Mini Devastator Test Build - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By Racerryan
  • 1 Post By hd0823
  • 1 Post By jujuman200
  • 2 Post By tential
  • 1 Post By Red Five
post #1 of 24 Old 12-26-2019, 03:54 PM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
Talking Mini Devastator Test Build
No real reason to build one other than it looked like a fun project. Thanks @Red Five .
My buddy wants a couple of VBSS end table variants built. But I think this is a better design. The plan was to built one and see if it would work for him. Just need to finish up the bracing, rear hatch and load a driver.
Mistakes or things i would do better.
1) the front and baffle assemble got spun around and i punched a number of pocket holes on what is the front. Ugh. I don't think these will fill well??
2) Cut larger front chamber rails and notch them so they sit flush to the front
3) Use baltic birch and mitre corners.
I have a Mach Audio IXL-18 not being used, i am thinking of jamming it in and taking some measurements. Or is this a total mismatch and not worth the time? PA460 was the originally intended driver.
ID:	2659222   Click image for larger version
ID:	2659224   Click image for larger version
ID:	2659226   Click image for larger version
ID:	2659228   Click image for larger version
OJ Bartley likes this.
Racerryan is offline
post #2 of 24 Old 12-26-2019, 04:10 PM
Looks good. I'm interested in your results for sure. And imo, if you didn't want to try and fill those pocket holes, cover them up with some trim.
Sent from my SM-G955U using Tapatalk
Soloact is offline
post #3 of 24 Old 12-26-2019, 04:18 PM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
Not a bad idea, similar to what @hd0823 did.
https://www.avsforum.com/forum/155-d...tor-build.html
post #4 of 24 Old 12-26-2019, 04:22 PM
Originally Posted by Racerryan View Post
Exactly. Easy fix.
Soloact is offline
post #5 of 24 Old 12-26-2019, 04:54 PM
a77cj7's Avatar
Quoted: 675 Post(s)
Liked: 720
Awesome, you should do a side by side with a vbss to see which is preferred.
Bondo can easily fill the pocket holes. Leave it a bit high for shrinkage, then sand flat when cured.
Putting the bracing in with the rear panel glued on is going to be interesting.
Chris
a77cj7 is online now
post #6 of 24 Old 12-26-2019, 04:55 PM
Liked: 3
Looking good!
tompa909 is offline
post #7 of 24 Old 12-26-2019, 08:59 PM
hd0823's Avatar
Quoted: 909 Post(s)
Liked: 1723
The trim is super easy and makes there be alot less sanding and filling plus gives it's a furniture looking touch. I actually ran screws in on the sides but wasnt worried because of the trim. I say go for it
Sent from my SM-N975U using Tapatalk
jujuman200 likes this.
hd0823 is online now
post #8 of 24 Old 12-26-2019, 09:08 PM
Red Five's Avatar
Quoted: 1094 Post(s)
Liked: 942
Primarily designed for pro 18"s SAF184.03, SAN184.03, 18TBW100, 18DS115, PA460 etc, but the RSS460HO works out of simulated/tested HT woofers. Not sure about the UXL18, I have not simmed it.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #9 of 24 Old 12-26-2019, 09:17 PM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
Interested to see how it models vs PA460. No pressure. lol
File Type: zip IXL-18 - 2013.zip (699 Bytes, 10 views)
post #10 of 24 Old 12-26-2019, 10:00 PM
jujuman200's Avatar
Quoted: 309 Post(s)
Liked: 290
Originally Posted by a77cj7 View Post
[snip].....
Chris
Yes it will be...... I made the same mistake when I built my LFE... but at least I could crawl inside for easier installation of the braces....
Juju
hd0823 likes this.
Sub List: 1- Red Five Mini Devastator 18" w/460HO, 1- Red Five Devastator LFE 21", 1- BOSS platform [The Hideaway Theater], 1- 21" "Marty" tuned to 20Hz, 1- 18" "Marty" tuned to 17Hz
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is online now
post #11 of 24 Old 12-26-2019, 10:24 PM
Quoted: 35 Post(s)
It might be easier to cut little 3/4" x whatever pieces from leftover scrap and stick them on the front of the rails to accomplish the same thing.
Prana Ferox is offline
post #12 of 24 Old 12-27-2019, 08:06 AM
Red Five's Avatar
Liked: 942
Le has a value of 0, do you have the full specs?
post #13 of 24 Old 12-27-2019, 10:24 AM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
I couldn't find anything online, so i emailed Mark at Mach Audio. Thanks again.
post #14 of 24 Old 12-27-2019, 05:54 PM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
Good idea.
Finished up the bracing. A little different than recommended. Seemed to me the bottom and front are well supported, just the sides and top need reinforcement.
ID:	2659874   Click image for larger version
ID:	2659876   Click image for larger version
ID:	2659878   Click image for larger version
post #15 of 24 Old 12-28-2019, 02:45 AM
tential's Avatar
Quoted: 435 Post(s)
Liked: 301
Not to be rude my friend but:
No real reason other than it looked like a fun project? That doesn't even make sense you silly goose. You seem to forget, it produces bass. Now trust me, people here, we love LOOKING at subs. I mean, I like the La Voce 21 inch because it's an "affordable" 21 inch sub that you can keep buying more and more of. But let's not pretend that these don't produce bass.
Unless of course, I have misunderstood you, and maybe you truly do just like to look at the subwoofer. And I won't judge you. We love subs. If you keep thinking of doing these fun projects every couple of months, you may really enjoy the outcome. Especially if you turn them on and don't just look at them. I'm not saying it has to be a monthly fun project (I'm not saying it doesn't, if you have to have fun once a month go ahead!) but don't stop having fun projects ok?
jujuman200 and Rcris like this.
tential is offline
post #16 of 24 Old 12-28-2019, 09:36 AM
jujuman200's Avatar
Quoted: 309 Post(s)
Liked: 290
Good idea.
I think that he was referring to up by the driver for the standoff distance.... but that works as well....
Looking good.....
Juju
post #17 of 24 Old 12-28-2019, 10:41 AM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
Lol. No offence taken. I have the bug bad as well. Eventually i will assemble a 2.1 system upstairs for music and this will be likely used there. I have 3 other enclosures not being used already (1 LLT/EBS, 2 plus sized VBSS variants). My theatre still puts a grin on my face when i crank up the music and movies. Although, judging from others on here, at some point an upgrade will happen.
post #18 of 24 Old 12-29-2019, 06:33 PM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
Mark says use 3.4mH for LE
post #19 of 24 Old 12-30-2019, 09:34 AM
Red Five's Avatar
Liked: 942
The IXL 18 with the values provided should look something like this. It looks a lot like the RSS460HO in the Mini DEV and that has been done with good results.
Name:	IXL 18 Mini Dev.jpg
post #20 of 24 Old 12-30-2019, 12:46 PM
jujuman200's Avatar
Quoted: 309 Post(s)
Liked: 290
A little EQ on that left side and you will be good to go.....
Juju
post #21 of 24 Old 12-30-2019, 01:32 PM - Thread Starter
Quoted: 47 Post(s)
Liked: 55
I will jam it in the box and give it a try. Thanks!!
post #22 of 24 Old 01-07-2020, 02:26 PM
Red Five's Avatar
Liked: 942
Any status updates? I have added the test build to the Index
post #23 of 24 Old 01-07-2020, 02:38 PM
Rcris's Avatar
Quoted: 124 Post(s)
Liked: 148
Is RSS460HO suitable to mini version, sorry not following the updates lately. I got 2 of them on hand taking dust but would love to them get in action if they do full range.
Rcris is offline
post #24 of 24 Old 01-07-2020, 02:49 PM
Red Five's Avatar
Liked: 942
I have not ran the sim for the Mini v2 yet, but they do work in the Mini v1. I would imagine they would get better low end on the v2.
