 23 Old 11-27-2019, 10:41 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
Well I appreciate the help regardless! I'll keep tinkering.
abpatter is offline
post #21 of 23 Old 11-28-2019, 12:29 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
EQ'ing all three together I was able to come up with this:
I did have to bump it 8dB at 63Hz though.
abpatter is offline
post #22 of 23 Old 11-28-2019, 09:13 PM
AudyoVidyo's Avatar
Quoted: 104 Post(s)
Liked: 143
Looks pretty good now. Well done. Can you take some additional measurements about 1ft each side of the microphone positioning that you took those measurements from? Sometimes we can get stuck on the one mic location but either side of it is not that bad. Binaural ears remember.
post #23 of 23 Old 11-29-2019, 12:25 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 5
Sure, I'll try to do that sometime tonight. I'm a little worried about boosting that one spot 8dB, as information here seems to vary on that topic. But the guide I was following said 5-8 dB boost is ok in the range of 50-90 hz, so hopefully it's ok.
abpatter is offline
