Theater Build FINALLY Moving Forward (Titan 630LX, SHS-24, HTM-10, Volt 10...) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #31 of 44 Old 02-09-2020, 09:38 AM
Quoted: 21 Post(s)
Liked: 3
Where’s a link to your sub box build?
That’s going to be a great system and the speakers will outlast all of the other gear for many many years. Great work and wonderful ideas.
hessc50 is offline
post #32 of 44 Old 02-09-2020, 02:34 PM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
Should have the CNC'd panels any day now from my cabinet guy. He's been promising them for several weeks... I'll post pics of the build here.
BBLV is offline
post #33 of 44 Old 02-09-2020, 02:51 PM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
While drawing out my projector box design, I decided to go with a hush box and add a 4" inline fan to get the heat out of the box and room. There is no return for the basement's HVAC loop in my theater room, just two supplies, so I thought I'd make use of an unused 4" duct that we ran during construction that was supposed to be for the equipment room (it kept overheating, so I added a ductless minisplit just for the equipment room). I'm going to tap into that 4" ducting in the equipment room, install an AC Infinity S4 inline fan on the ceiling of the equipment room, and then feed a new 4" duct through the soffit to the top of the hush box. In the pic you can see the hole where the flange will attach at the upper front of the hush box.
I rigged up a small relay box with a 120V > 12V power supply that powers a time delay relay. The logic is: JVC NX7 projector's 12V trigger powers on/off with the projector, turn projector off and the 12V trigger turns the relay and duct fan off, but the time delay on the relay will keep the power outlet for the fan hot for another 15 min to evacuate all of the hot air. Built and tested today and it works perfectly.
The hush box is going to hang from the ceiling in the back of the theater. I built a mounting plate with cutouts for the AV conduit box, 4-gang power outlet and the 4" ducting. Went to attach it to the ceiling last night and found out that my drywall guys are complete garbage - the ceiling had a bow of over 1/2" so the mounting plate wouldn't lay flush!!! Still fuming...... Not sure what I'm going to do, but it might involve brute force, hoping that it doesn't F up the drywall finish on the ceiling... (there's a big piece of 3/4" ply above the drywall mounted to the soffit framing).
Right now I'm building the lower box that will slip over the mounting plate's flange and attach to it with some #8 screws. As soon as the lower box is done and ready for paint I'll try getting that mounting plate mounted up. The back of the hush box is going to be held on with magnets and have a perforated aluminum grill to allow fresh air to be pulled through the hush box.
Name:	IMG-9850 (50%).JPG
ID:	2682906   Click image for larger version
Name:	IMG-9847 (50%).JPG
ID:	2682908   Click image for larger version
Name:	IMG-9846 (50%).JPG
ID:	2682910   Click image for larger version
Name:	IMG-9835 (50%).JPG
p3bham likes this.
BBLV is offline
post #34 of 44 Old 02-11-2020, 06:30 AM
rfbrang's Avatar
Quoted: 320 Post(s)
Liked: 99
Sub'd. Looks fantastic.
You mentioned 240v for amps, what benefit does that provide?
Do you just get a breaker that spans both sub panel channels?
What outlets?
Our Old Space
New House
PSN: brotj7
rfbrang is online now
post #35 of 44 Old 02-11-2020, 01:45 PM
OJ Bartley's Avatar
Quoted: 572 Post(s)
Liked: 674
Sometimes I'm just in awe of the great ideas and the application of knowledge and skills in here to solve specific problems. That inline fan solution looks so clean and perfect in its execution. Very impressive.
BBLV likes this.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is online now
post #36 of 44 Old 02-11-2020, 05:19 PM
Mike Garrett's Avatar
Quoted: 13210 Post(s)
Liked: 10833
The problem would not be from the drywall guys. The drywall conforms to the framing. So if you have a bow in the ceiling, it is the framing guy or framing material, that you should be upset with, not the drywall guys. Only way it can be the drywall guys is if they completely missed fastening to several joists and I doubt that happened. But if that did happen, you would be able to push the drywall back up, using a "T" brace and fasten it to the joists.
BBLV likes this.
Mike Garrett is online now
post #37 of 44 Old 02-11-2020, 05:40 PM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
I think you're right. Waiting for my contractor to come by and see what we can do to fix it.
BTW they framed the soffit with metal studs. Hoping that doesn't come back to bite me... The columns and screen wall are wood.
BBLV is offline
post #38 of 44 Old 02-12-2020, 10:22 AM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
What outlets?
The Emotiva amps run more efficiently and the Speakerpower amp is 240V only. Here are some pics of the power outlets, dedicated HT rack subpanel and power cable construction. Overkill everything: 10g cryo-treated power cable for the SP amp and 12g cryo-treated power cables for the Emotiva amps.
Name:	IMG-9863 (50%).JPG
ID:	2683974   Click image for larger version
Name:	IMG-7045 (50%).jpg
ID:	2683976   Click image for larger version
Name:	IMG-7042 (50%).JPG
ID:	2683978   Click image for larger version
Name:	IMG-7041 (50%).jpg
ID:	2683980   Click image for larger version
Name:	IMG-7040 (50%).JPG
Name:	IMG-7038 (50%).JPG
ID:	2683984   Click image for larger version
Name:	IMG-9864 (50%).JPG
BBLV is offline
post #39 of 44 Old 02-12-2020, 12:32 PM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
This morning we cut open the drywall in the ceiling and found that the drywallers went right over a low-voltage box that stuck down about 1/2". Trimmed the box back to flush and drywallers are repairing the drywall as we speak. Back on track!
BBLV is offline
post #40 of 44 Old 02-12-2020, 07:07 PM
Liked: 10833
I assumed you had accounted for all the boxes.
BBLV likes this.
post #41 of 44 Old 02-14-2020, 04:06 PM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
Well well well.... Look what just arrived fresh off the CNC. Going to be a long weekend gluing up in the garage!!
Name:	IMG-9887 (50%).JPG
ID:	2684968   Click image for larger version
Name:	IMG-9886 (50%).JPG
tjambro, luisev, trevordj and 1 others like this.
BBLV is offline
post #42 of 44 Old 02-18-2020, 04:06 PM
Quoted: 45 Post(s)
Liked: 3
Love this thread. Do you have a full build thread somewhere too?
It looks like your HT-10s for surround duty are all going into columns. I would love to know your column dimensions as that is exactly what I'm planning (if I can spare the 8" deep column space vs. putting in in-walls). What is your overall room dimension?
Sundodger is offline
post #43 of 44 Old 02-19-2020, 06:57 PM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
Making some slow progress. I only have a pair of saw horses, just ordered two more pairs to help speed this up! Cabinet guy missed/miscut a handful of pieces and I'm still waiting on them, so the Titans are on hold until those show up. Should be done with the two SHS enclosures by Friday. I've learned some valuable lessons on CAD/CNC design that have led to lots of wasted time during assembly sanding and cutting clearances for corners where the bracing meets, etc. If I were to do it again I would also program the CNC to drill all the holes to save even more time and add more precision.
Name:	IMG-9908 (50%).JPG
ID:	2687386   Click image for larger version
Name:	IMG-9907 (50%).JPG
ID:	2687388   Click image for larger version
Name:	IMG-9906 (50%).JPG
ID:	2687390   Click image for larger version
Name:	IMG-9940 (50%).JPG
ID:	2687392   Click image for larger version
Name:	IMG-9939 (50%).JPG
Name:	IMG-9938 (50%).JPG
ID:	2687396   Click image for larger version
Name:	IMG-9922 (50%).JPG
ID:	2687398   Click image for larger version
Name:	IMG-9921 (50%).JPG
ID:	2687400   Click image for larger version
Name:	IMG-9918 (50%).JPG
ID:	2687402   Click image for larger version
Name:	IMG-9899 (50%).JPG
Name:	IMG-9905 (50%).JPG
tjambro and OJ Bartley like this.
BBLV is offline
post #44 of 44 Old 02-19-2020, 07:10 PM - Thread Starter
BBLV's Avatar
Quoted: 118 Post(s)
Liked: 143
This is my only build thread. Not as well organized as many, but it fits my scrambled approach
The outer dimensions on the side columns are 11" deep and 21.5" wide. The openings are slightly under 20"H x 16"W. The rear and front wides columns are different dimensions, simply to suit the design/layout of the room.
Attached are my initial design drawings from probably 3 years ago. I haven't looked at these in quite a while until your question came up on the room dimensions, but I'm surprised how close the end result is going to be to my initial vision!
Name:	IMG-2860 (50%).JPG
ID:	2687408   Click image for larger version
Name:	IMG-2862 (50%).JPG
BBLV is offline
