21" Full Marty Build - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By automata21
post #1 of 14 Old 12-21-2019, 12:26 AM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
Hey Gents!, After seeing people praising a lot about LaVoce I recently got two of the 21" inch LaVoce SAN214.50 imported to NZ from US and looking to build Full Marty Sub. But I am struggling to find out cutlist for the same.
If I was staying in US my easy route would have been to get GSG Audio flatpack. Another problem is we don't get 19mm mdf here in NZ, only 18mm. So it would be really helpful if someone can help me out with the cutlist.
Thanks a lot
automata21 is offline
post #2 of 14 Old 12-21-2019, 01:48 PM
BassThatHz's Avatar
Quoted: 3880 Post(s)
Liked: 4374
So like a normal every-day 15hz ported box then?
Probably best to make a 15hz ported box that is designed for those woofers, rather than designed for different woofers.
The net volume, port length/size and port velocity might have different requirements.
The the width and height too, since this is a 21, not an 18...
You should start by using winISD to plug all the values in for the driver, the tuning, the power, and then optimize for excursion/spl.
Once you have a rough idea of the size, then you can use sketchup to mock up a box in 3 dimensions.
You can use the ruler-tool to figure out the cut-list.
This is what I did for the HzHorn, but using HornResp instead of winISD.
BassThatHz is offline
post #3 of 14 Old 12-21-2019, 03:27 PM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
Thanks @BassThatHz , yeah I like to tune it at @15hz. I have already got dual sealed um18, dual VBSS tune 31hz and SVS pc13 in a small room 14ft by 12 ft but so wanted to see how 21 pro will sound. I will model it myself to see what I can do and will post back. Having it tune at 15 will make sure they are in sync with Pc13 but I am sure they ll not match in SPL level.
post #4 of 14 Old 12-22-2019, 01:44 PM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
I have been modelling Lavoce 21 in a ported box tuned at 15hz and at 2m I see its performance equal to SVS PB13 ultra. Is there something wrong I am doing? Isn't it suppose to do better than a 13.5 inch driver?
post #5 of 14 Old 12-22-2019, 02:10 PM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
Also, I am comparing the Model I did in winISD with GSGAudio performance tabel and I see I am bit off in the SPL table.
post #6 of 14 Old 12-22-2019, 03:37 PM
Augerhandle's Avatar
Quoted: 1381 Post(s)
Liked: 1338
Looks like apples and oranges to me.
Why do you show it in two different volume boxes (and two different tunes) for the comparisons? Why is the tune different than the GSG spec that you are comparing? What is the signal level, and at what distance? Is it driven to xMax? Is there a HP filter in place? Did you use the GSG PEQ recommendation?
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #7 of 14 Old 12-22-2019, 04:05 PM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
Please correct me if I am doing this wrong as I am newbiew with winISD. Does this makes sense?
post #8 of 14 Old 12-23-2019, 08:12 AM
Liked: 1338
You've changed the volume again. Isn't the GSG flatpack 9.0 cu. ft.? I think they also recommend a PEQ filter set to +9 dB at 25 Hz., and lowering the gain 9 dB to compensate.
post #9 of 14 Old 12-23-2019, 05:57 PM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
I have taken the dimensions from their page for 21" full marty: 28.25” wide, 23.50” deep, 42.00” tall
Maximum power : 1200 Watt
Tuning 17hz
If I put them in the excel it comes like this
Please correct me if I am doing anything wrong here.
ID:	2658084   Click image for larger version
ID:	2658086   Click image for larger version
ID:	2658088   Click image for larger version
Name:	Volume Tuning.png
ID:	2658090   Click image for larger version
post #10 of 14 Old 12-24-2019, 02:21 AM
Liked: 1338
You're using gross volume of 13.50 instead of the net volume of 10.86. GSG uses more bracing, so this number would be even lower.
You're adjusting Gain -5 dB instead of -9 dB.
You may need to adjust input power down from 1200 watts, until the Cone Excursion is at or below the red line.
post #11 of 14 Old 12-24-2019, 04:45 PM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
Yeah right. I used -5 to keep it below excursion
I keep it to around usable excursion. Isn't Lavoce okay with usable excursion till 22mm or its best to check keep it near Xmax
I still couldn't figure out how GSG performance table can suggest: 21-Full Marty SAN214.50 15 121 127 (132)
Is it including room gain?
post #12 of 14 Old 12-28-2019, 08:09 PM
LTD02's Avatar
Quoted: 2997 Post(s)
Liked: 3742
lavoce specs xmax as (Hvc - Hg)/2+ Hg/4.
that's on the conservative side.
(Hvc - Hg)/2+ 2/3 * Hg is roughly the usable both in theory as well as measured by josh at databass for the lavoce san214.50.
Listen. It's All Good.
LTD02 is offline
post #13 of 14 Old 01-14-2020, 03:01 AM - Thread Starter
automata21's Avatar
Quoted: 30 Post(s)
Liked: 24
Thanks @LTD02 , I went with your devastator design and build two of them. Your designs are helping people across the globe to experience bass nirvana.
They are nearfield, I just need to play with dsp now.
LTD02 likes this.
post #14 of 14 Old 01-14-2020, 09:54 PM
LTD02's Avatar
Liked: 3742
way to go!!
...and, thank you.
LTD02 is offline
