DIYSG Cobalt 8 Build Thread - AVS Forum | Home Theater Discussions And Reviews
 27Likes
  • 4 Post By HurricaneDitka
  • 5 Post By HurricaneDitka
  • 3 Post By HurricaneDitka
  • 2 Post By HurricaneDitka
  • 9 Post By HurricaneDitka
  • 1 Post By ghart999
post #1 of 30 Old 01-03-2020, 09:49 AM - Thread Starter
HurricaneDitka's Avatar
Quoted: 42 Post(s)
Liked: 47
I have 4 Colbalt 8s for surround duty in my new theater. When I was talking to Erich he said he had never seen a build thread for these, so I figured I'd document the process even though they are pretty basic. All four are going in the angled surround flat packs.
The quality of the MDF pieces in the flat packs are amazing with the precision of their cuts. I added a generous helping of Titebond 3 and clamped them up. Unfortunately, I don't have enough clamps, so I had to do them one at a time.
ID:	2663376   Click image for larger version
ID:	2663378   Click image for larger version
ID:	2663380   Click image for larger version
HurricaneDitka is offline
post #2 of 30 Old 01-03-2020, 09:53 AM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
I bought the binding post plates from Parts Express and I'm going to put them on the top of the cabinets.
ID:	2663384   Click image for larger version
ID:	2663386   Click image for larger version
post #3 of 30 Old 01-03-2020, 02:52 PM
ZGief's Avatar
Liked: 1
Following I've only seen 2 Cobalt build threads and both were for LCR.
Sent from my HD1905 using Tapatalk
ZGief is offline
post #4 of 30 Old 01-05-2020, 05:08 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
Did some jigsaw work today. Because of how I am mounting them, I put two of the speaker terminals on the back and two on the top.
ID:	2665002   Click image for larger version
ID:	2665004   Click image for larger version
ID:	2665006   Click image for larger version
ID:	2665008   Click image for larger version
post #5 of 30 Old 01-05-2020, 05:10 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
Did a dry fit run of the parts and glued the face panel on the two that will be my rear surrounds. I found the easiest way to clamp them since they were angled was to do them together.
ID:	2665018   Click image for larger version
ID:	2665020   Click image for larger version
post #6 of 30 Old 01-07-2020, 03:29 AM
Quoted: 151 Post(s)
Liked: 133
That's brilliant!
dorri732 is offline
post #7 of 30 Old 01-08-2020, 10:10 AM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
Did a sanding with 150 grit by hand and then filled all the seams and rounded edges with joint compound.
post #8 of 30 Old 01-09-2020, 03:06 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
CRAP!
I just noticed that the picture of the flat pack on the DIYSG website has the tweeters at the bottom. How screwed am I?
Name:	Cobalt Flat Pack.jpg
post #9 of 30 Old 01-09-2020, 03:21 PM
smcmillan2's Avatar
Quoted: 1033 Post(s)
Liked: 886
Probably lose a bit of the low end due to port proximity to back wall, but that's about it.
Real question is do the drivers fit in that orientation?
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #10 of 30 Old 01-09-2020, 03:45 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
Everything seemed to have plenty of room when I dry fitted the drivers. I contacted Erich and this is his response.
I did see that in your build thread when you posted pictures. It won't really matter enough to worry about. My original thought was having the tweeter on the bottom might lower reflections off the ceiling. That was when the original prototype design used a flush mount tweeter. But before the final design ever got to the site the designer ended up liking the horn loaded tweeter better for the Cobalts. So the horn around the tweeter already helps lower reflections. Long story short....you're fine.
This response came in about 3 minutes. Erich and DIYSG is amazing.
post #11 of 30 Old 01-24-2020, 10:55 AM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
I did some work doing the internal wiring last night. The kit comes with gold plated connectors for the woofer and tweeter. I bought some more (blue) from Home Depot to connect to the terminal plate. I had DIYSG build the crossovers for me since I was a total noob and a little nervous about getting it right. Since that time, I have built them for my Volt 6s and the process is super easy and fun. If you have any soldering skills, I suggest doing it.
post #12 of 30 Old 01-24-2020, 12:55 PM
trilkb's Avatar
Quoted: 715 Post(s)
Liked: 381
Nice build.
I was also amazed how easy the crossover was to put together on my classix II's. Not much to it if you get the crossover boards. My next build will be harder (sunflower redux's).
Have you listened to the cobalts yet?
- 6 x Boston Acoustic CR6 Frankencenter, Boston Acoustic CR8 L/R, 4 jbl 8330a surr , 8 x jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #13 of 30 Old 01-24-2020, 02:33 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
Originally Posted by trilkb View Post
Nice build.
No. Parts Express shipped me the DuraTex without the texture roller so I am waiting for that to show up. I don't want to put them together more than once to keep the screws tight.
post #14 of 30 Old 01-24-2020, 04:44 PM
smcmillan2's Avatar
Liked: 886
That isn't something to worry about. I tested all of my DIYSG speakers "in the raw" and then finished them. The screws hold without issue (unless you remove/reinstall 5 - 8 times, maybe).
post #15 of 30 Old 01-24-2020, 07:06 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
You talked me into it. Time to try these out and break them in a bit.
ID:	2675490   Click image for larger version
BP1Fanatic and OJ Bartley like this.
post #16 of 30 Old 02-04-2020, 05:54 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
Some roller coats of DuraTex and they are installed and running. They were tight as hell at first and needed a severe workout to get them loosened up, but they are sounding great now. The two for the surround back channels are mounted with a combination of door hinges and mounts from Monoprice.
ID:	2680638   Click image for larger version
ID:	2680640   Click image for larger version
ID:	2680642   Click image for larger version
ID:	2680644   Click image for larger version
post #17 of 30 Old 02-04-2020, 09:16 PM
BlueGhost's Avatar
Quoted: 64 Post(s)
Liked: 43
I like the recessed mounts, I've though about doing this with my volt 8s.
BlueGhost is offline
post #18 of 30 Old 02-05-2020, 09:38 AM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
I originally did it because the room is small and it was a way to get them a few more inches away from the listeners, but I like the look as well.
post #19 of 30 Old 02-05-2020, 03:43 PM
BlueGhost's Avatar
Quoted: 64 Post(s)
Liked: 43
My room is 11'9" wide, with a 8' reclining sofa centered at the MLP. One of the walls is an exterior wall, so I'm not sure I'd want to open it up. I think my volts are going to end up at shoulder height to keep them mostly out of the way.
post #20 of 30 Old 02-07-2020, 11:59 AM
ghart999's Avatar
Quoted: 221 Post(s)
Liked: 73
They look great. I have the Colbalt 8s for LCR and love them. I hate putting them sideways but I have no other choice.
BP1Fanatic likes this.
Audio: Denon AVR-X3400H - Behringer NX6000D - miniDSP
Speakers: LCR: DIYSoundGroup Cobalt 8s | Surrounds: NHT SuperOnes | Atmos: Boston Acoustic SoundWare | Subs: Marty cube w/ Ultimax UM18 and (4) JBL CS1214s
Automation: Fire Cube - Harmony Hub- Insteon Plugs - Sensi Thermostat
Video Image: TCL 55r625 - Roku - nVidia Shield Pro 2019 - Xbox One X
ghart999 is offline
post #21 of 30 Old 02-07-2020, 12:39 PM
smcmillan2's Avatar
Liked: 886
Originally Posted by ghart999 View Post
They look great. I have the Volt 8s for LCR and love them.
Volts? Those look more like Cobalts to me?
post #22 of 30 Old 02-07-2020, 12:51 PM
ghart999's Avatar
Quoted: 221 Post(s)
Liked: 73
I'm a moron. Meant to say Colbalts.
ghart999 is offline
post #23 of 30 Old 02-07-2020, 04:28 PM
meeks32's Avatar
Liked: 27
Could this kit be built into the walls to be flush or close to flush? I’m looking into some inwall speakers for my living room. Custom boxes built into the walls aren’t out of the question but I would want them pretty flush.
meeks32 is offline
post #24 of 30 Old 02-07-2020, 05:19 PM
BlueGhost's Avatar
Quoted: 64 Post(s)
Liked: 43
The standard Cobalts are 10.25" deep, the angled are 9.25" deep at the top and 5.5" at the bottom. You would want the baffles from the angled boxes that have front facing ports.
I know they can be made at least 5.5" deep, which would slightly overhang most walls. Your average interior wall would be 4.25-4.5" deep accounting for 2x4s and sheet rock on one face. You would need to expand the box inside the wall to make up for the extra volume needed.
HT-8s would be another one to look at. They are 7.5" deep, giving you around 3 inches overhang.
post #25 of 30 Old 02-10-2020, 10:19 AM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
As you see the angled ones in my theater, that is as far back as they will go and are up against the drywall on the other side.
ID:	2683288   Click image for larger version
post #26 of 30 Old 02-12-2020, 07:43 AM
OJ Bartley's Avatar
Quoted: 572 Post(s)
Liked: 674
I'm going to be using Volts for my surround and Atmos speakers, and they will all be recessed into the walls/ceiling. I shortened the depth as much as I could, and I figure with grilles on they will probably come out maybe an inch or an inch and a half into the room after 2 layers of drywall.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is online now
post #27 of 30 Old 02-12-2020, 09:28 AM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
Grills? Did you custom make some?
post #28 of 30 Old 02-13-2020, 06:32 AM
OJ Bartley's Avatar
Quoted: 572 Post(s)
Liked: 674
Hey Ditka, I did actually make some grilles. Or at least I started to make some. I used some leftover hardboard and cut it to the size of the baffle (slightly undersized to allow for fabric covering). Then I drilled 4 pilot holes through the grille (in place) and into the baffle. That marked my centre locations to install magnets. I used a larger bit to make the holes to flush fit the magnets, triple checked polarity, and epoxied them into place. Then I did some filling and sanding.
They turned out pretty decent, but I probably should have set them just under the surface, instead of flush like I did. The magnets would have totally disappeared that way. I think they should finish up pretty nicely, and when the grilles are on you won't see that spot anyway.
I haven't cut out the centres or put a chamfer on the outside yet, but I will. This was kind of a test to see how things worked. I think the magnets I used are 8mm x 3mm and they seem to hold very well, which is good because I plan to put these on my overhead Atmos speakers too.
ID:	2684360   Click image for larger version
ID:	2684362   Click image for larger version
ID:	2684364   Click image for larger version
ID:	2684366   Click image for larger version
ID:	2684370   Click image for larger version
post #29 of 30 Old 02-15-2020, 05:37 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 47
That looks great! Do you have any pics of the finished product?
Edit: I just re-read your post and realize they aren't done yet. Please share when they are.
post #30 of 30 Old 02-16-2020, 03:04 PM
BP1Fanatic's Avatar
Quoted: 328 Post(s)
Liked: 302
Nice build HD!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is online now
