DIY Subwoofer considerations - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31 of 41 Old 01-14-2020, 11:25 AM - Thread Starter
5js
5js's Avatar
Originally Posted by Augerhandle View Post
Were your other speakers disconnected?
no. All speaker were physically connected to the AVR.
REC: Onkyo TX-NR609, HDR TV: Vizio M658-G1
L/R: Polk RT15i , C: Polk 245i , SL/SR: Polk Rt15i , SUB: Polk PSW-250
5js is offline
post #32 of 41 Old 01-14-2020, 11:40 AM
Augerhandle's Avatar
Quoted: 1387 Post(s)
Liked: 1349
Originally Posted by 5js View Post
changing the subs polarity from 0 to 180 will invert the phase, correct? ...
Originally Posted by desertdome View Post
That is not correct. Here is one fairly simple explanation: Polarity? Phase? What is the difference?...
From your link:
polarity and phase are actually the same thing. Stay with me for the next few practical sections, and then I'll expand on the math.
when we reverse the polarity of a complex waveform, the phase of every single frequency component is changed by 180°.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #33 of 41 Old 01-14-2020, 11:51 AM
Liked: 1349
Okay, thanks for confirming.
post #34 of 41 Old 01-14-2020, 11:53 AM - Thread Starter
5js
5js's Avatar
for my own education, how does this affect anything?
5js is offline
post #35 of 41 Old 01-14-2020, 12:14 PM
Liked: 1349
As I stated earlier, those sharp downward dips in the response look (to me) like destructive interference due to phase differences with your other speakers. If the phase differences are closer to 180° (say, 135°-225°) switching polarity should help. If the phase differences are closer to 0° (let's say, 315°-45°), switching polarity should make it worse. Either way, fine tuning the phase using delay might be necessary.
post #36 of 41 Old 01-14-2020, 12:22 PM - Thread Starter
5js
5js's Avatar
While the other speakers were "connected" each sweep was output individually to each speaker. I did a sweep with signal ONLY coming from the left speaker, then another sweep with signal ONLY coming from the right speaker, then a sweep with signal ONLY coming from the Sub.
Anyway - the sub sweeps were only done to help identify the preferred location for a new sub. I am not planning to tweaking the setup of this sub as I am looking for a sub that is more suitable for my setup as the current sub doesn't work well for the LFE in movies.
What I am looking for is a recommendation for a sub and currently looking at a couple of VBSS's, and IB install, or a sub based on the Ultimax 18 (sealed 4 cu ft box or a ported design like a mini or micro marty).
5js is offline
post #37 of 41 Old 01-14-2020, 12:29 PM
Liked: 1349
While the other speakers were "connected" each sweep was output individually to each speaker. I did a sweep with signal ONLY coming from the left speaker, then another sweep with signal ONLY coming from the right speaker, then a sweep with signal ONLY coming from the Sub...
Thanks for clearing that up. I must have missed the sweeps from the L and R speakers only. If that is the case, then the dips are definitely nulls from placement locations. Just choose the location with the best looking graph, and EQ from there.
post #38 of 41 Old 01-14-2020, 01:12 PM
desertdome's Avatar
Quoted: 1545 Post(s)
Liked: 1847
. . .polarity and phase are actually the same thing. Stay with me for the next few practical sections, and then I'll expand on the math.
That is only true if you time shift the signal back to overlay over the original waveform - which defeats the concept of phase. The graphs in the article Phase or Polarity? illustrate the difference between polarity and phase.
Ponderosa Theater
High Impact AV
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
desertdome is offline
post #39 of 41 Old 01-14-2020, 04:30 PM
Quoted: 3063 Post(s)
Liked: 13057
Agreed, except I strongly suspect he is running the sweeps with all speakers connected.
Whether they are connected or not doesn't matter. It only matters if the sweeps were crossing from the sub to the mains. The sweeps he posted all appear to be sub only, so there is no crossover and no phase interaction.
I don't think he posted any of L and R. The only ones I see are sub only.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #40 of 41 Old 01-15-2020, 04:58 AM - Thread Starter
5js
5js's Avatar
This shows the L, R, and Sub. All measurements taken individually - so no crossover or phase interaction
Name:	SPL LRSub.jpg
5js is offline
post #41 of 41 Old 01-15-2020, 08:43 AM
JohnDean's Avatar
Quoted: 566 Post(s)
Liked: 262
FWIW, the only reason I suggested the sealed Ultimax is because of size in your room. If you're ok having a minifridge somewhere in the room, then Full or Mini marty is going to outperform the sealed.
You could EQ the sealed sub and beat the performance you currently have by a mile, or build a ported design and beat it by 2 miles(At the cost of a larger cabinet.)
Heide264 likes this.
JohnDean is offline
