Another Titan 615LX Build Thread - with Questions - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #1 of 37 Old 12-15-2019, 12:07 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Hey everyone,
Been a member for close to 8 years and posted ~20x. Essentially, I lurk and read what those far smarter than me have posted. I am however creating my first thread and have a couple questions. I have started building three Titan 615LX speakers for my front stage to go behind a 120-135" projector screen (haven't decided which). I must first say that the packaging from DIY Soundgroup is truly second to none. All the wood and components arrived safely, unharmed and cut perfectly.
I do plan to finish the speakers with Black Duratex, rolling it on. I think two coats should be proficient from reading all the threads and Duratex's cheat sheet.
Quick shout out to some of the previous build threads (no particular order) that were awesome to follow:
Definitely Matt Grant at HifiCircuit and Erich H for answering all my questions.
@VicTorious1
@strawberry
@kaiforce
@Nahkarankaisija
@pnhayden
Here are a few pics to get everyone up to speed on where I am.
Name:	Initial Assembly 0.jpg
ID:	2654392   Click image for larger version
Name:	Initial Assembly 1.jpg
ID:	2654394   Click image for larger version
Name:	Initial Assembly 2.jpg
ID:	2654396   Click image for larger version
Name:	Initial Assembly 13.jpg
ID:	2654398   Click image for larger version
Name:	Initial Assembly 12.jpg
Name:	Initial Assembly 11.jpg
ID:	2654402   Click image for larger version
Name:	Initial Assembly 10.jpg
ID:	2654404   Click image for larger version
Name:	Initial Assembly 9.jpg
ID:	2654406   Click image for larger version
Name:	Initial Assembly 8.jpg
ID:	2654408   Click image for larger version
Name:	Initial Assembly 7.jpg
Name:	Initial Assembly 6.jpg
ID:	2654412   Click image for larger version
Name:	Initial Assembly 5.jpg
ID:	2654414   Click image for larger version
Name:	Initial Assembly 4.jpg
ID:	2654416   Click image for larger version
Name:	Initial Assembly 3.jpg
1slowfrc is offline
post #2 of 37 Old 12-15-2019, 12:08 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Denim
Here are a few pics of the denim installation with the glue I used.
ID:	2654424   Click image for larger version
ID:	2654426   Click image for larger version
Name:	Spray Glue 1.jpg
ID:	2654428   Click image for larger version
bubbrik and openbaffled like this.
1slowfrc is offline
post #3 of 37 Old 12-15-2019, 12:14 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
QUESTIONS for the pros
I have completed my first round of sanding and found a couple errors I made in the gluing process. I attached a couple pictures that show some poorly clamped edges and my questions are as follows:
1. Should I use the recommended 50/50 glue and water mixture to help "seal" these joints? Should I do so on all the joints? Is it necessary, or am I just being paranoid?
a. I do plan to use the compound below to hide these edges prior to painting.
2. I planned to use the drywall/joint compound in the picture attached below to hide all the edges. I do plan on using Duratex to finish. Is this joint compound okay to use? I did a bunch of searches and couldn't find any recommendations on what to use or more specifically, what NOT to use.
One quick aside, for those looking at the super uneven edges on the bottom of the box, I highly recommend using a router and a flush trim bit vs. sanding. I sanded... needless to say it took some time!!
Please be kind with your responses as I am no pro and am merely asking for help after researching this for hours on end.
Name:	Uneven Edge 1.jpg
ID:	2654432   Click image for larger version
ID:	2654434   Click image for larger version
ID:	2654436   Click image for larger version
Name:	Uneven Edge 2.jpg
ID:	2654438   Click image for larger version
Name:	Drywall Texture Compound 1.jpg
Name:	Drywall Texture Compound 2.jpg
1slowfrc is offline
post #4 of 37 Old 12-15-2019, 12:19 PM
Kothoga's Avatar
Quoted: 136 Post(s)
Liked: 182
F the speakers, what's with the Maro in the background?!
Craig S King likes this.
Theater: JVC RS540U, 2.35:1 142" screen, Onkyo RZ1100, Panasonic UB820, Outlaw Audio M2200 Monoblock x3, Klipsch RF7II, RC64II, RS62II, 5800CII x4 Atmos, PSA V3611 Subwoofer x2.
2 Channel: Parasound P6, Parasound A23+, Rega Planar 6 with Ortofon 2M Bronze, Klispch La Scala II, Behringer NX6000D, B&C 21DS115-4 powered Devastator V1 x2.
Kothoga is online now
post #5 of 37 Old 12-15-2019, 12:20 PM
michael hurd's Avatar
Quoted: 642 Post(s)
Liked: 693
2. I planned to use the drywall/joint compound in the picture attached below to hide all the edges. I should have mentioned this earlier, but I do plan to use duratex to finish all the boxes. Is this joint compound okay to use? I did a bunch of searches and couldn't find any recommendations on what to use or more specifically, what NOT to use.
You could use drywall joint compound, but I use a lightweight polyester autobody filler. Keep in mind that any solution is going to be dusty, very dusty. A long flat board sanding block will help you out in achieving good looking joints in conjunction with an appropriate filler.
180 grit is fine enough for your duratex finish if you are rolling it.
fill35U likes this.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, impulsivity, uncontrolled or repeated movements.
michael hurd is offline
post #6 of 37 Old 12-15-2019, 12:24 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Haha, that has been a 6 year build from the bottom up. It's a black hole of money, blood and time...
1slowfrc is offline
post #7 of 37 Old 12-15-2019, 12:26 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Thank you for the recommendation. I did some research on auto body filler and Bondo specifically, but most people said it was a PAIN to sand and ended up using joint compound. I have never used either, just researched both.
Do you hand sand it or use a Random Orbital Sander. I have plenty of 180 sandpaper so that isn't an issue. Also did you use 50/50 water glue before hand or is one or the other?
1slowfrc is offline
post #8 of 37 Old 12-15-2019, 12:26 PM
Kothoga's Avatar
Quoted: 136 Post(s)
Liked: 182
They always are! I've done a few Vettes, wife had enough so I bought a C7Z. Best of luck on the Titans and the SS.
post #9 of 37 Old 12-15-2019, 12:28 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Done 4 vettes, hence the name 1slowFRC... will probably sell the 'maro in the spring and look at the 2020 mid-engine options. Thanks for the kind words. I am very confident I am in the right place to receive some good advice. Everyone here is pretty awesome and I unfortunately I don't have much to add to many threads. Good reads though.
1slowfrc is offline
post #10 of 37 Old 12-15-2019, 12:36 PM
Kothoga's Avatar
Quoted: 136 Post(s)
Liked: 182
Yeah, know the feeling. Just bought a large Tuff Shed to use as a woodworking space, evidently I needed a new expensive hobby. As for the C8, waiting for the Z06 version before I make the jump, but yes, I'll go to a mid-engine ASAP too.
post #11 of 37 Old 12-15-2019, 12:42 PM
Quoted: 642 Post(s)
Liked: 693
Body filler can be a pain to sand if:
( 1 ) you use cheap filler instead of a premium filler
( 2 ) using the wrong grit and type of sandpaper - Garnet / flint sandpaper is not suggested
( 3 ) expecting instant gratification
If you mix and apply the filler properly, it will make finishing work a lot easier. * a thin application with a good quality applicator. ( I prefer a metal wallpaper scraper instead of a plastic applicator )
Hand sand the filler with P80 grit, then finish in P180. Use a long block and long strokes to keep the surface flat.
Buy your supplies at an autobody shop, Pep Boys, etc, not at Walmart.
fill35U likes this.
post #12 of 37 Old 12-15-2019, 12:57 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Good advice. Thanks for taking the time to reply. Looks like Auto Body Filler is the weapon of choice!
Any need to use the water and glue mixture prior to?
1slowfrc is offline
post #13 of 37 Old 12-15-2019, 12:58 PM
Quoted: 642 Post(s)
Liked: 693
No.
post #14 of 37 Old 12-15-2019, 01:20 PM
lawdogx's Avatar
Quoted: 204 Post(s)
Liked: 238
No pro here but I do live very close to the Duratex HQ and chat with the nice folks there when I pick up my product. One of the tips they gave is that some types of fillers do not bond well with Duratex. The only filler they endorse is the Elmers Carpenter’s Color Change Wood Filler, in fact they sell it in their showroom. I have no idea how other types of fillers mentioned bond with Duratex, but the Elmers stuff they recommended works like a charm.
Chris Popovich and fill35U like this.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is online now
post #15 of 37 Old 12-15-2019, 04:55 PM
Erich H's Avatar
Quoted: 1917 Post(s)
Liked: 2764
I'd use a power sander to get all the panels flush, then use some wood filler on any cracks. Or you could just mix saw dust with wood glue until it's thick and then squish that into the cracks.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #16 of 37 Old 12-15-2019, 06:59 PM
Craig S King's Avatar
Quoted: 445 Post(s)
Liked: 545
Those CCWs look sharp. Good combo.
Craig S King is offline
post #17 of 37 Old 12-15-2019, 10:18 PM
mtg90's Avatar
Quoted: 827 Post(s)
Liked: 1664
Yeah just use wood filler especially for a small joint like that, easy application, easy cleanup. You're not going for an automotive gloss finish on the speakers so there is no need to use a messy/stinky two part auto body filler.
mtg90 is offline
post #18 of 37 Old 12-16-2019, 05:53 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Thank you to everyone for the replies so far. I did go ahead and pick up some autobody filler ha. I think I'll give it a try and see how it turns out. If it's just an extra day of labor I might as well go for it and get acclimated to using it for my next builds. I probably should have waited for a consensus from everyone, but am excited to see how the bondo product works and the final product. I guess I don't mind sanding too much
I'll update with pictures hopefully this weekend if I get time.
1slowfrc is offline
post #19 of 37 Old 12-17-2019, 08:20 AM
kaiforce's Avatar
Quoted: 129 Post(s)
Liked: 182
I had similar cracks in my boxes and just filled them with glue and sanded accordingly. I only recommend that if you're going to roll on duratex. A thick layer of duratex hides so much. I wouldn't spend too much time worrying
Pair of Titan 615LX
8x Full Marty (6x UM18-22, 2x SI HT-18) on 4x Inuke6000DSP
4x Sealed Dayton 460HO on Crest Audio ProLite 5.0
4x Volt 10LX
kaiforce is offline
post #20 of 37 Old 12-20-2019, 01:07 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Bondo Application
Well, since I had already gone ahead and purchased the bondo for the seams, I decided to use it. Not sure I'm the best at applying it, but hopefully it turns out okay. Really just hoping duratex hides my feeble attempt at applying it evenly.
As promised, pictures below. Will start sanding this evening...wish me luck!!
As an aside, these are the initial applications. I do think I got "slightly" better as I did the rest of the cabinets haha.
ID:	2656480   Click image for larger version
ID:	2656482   Click image for larger version
ID:	2656484   Click image for larger version
1slowfrc is offline
post #21 of 37 Old 12-20-2019, 05:21 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Just finished sanding!! Super easy and not near as painful as I thought it would be. Used 80 grit on a long block to start then finished with 150 grit. Couldn’t find my 180 roll for some reason. Here’s a couple pics.
Need to finish the waveguide portion tomorrow and hopefully first coat of paint.
1slowfrc is offline
post #22 of 37 Old 12-20-2019, 05:25 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Question for those that have done DIY builds...did y’all use speaker feet?
1slowfrc is offline
post #23 of 37 Old 12-20-2019, 06:45 PM
smcmillan2's Avatar
Quoted: 1026 Post(s)
Liked: 866
With the speakers sitting on what?
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #24 of 37 Old 12-21-2019, 09:46 AM - Thread Starter
1slowfrc's Avatar
Liked: 29
Question for those that have done DIY builds...did y’️all use speaker feet?
Carpet.
1slowfrc is offline
post #25 of 37 Old 12-21-2019, 12:26 PM
Quoted: 642 Post(s)
Liked: 693
Looks decent, though there may be one or two spots that may need a tad bit more sanding. Don't worry, when you put on a coat of Duratex, and you can see any flaws, just give the Duratex 1/2 hour or so to dry, give it a light hand sanding down with P180 or P220 on a block, wipe off the dust and re-coat.
post #26 of 37 Old 12-21-2019, 02:34 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Will do! Thanks for the tip. Applied the first coat of Duratex about an hour ago. Have a few chores to complete and will hopefully get some time to light sand this evening and apply second coat tomorrow am. Here are a few pics.
Name:	Duratex Coat 5.jpg
ID:	2657138   Click image for larger version
Name:	Duratex Coat 4.jpg
ID:	2657140   Click image for larger version
Name:	Duratex Coat 3.jpg
ID:	2657142   Click image for larger version
Name:	Duratex Coat 2.jpg
ID:	2657144   Click image for larger version
Name:	Duratex Coat 1.jpg
kaiforce likes this.
1slowfrc is offline
post #27 of 37 Old 12-21-2019, 04:35 PM
smcmillan2's Avatar
Liked: 866
Carpet.
I can't imagine needing feet on the Titans if they are sitting on carpet. Unless they start walking when really pushed.
post #28 of 37 Old 12-22-2019, 01:19 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
Second coat of Duratex and awful soldering skills
This is why you buy the pre-built XOs lol
Name:	Duratex Coat 2.1.jpg
ID:	2657440   Click image for larger version
Name:	Duratex Coat 2.2.jpg
ID:	2657442   Click image for larger version
Name:	Awful Soldering Skills.jpg
trevordj likes this.
1slowfrc is offline
post #29 of 37 Old 12-22-2019, 10:52 PM
trevordj's Avatar
Quoted: 120 Post(s)
Liked: 124
The cabinets look good, nice work.
That looks like a cold solder joint. What kind of soldering iron are you using? If you can turn up the power it may help, more flux may help, different solder may help, or simply giving the joint more time to heat. A new iron may help if you are using something really crappy. I like a hot soldering iron so I can heat the joint quickly, solder it, and move on before it’s heats much of the surrounding components.
trevordj is offline
post #30 of 37 Old 12-23-2019, 03:58 PM - Thread Starter
1slowfrc's Avatar
Liked: 29
I probably need a better soldering iron. Mine was a struggle to use with my wife holding the wire and terminal. I also will freely admit, I am not the best at soldering.
1slowfrc is offline
