New Crown amp for two 18" SI D4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tgeorge34
post #1 of 15 Old 11-26-2019, 01:58 PM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
Hey guys,
It has been a few years since i have been on here, so i need a little refresher course on wiring, etc. I have an Inuke 6000DSP going to two 18" SI D4's. Had the system running issue free for about 5 years now, and just the other day noticed my amp quit on me. Currently in the market looking for a new amplifier. What i am leaning towards now is a Crown XLS 2502 as opposed to another Inuke.
Does anyone have a similar setup? I am wanting to know if you guys ran the amp at 2, 4 or 8 ohm loads. If i remember correctly, those are the variations you can do with two individual sub boxes? Can anyone remember the settings for the amplifier etc, as i don't remember what all the little controls do in the DSP. Was the 2502 enough power compared to the inuke?
Tyler
tgeorge34 is offline
post #2 of 15 Old 11-26-2019, 03:22 PM
Quoted: 35 Post(s)
Originally Posted by tgeorge34 View Post
Hey guys,
Tyler
I have 4 18" DS 4 in sealed boxes. I'm running 2 Crown XLi-3500. One channel on each sub running a 4 ohm load. I've never stressed the amp or the subs.
ls1ssz is offline
post #3 of 15 Old 11-27-2019, 12:40 PM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
A little update....so I got the Crown 2502 hooked up last night, each sub at 4 ohms. I set the Low Pass Filter at 80hz. This should give me 775 watts per sub. The sub is rated for 600 watts rms. With the inuke, it says it gets 3000 watts per channel, although we all know that number is not accurate.
The subs do not pound nearly as much at the same volume as with the Inuke? I could only get the lights on the front to barely jump up and down, like it wasn't pushing the amp that much? I was used to the Inukes lights going like crazy. Is this due to the Crown pushing out less power? I was expecting the bass output to be very similar, but was disappointed.
Is there anything i am missing? I want the Low Pass Filter set at 80hz, correct? I called SI directly, and they informed me the Crown amps power ratings is much better for the SI D4 rms rating than the Inukes.
Any thoughts?
post #4 of 15 Old 11-27-2019, 01:07 PM
Chris Popovich's Avatar
Quoted: 247 Post(s)
Liked: 225
Gain issues. Make sure you are using .775 v setting, make sure gain knobs are maxed out, and send it a good strong signal.
Chris Popovich is offline
post #5 of 15 Old 11-27-2019, 03:40 PM
Quoted: 88 Post(s)
Liked: 7
Any thoughts?
I had the same exact problem and an ART cleanbox pro fixed everything
valleyslim is offline
post #6 of 15 Old 11-27-2019, 09:49 PM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
Thanks!! I had the gain knobs up all the way, but changing the input sensitivity to .775 made a huge difference!!
Chris Popovich likes this.
post #7 of 15 Old 11-27-2019, 09:52 PM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
I will be ordering one of these as well. They are sounding fine now....but can't figure out why one channel has its lights illuminate just a split second faster, even though they are ran from a splitter from one LFE output from Receiver. Maybe boosting the signal will eliminate that. Thanks!
post #8 of 15 Old 12-01-2019, 02:24 PM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
I have the ART clean box pro on order. After you hooked it up, did you leave the input setting on the amp at .775 or the 1.4 setting. Also, how high did you turn the gains up on the Cleanbox? Or how do you know you have everything at the correct setting or level?
post #9 of 15 Old 12-01-2019, 05:41 PM
Quoted: 88 Post(s)
Liked: 7
I have it on .775 and half gain on the ART
post #10 of 15 Old 12-01-2019, 10:01 PM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
post #11 of 15 Old 12-02-2019, 06:49 AM
Quoted: 130 Post(s)
Liked: 64
How are you getting one sub to present a 4ohm load if its a D4 (i.e. dual 4 ohm voice coils)? If you wire the VCs in parallel that presents 2 ohms, if you wire them in series it presents 8ohms.
I have four of the SI HT18 D4, each one has its voice coils in parallel to present 2ohms and is connected to a single channel of an inuke nu4-6000 (4 channels, 4 subs). I don't have the gain knobs on the inuke set to max (they're on position 14 of 20) but they play plenty loud for me while barely tickling the 2nd of four clip lights, and that's with a 9dB boost below 25Hz.
Source: Gaming/HT PC, i7 3770K, 16GB DDR3 2400Mhz, 2x GTX 980Ti SLI, MPC-HCx64 w/ MadVR & SVP frame interpolation
Display: Panasonic VT30 55" Plasma ::: Receiver: Denon AVR-1910
5.1 Speakers: Behringer B215XLs
Subwoofers: 4x SI HT18 D4 - iNuke NU4-6000 w/ silent-fans (1 driver per channel at 2ohm)
Ormy is offline
post #12 of 15 Old 12-02-2019, 11:01 AM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
From memory when i hooked this all up originally, I was thinking that i wired up only a single voice coil per sub? Thanks for the lookout,...alot of this stuff has slipped my mind lol. I guess i will be taking the subs out of there box today and confirming exactly how i have them wired.
post #13 of 15 Old 12-02-2019, 11:44 AM
a77cj7's Avatar
Quoted: 397 Post(s)
Liked: 334
Hopefully not using only one coil, not good for the sub. That amp is 2 ohm stable though, so running the coils paralleled at 2ohm would work well.
Chris
a77cj7 is offline
post #14 of 15 Old 12-02-2019, 03:34 PM - Thread Starter
tgeorge34's Avatar
Quoted: 31 Post(s)
Liked: 25
Chris
Just got em out of the box....looks like i had them in series...an 8ohm load.
Just to confirm, I want them in parallel for a 2 ohm load, like the picture.
Name:	Screen Shot 2019-12-02 at 2.31.37 PM.png
post #15 of 15 Old 12-02-2019, 03:52 PM
a77cj7's Avatar
Quoted: 397 Post(s)
Liked: 334
Yes, that is correct.’
Chris
a77cj7 is offline
