Best Pro Amp with DSP For Highs - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By A9X-308
post #1 of 13 Old 12-08-2019, 03:13 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 1
I need Pro Amp with dsp for highs. Need about 300w at 8ohm two ch or 4 up to $1500 or so budget although love to save money he he. Thanks for any help
rotgg is offline
post #2 of 13 Old 12-08-2019, 07:06 PM
Purenv's Avatar
Quoted: 234 Post(s)
Liked: 147
Look on EBay for Crown DCI 4-300N. There’s one on there right now listed for an opening bid at $850. Or if you want more power/headroom, there’s a DCI 4-600N for the same price.
Purenv is offline
post #3 of 13 Old 12-08-2019, 07:57 PM
a77cj7's Avatar
Quoted: 392 Post(s)
Liked: 331
JBL specs the crown dci’s for some of their high end theater speakers. They have their own dsp setting file for them, of course.
I love my analog dci’s, haven’t used the network versions though.
A minidsp and any high quality pro amp would be another option.
Chris
a77cj7 is online now
post #4 of 13 Old 12-08-2019, 08:11 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 1
Thanks for the replies I do not want to use mini dsp just trying to keep things as simple as possible I am looking at the crowns now
rotgg is offline
post #5 of 13 Old 12-11-2019, 08:30 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 1
Bought a crown didnt get the network one but may switch all my amps to network after doing some reading on them thanks for the help
rotgg is offline
post #6 of 13 Old 12-11-2019, 06:33 PM
A9X-308's Avatar
Quoted: 1844 Post(s)
Liked: 1554
Why?
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #7 of 13 Old 12-12-2019, 10:37 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 1
Originally Posted by A9X-308 View Post
Why?
thats what drivers will take
rotgg is offline
post #8 of 13 Old 12-12-2019, 03:11 PM
A9X-308's Avatar
Liked: 1554
What sensitivity are they?
A9X-308 is offline
post #9 of 13 Old 12-12-2019, 07:11 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 1
Originally Posted by a9x-308 View Post
what sensitivity are they?
107
rotgg is offline
post #10 of 13 Old 12-12-2019, 07:52 PM
A9X-308's Avatar
Liked: 1554
107
Then you're not going to need anything remotely like 300W, even in a PA in a much larger room than anybody but an oligarch can afford.
All you'll end up doing is running into noise problems.
Also what 107dB driver handles 300W?
A9X-308 is offline
post #11 of 13 Old 12-12-2019, 08:08 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 1
then you're not going to need anything remotely like 300w, even in a pa in a much larger room than anybody but an oligarch can afford.
Also what 107db driver handles 300w?
de780tn
rotgg is offline
post #12 of 13 Old 12-12-2019, 09:11 PM
Augerhandle's Avatar
Quoted: 1380 Post(s)
Liked: 1335
...what 107dB driver handles 300W?
de780tn
de780tn is rated 220 watts
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #13 of 13 Old 12-12-2019, 09:39 PM
A9X-308's Avatar
Liked: 1554
Yeah, I'd just looked it up myself. My DE25s in the Unitys are similar sensitivity and I doubt that even with EQ I've hit 20W into them at deafening levels. I use a 50W/ch amp for the HF.
scottvalentin likes this.
A9X-308 is offline
