AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   15" subwoofer build (https://www.avsforum.com/forum/155-diy-speakers-subs/3114852-15-subwoofer-build.html)
felix94 01-08-2020 06:35 AM
15" subwoofer build
5 Attachment(s)
I am planning to build a pair of sealed subs using the new sql-15 driver.
With the help of a friend I was able to draw up a box.
These boxes will be CNCed some day in january and before that I thought id post and ask if anyone could see problems with the design.
Mainly if the bracing is adequate or not. As you can see bracing has been designed for a easy build process.
smcmillan2 01-08-2020 07:02 AM
I would add L-shaped bracing center-to-sides from the top and bottom as well.
A9X-308 01-08-2020 10:53 AM
I'd add a plane between baffle and rear and one between the sides vertically to tie all the panels together.
felix94 01-09-2020 04:16 AM
Thanks for the replies guys,
would it be possible to use a couple dowels to do the additional reinforcing?
Are they hard to work with?
GeorgeHolland 01-14-2020 10:16 PM
I used the concepts outlined in the NCM Cabinet Handbook.
A bit more bracing than most but rock solid.
https://www.avsforum.com/forum/155-d...s-r-15a-s.html
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
