SI 24” face to face driver arrangement help please - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #31 of 41 Old 12-07-2019, 05:14 AM
LTD02's Avatar
Quoted: 2998 Post(s)
Liked: 3745
"I thought “OD” is what placed the drivers in the sides firing towards each other hence offset? That’s how I was told to model the slot in hornresp."
that's right.
"What I am not sure about is the orientation of the drivers firing into the slot though. It appears that they are positioned on top and bottom instead of sideways just by trying to interpret the schematic."
no difference.
"Here are newest graphs...."
conceptually, that is right. however your PAR length appear too long. first is from back of manifold to center of driver, then second is center of driver to exit of manifold. yours are about 4 feet total. the manifold appears to be just over 2 feet, so try reducing them by just under half.
Listen. It's All Good.
LTD02 is offline
post #32 of 41 Old 12-07-2019, 05:48 AM - Thread Starter
audiovideoholic's Avatar
Quoted: 717 Post(s)
Liked: 226
that's right.
no difference.
Ok. Thanks LTD. last time you helped me I couldn’t figure out what to do once added the voltage instead of hitting max spl. I guess just play with voltage until I hit a limit right? So play with voltage, hit calculate, then look at power graph?
So if I have the plenum splayed so that the back is more narrow than the front and the schematic shows the drivers firing down into that section instead of sideways it compensates for the drivers not actually fitting in that orientation? Basically it works it out regardless is my question? The loading would seem to be different if the drivers were at an angle I would think? Basically a V style vs U style but don’t see how to change their orientation if that makes sense?
That is why the numbers are that way. I was just playing around to see how switching from U to V affected the curve. It pretty much stays the same as far as where it peaks.
Thanks for chiming in LTD!
Sent from my iPhone using Tapatalk Pro
audiovideoholic is offline
post #33 of 41 Old 12-07-2019, 05:52 AM - Thread Starter
Quoted: 717 Post(s)
Liked: 226
Originally Posted by Gorilla Killa View Post
OD is modeling a horn with the driver down from the throat instead of in it.
Are you using the Yates manifold for the front sealed drivers in the baffle? U baffle could work, transmission line box assuming its resonance you're concerned with.
Yes I’m trying to model a baffle similar to the Yates baffle for sealed on the front baffle wall. If I were to place these 24s in a manifold in the ceiling the opening would be restricted by the joist spacing so would be much more narrow than I am modeling here.
post #34 of 41 Old 12-07-2019, 05:55 AM
LTD02's Avatar
Liked: 3745
at bass wavelengths, slight differences in U or V shape won't matter if the cross sectional areas are roughly accurate.
up/down vs horizontal facing won't matter for modelling. neither will the angle of the drivers.
"I couldn’t figure out what to do once added the voltage instead of hitting max spl."
not sure what you are asking here. i'd check power for the amp and drivers's sake as well as excursion. those drivers should have quite a bit of excursion capability though. :-)
LTD02 is offline
post #35 of 41 Old 12-07-2019, 05:57 AM
LTD02's Avatar
Liked: 3745
"Yes I’m trying to model a baffle similar to the Yates baffle for sealed on the front baffle wall. If I were to place these 24s in a manifold in the ceiling the opening would be restricted by the joist spacing so would be much more narrow than I am modeling here."
you can cheat that somewhat by increasing the height of the manifold to compensate.
audiovideoholic likes this.
LTD02 is offline
post #36 of 41 Old 12-07-2019, 06:16 AM - Thread Starter
Quoted: 717 Post(s)
Liked: 226
Here a 18”width x 24.5”height U style with corrected par values....
post #37 of 41 Old 12-07-2019, 06:45 AM
LTD02's Avatar
Liked: 3745
that looks right.
thumbs up.
not sure about the vtc, but i don't think it matters.
LTD02 is offline
post #38 of 41 Old 12-07-2019, 12:42 PM - Thread Starter
Quoted: 717 Post(s)
Liked: 226
When I had you help me a few years ago with something similar I kept getting caught up on the max spl function instead of playing with the voltage to see performance.
So when I change voltage I need to hit calculate each time correct? I’m using FP clones so will need to regulate voltage possibly. I haven’t gotten that far yet though.
post #39 of 41 Old 12-07-2019, 02:22 PM
Gorilla Killa's Avatar
Quoted: 1541 Post(s)
Liked: 2245
that's right.
no difference.
So, modeling in OD you are putting the drivers at the mouth and eliminating the throat? The response is rather peaky at 100hz for this driver is this resonance of the opening?
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #40 of 41 Old 12-07-2019, 09:41 PM
LTD02's Avatar
Liked: 3745
roger, and yes, each time a parameter is changed 'calculate' has to be hit. tough to say how much limiting you may need. some of those drivers had a pretty tight suspension while others not so much, and lots of excursion as you know.
LTD02 is offline
post #41 of 41 Old 12-07-2019, 09:44 PM
LTD02's Avatar
Liked: 3745
s1/s2 PAR is from the back of the manifold to the middle of the driver.
s2/s3 PAR is from the middle of the driver to the mouth of the baffle.
for a 24" driver, with a baffle only deep enough to fit the driver, s1/s2 PAR would be about 12-13" or so and s2/s3 PAR would be about 12-13" as well.
when using OD as the model.
LTD02 is offline
