Help ? Dvc isobarik sub wiring - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-07-2020, 07:51 PM - Thread Starter
John O'Connell's Avatar
Liked: 0
Does any know how to wire two 4 dvc subs in a clamshell isobarik config out of phase ,iv got two duel 4ohm subs that im putting in to a ported clamshell isobarik config , an im not sure how to wired it a visual diagram would be helpful if anyone has one ,just to note im aiming for a parallel wiring config that end in a 4ohm load
sorry if i sound a tha noob
if you can help thanks
John O'Connell is offline
post #2 of 8 Old 01-07-2020, 08:32 PM
A9X-308's Avatar
Quoted: 1844 Post(s)
Liked: 1554
1: Put each 4R VC in each driver in series to make 2 x 8R drivers.
2: Connect drivers in opposite phase in parallel.
Test before bolting on the front driver with a very low frequency sine wave to make sure both are moving in the same direction at the same time, ie, both out of the box then both into the box.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #3 of 8 Old 01-08-2020, 03:21 PM
drewp29's Avatar
Quoted: 82 Post(s)
Liked: 70
John - Are you aware of the benefits and drawbacks of an isobaric design?
Before you commit to an isobaric configuration, you should be aware of the drawbacks, as they are quite significant. The only real benefit is the box size can be smaller (half the Vas). If that is what you are going for, then so be it. However, you don't gain any efficiency, and therefore, the dual driver configuration outputs the same as a single driver. Isobaric has no real benefits in my opinion.
http://techtalk.parts-express.com/fo...antages-if-any
^Read this thread for more info.
drewp29 is offline
post #4 of 8 Old 01-08-2020, 03:24 PM - Thread Starter
Liked: 0
do you have a visual diagram of how that goes ,iv got two duel 4 ohms subs that need to be wired to a single 4ohm load so i can power it with my crown 1502 in bridged mode to give the the full 1550watts
post #5 of 8 Old 01-08-2020, 05:12 PM - Thread Starter
Liked: 0
im going for a smaller box ,my ability to lift big boxs is limited my current design is an effective 3.765 cubicfeet with one 15in passive radiator tuned to 12.5hz
the outer dims are 49in high by 19.3in wide by 12.25in deep with inturnal dim at 46in by 16.3in by 9.25in deep
post #6 of 8 Old 01-09-2020, 12:05 PM
drewp29's Avatar
Quoted: 82 Post(s)
Liked: 70
1.5 inch wall thickness? MDF or plywood? If you are planning MDF, you might consider plywood for the substantial weight savings. Double baffle 3/4" plywood, with 3/4" for the rest of the box would net you a little under 5 cubic feet while still retaining the outer dims. And it would weigh less than half of what an MDF box would weigh - probably more like 1/3. Much easier to move.
Just some things to consider - most people build extreme SPL boxes using drivers with very high Xmax out of 3/4" plywood and have no issues provided the internal bracing is properly designed. Though I feel a lot of designs go extreme overkill on bracing. Some sacrifice a large amount of internal volume for no real world gain. Bracing is important, but the law of diminishing returns applies in the same manner as increased wall thickness.
Back to the isobaric discussion though - You had asked initially about 2 open baffle 15s, and judging by the depth of your current design, it appears you have a depth limitation, not necessarily width and height?
You also mentioned a passive radiator (PR)? What are you doing with the PR? Are you thinking isobaric 15s, face to face, with a single 15 PR?
It would help immensely if you told us what your plan is for this box, and any applicable limitations. There are much more knowledgeable forum members here than myself that might be able to help you accomplish your ultimate goal with a little more information from you.
drewp29 is offline
post #7 of 8 Old 01-13-2020, 09:16 AM
Augerhandle's Avatar
Quoted: 1381 Post(s)
Liked: 1338
Originally Posted by john o'connell View Post
does any know how to wire two 4 dvc subs in a clamshell isobarik config out of phase ,iv got two duel 4ohm subs that im putting in to a ported clamshell isobarik config , an im not sure how to wired it a visual diagram would be helpful if anyone has one ,just to note im aiming for a parallel wiring config that end in a 4ohm load
https://knowledge.sonicelectronix.co...g/#prettyPhoto
If you want them out of phase from each other, just swap the positive and negative (red and black) wires of the driver on the right side of the drawing.
Name:	capture 2_subs_DVC_4_ohm_mono_variation1.jpg
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #8 of 8 Old 01-13-2020, 10:48 AM
noah katz's Avatar
Quoted: 2257 Post(s)
Liked: 828
And you don't get all of that benefit because the motor of the 2nd driver sticks way out.
I also agree that 1.5" thick is overkill, and wastes a lot of internal volume w/those dimensions.
You can make the panels just as stiff w/sufficient xbracing.
Noah
noah katz is offline
