Sealed vs Marty Sub Response - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Augerhandle
  • 1 Post By BassThatHz
  • 2 Post By Luke Kamp
post #1 of 9 Old 12-03-2019, 03:26 PM - Thread Starter
bradthebold88's Avatar
Quoted: 50 Post(s)
Liked: 35
I just built one full marty to test and am getting a huge dip in response for some reason. Both subs are Stereo Integrity HT18s - full marty vs 4cf sealed, no EQ. Blue line marty, red line sealed, placed in the same spot to measure. Any idea why the ported has the huge dip through most of its response or if it's fixable? I've moved the sub around some, flipped the port to the other side but nothing made an appreciable difference.
Living room: Vizio P75 - Definitive BP2000TL, CLR3000, BPVX Bedroom: Definitive BP30, CLR2000
Theater: JVC RS540, 130" Centerstage XD, 1099 L/C/R, Definitive BPVX/BPX, quad SI 18
bradthebold88 is offline
post #2 of 9 Old 12-03-2019, 03:34 PM - Thread Starter
Quoted: 50 Post(s)
Liked: 35
Well, I'm mostly dumb, must have wired it backwards to the posts in the box I guess. Here it is with reversed polarity. Still a weirdly abrupt drop in response at 35Hz limiting the advantage of being ported, but it doesn't look horrible now at least.
post #3 of 9 Old 12-03-2019, 03:35 PM
Augerhandle's Avatar
Quoted: 1382 Post(s)
Liked: 1338
Play with polarity and delay.
EDIT: you posted while I was composing. Now, I would try to pull everything down to match the low spot.
Cam Man likes this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #4 of 9 Old 12-03-2019, 04:09 PM
asarose247's Avatar
Quoted: 1281 Post(s)
Liked: 1123
for the 2 subs involved here,
independently adjusted using mostly "delay" in terms of distance > many REW sweeps
so improvement is a possibility
YMMV
Name:	6 sub tweak sweeps.jpg
ID:	2648980   Click image for larger version
Name:	2018 1 1 13 jpeg to post.jpg
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #5 of 9 Old 12-03-2019, 04:17 PM - Thread Starter
Quoted: 50 Post(s)
Liked: 35
Yeah, that is just one sub, so any delay shouldn't be an issue. I have a minidsp and XT32 to EQ/set delay with once I get the other ones done. I mainly just wanted to see if it was worth the ~$300 in supplies to make boxes that take up 3 times the room. I'm a little disappointed with the >10dB drop at 35Hz vs the sealed one, but I'll check some other spots in the room too.
post #6 of 9 Old 12-03-2019, 05:17 PM
BassThatHz's Avatar
Quoted: 3880 Post(s)
Liked: 4374
That is likely the room and not the sub.
A full marty is flat from tuning on up, just like every other ported box.
Sealed only wins below 10hz.
From ~50hz up they will be nearly identical.
Cam Man likes this.
BassThatHz is online now
post #7 of 9 Old 12-03-2019, 08:36 PM
Luke Kamp's Avatar
Quoted: 189 Post(s)
Liked: 264
You need drivers in exact same spot to compare above port contribution, so raise sealed up...
Its not a drop at >35hz, its a big boost <35 hz with the port contribution.
Cam Man and lawdogx like this.
Luke Kamp is offline
post #8 of 9 Old 12-05-2019, 09:11 AM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 545 Post(s)
Liked: 658
What size/dimensions of the room, where was the sub placed in the room, where is seating, and why have any confidence that the MLP in your room will mirror anechoic response? Show us a spatial average using the same mic positions that you used for xt32. That's the only viable way to reasonably analyze LF acoustic response when we are working with "small" room acoustic LF response.
Cam Man is offline
post #9 of 9 Old 12-05-2019, 09:31 AM
lawdogx's Avatar
Quoted: 200 Post(s)
Liked: 236
I'm with Luke, you're getting a nice boost below 35 with the Marty, not a deficiency above 35 (assuming both measurements are at the same MV). That dip at 53 and peak at 70 are room related. If you EQ the Marty's low end the sweeps would be nearly identical … or you can use some of it in building a house curve … or, even better, move a sub around the room and find a second location that's strong from 35 to 65, add a second Marty there and use all those new-found dB's!
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is online now
