Integration strategy - 1 Devastator + 2 Marty Cubes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-29-2019, 12:40 AM - Thread Starter
nexus99's Avatar
Quoted: 183 Post(s)
Liked: 85
In my room I plan to have 2 18" marty cubes up front and a 21" Eminence Devastator on the back wall. My room is 14' deep so that puts the Deva nearfield to the back of my sofa.
Any recommendations on integration strategy? Just slap on a HPF and try to time align and EQ? Or try something fancy?
The Deva cant go up front... room is just too small.
JDM World: https://www.youtube.com/jdmworld
GSG Devastator Build Eminence 21" https://youtu.be/DgtVxjg06to
GSG Full Marty Build: https://youtu.be/-U1deD_0j9c
UM18-22 Sealed Subwoofer Build: https://youtu.be/7ifac8Rh8gk
nexus99 is offline
post #2 of 2 Old 12-29-2019, 10:58 AM
lawdogx's Avatar
Quoted: 204 Post(s)
Liked: 238
I can share my strategy - take a measurement from every available location in the room then choose your locations based on what the location delivers for you. I choose locations based on how they compliment other locations and sum together to give me a nice flat response. I then choose which sub goes where based on the sub/driver’s strengths and weaknesses. My um18-22 minimartys excel on the lower end, so they go in the locations that play to their strengths. My devas excel mid to high so they go in locations that suit them. For me, location is the single most important variable, but then again my room sucks.
Some folks have room or decor constraints that limit them to zero other options. If your room or waf or preferences have your locations chosen without regard to how they perform acoustically then yeah, time align them and EQ them as best you can, you have what you have. I have a thread on deva/Marty integration and found they integrate perfectly if you do your part in location selection
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is offline
