DIY center speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-11-2019, 10:41 AM - Thread Starter
Liked: 0
DIY center speaker
Hi, I have been lurking here for a while and have built a few projects from the information here (martycube, and 2x fullmarty subs). I am now looking to build a good center channel speaker. My theater room has a sloped ceiling and that puts my TV pretty low to the ground. I am looking for a center speaker design that is low in height. I have no restrictions on width.
Does anyone have any design recommendations for a center speaker with the low height restrictions? I am not looking for a flat pack. I will build from scratch. Basic dimensions are ok, as I can model it out in CAD.
Thanks in advance.
jeffseine is offline
post #2 of 14 Old 12-11-2019, 10:48 AM
Quoted: 233 Post(s)
Liked: 221
What is your maximum height?
What are your main speakers and receiver/amp driving the front stage?
What is your desired frequency response? SPL?
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is online now
post #3 of 14 Old 12-11-2019, 10:53 AM - Thread Starter
Liked: 0
Hi, I could probably go as high as 12", but would prefer less. I will probably build main L/R speakers in the next couple months to go with the center, but right now for temporary speakers, my center is the weakest. Something that I could build matching L/R speakers later would be good. I am driving it with a Denon X6500H.
I don't know enough about audio to have a desired frequency response or SPL. I am looking for recommendations. I don't want to spend crazy money, but wouldn't mind being at the high side of the bang for the buck curve.
Jeff
post #4 of 14 Old 12-11-2019, 10:56 AM
asarose247's Avatar
Quoted: 1281 Post(s)
Liked: 1123
it depends . . .
do you have a height dimension range?
the F4Q4 could have been a prime candidate but Bigfoot got the last one . . .
but maybe some research / questions could put you on the trail
@mtg90 might have some info
the designer is Curt Campbell
HTH
my pair , after AudyXT32 runs would get xo'd @ 40 hz.
a wondrously space saving yet monstrous sounding speaker
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #5 of 14 Old 12-11-2019, 12:22 PM
BlueGhost's Avatar
Quoted: 50 Post(s)
Liked: 35
Just looking at what DIYSG has to offer, the HTM 8 and HT 8 are 12.5 inches tall, Cobalt 8 MTM is 10 inches tall, the Apollo 7 MTM and Helix Dome MTM are both 9.5 inches tall.
They all come with front baffles, but the flat pack it optional.
BlueGhost is offline
post #6 of 14 Old 12-11-2019, 12:47 PM
asarose247's Avatar
Liked: 1123
.02
my pair of HTM6's as pictured , at a distance of 6' , mol, from the mlp
for a majority of music and movies, with subs
create a sound field of superlatives
the F6CC is usually not needed
as the SEOS horns with moderate toe-in leave nothing to be desired
all too often better than DSU or Neo:X in a room that does 5.3.4 ATMOS very well
props to @Erich H and the DIYSG crew
the F15's that use the 15" SEOS, as do the HTM12's
also do a very very good phantom center fill, at 11' from the mlp in my living room
not sure what your "temporary" speakers are
but you might consider a L/R upgrade
depends on your HT particulars
post some dimensions, pics , budget, mitigating factors etc.
HTH
Name:	3 x 15's.jpg
ID:	2652598   Click image for larger version
Name:	HTM6 and Fusion6CC- mancave.jpg
post #7 of 14 Old 12-11-2019, 01:24 PM
a77cj7's Avatar
Quoted: 392 Post(s)
Liked: 331
https://www.diysoundgroup.com/home-t...-1010-kit.html
That should fit the requirements.
Chris
a77cj7 is online now
post #8 of 14 Old 12-11-2019, 02:21 PM - Thread Starter
Liked: 0
Originally Posted by asarose247 View Post
.02
HTH
Interesting, so you use two speakers toed in as the center?
Jeff
post #9 of 14 Old 12-11-2019, 02:23 PM - Thread Starter
Liked: 0
Chris
This is interesting as well. I can't seem to find a photo of it on the web, do you know of any photos?
Jeff
post #10 of 14 Old 12-11-2019, 02:24 PM
BlueGhost's Avatar
Quoted: 50 Post(s)
Liked: 35
Chris
Looking at the specs, the HTM 1010 would pair great with some HTM 12s down the road.
post #11 of 14 Old 12-11-2019, 02:26 PM
a77cj7's Avatar
Quoted: 392 Post(s)
Liked: 331
Jeff
Its brand new, don’t think any have been posted. You can contact Erich.
I would assume its a MTM with 2 10” woofers and a large waveguide.
Chris
post #12 of 14 Old 12-11-2019, 02:31 PM
BlueGhost's Avatar
Quoted: 50 Post(s)
Liked: 35
Chris
It's two 10's and a SEOS 77 wave guide. They are listed under the "What's Included" tab. I'm guessing a SEOS 77 would be a 7 inch square wave guide, but I can't find any pictures of it.
post #13 of 14 Old 12-11-2019, 02:41 PM
Quoted: 14 Post(s)
Liked: 5
Since you are able to build without flat packs, here are a couple more options from reputable designers:
https://www.divine-audio.com/khancenter/
http://techtalk.parts-express.com/fo...h-amigas/page3
bac2040 is offline
post #14 of 14 Old 12-11-2019, 03:51 PM
asarose247's Avatar
Liked: 1123
The stereo imaging of the L/R "works" as expected in creating a full frontal sound stage
really fantastic for 99%+ of legacy stereo
they do not lack . .
