Ultimax 18 to NX6000D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-29-2019, 07:32 AM - Thread Starter
thisismyname123's Avatar
Quoted: 152 Post(s)
Liked: 56
I have 2 of the Ultimax 18s I bought a while ago and just ordered the DIYSG Sledge 4ft3 boxes for them.
This is my first sub build.
What's the connection method....AVR (Marantz 6011) to NX6000D to Sub. I see XLR, SPeakon, TRS, TS. Not sure what is what and what I need.
Help with links to products?
Need AVR out to AMP in cable....AMP out to Sub in cable....and Sub input terminal
thisismyname123 is online now
post #2 of 6 Old 11-29-2019, 08:40 AM
smcmillan2's Avatar
Quoted: 1026 Post(s)
Liked: 865
AVR -> NX6k - https://www.amazon.com/Monoprice-XLR.../dp/B001VLW398
4-pole SpeakOn from NX6k to box, I use 12AWG speaker wire in between.
I prefer these on the box: https://www.amazon.com/Neutrik-Panel.../dp/B00067JSFK
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
Last edited by smcmillan2; 11-29-2019 at 08:50 AM. Reason: Add note for 4-pole SpeakOn
smcmillan2 is online now
post #3 of 6 Old 11-30-2019, 08:33 AM - Thread Starter
Quoted: 152 Post(s)
Liked: 56
Ok thanks. Will have to look into these. Are speakon the preferred connection?
4 pole means 4 separate wires?
Sent from my Pixel 4 using Tapatalk
post #4 of 6 Old 11-30-2019, 08:54 AM
lawdogx's Avatar
Quoted: 201 Post(s)
Liked: 236
You use two wires, connected to the +1 and -1 inserts in your Neutrik connectors (just leave the +2 and -2 slots empty). For connectors, I like to use a straight neutrik NL4 connector on the amp side and a right angle NL4 connector on the sub side, because it allows for closer placement to the wall.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is online now
post #5 of 6 Old 11-30-2019, 08:59 AM
smcmillan2's Avatar
Liked: 865
They are my preferred connection. Many here use them as well.
4 pole is the number of connections in the SpeakOn itself, allows for options down the road (bridging, multiple connections, etc.). 2 wire between the SpeakOns is probably the most common use, +1/-1.
post #6 of 6 Old 12-01-2019, 06:54 PM - Thread Starter
Quoted: 152 Post(s)
Liked: 56
Thoughts on the crown xli 2500 vs the nx6000D?
Any comparison I find seems to be for the last model of inuke. Not sure if the new models are better.... quieter
