DIY Subwoofer considerations - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 41 Old 01-08-2020, 11:20 AM - Thread Starter
5js
5js's Avatar
I have a home theater with the specific components listed below in my signature. The speakers are okay, but the sub lacks a lot, especially for home theater use. I use the system at 50% HT / 50% Music. Note: pics taken from the MLP.
I would like to build a diy sub, just undecided on what I want to build. Couples of options that I am considering are a pair of VBSS’s placed on their side under the L & R speakers (I would place the L&R RT15i’s on top of the VBSS's). The other option is doing an IB build using a single FI IB318 (with an option to install a second when I can afford). The IB would be installed in the corner cabinets on the right in the 2nd pic below (this would vent to the basement below). With either option I plan on getting a Behringer NX3000D (w/DSP).
I have attached a sketch of the house layout below as I’m not sure how I should calculate the volume. If I just use the “living room” area, it would be ~1928cu ft (18’ 9” x 13’ 5”, x 7’8”). Also not sure how much sound I need from the sub. Normally I have the Onkyo set about -20dB, max may be around -10dB. I’m not sure I measured correctly, but using a phone app I measure a 70-75dB at the MLP when set at -20dB or 85-90dB when set at -10dB.
I would like to keep this around $600 (inc. amp) as I am hoping to replace the Receiver, and maybe the other speakers in the near future. What should I consider in making a decision? Are there other recommended options? Are there preliminary measurements I can take to assist with the decision? (note I do have, but have not used, REW and a calibrated UMIK-1. The PC to the left under the TV is integrated into the system).
ID:	2666402   Click image for larger version
ID:	2666404   Click image for larger version
REC: Onkyo TX-NR609, HDR TV: Vizio M658-G1
L/R: Polk RT15i , C: Polk 245i , SL/SR: Polk Rt15i , SUB: Polk PSW-250
5js is offline
post #2 of 41 Old 01-08-2020, 01:53 PM
JohnDean's Avatar
Quoted: 566 Post(s)
Liked: 262
The best thing to do would be to put your sub in your MLP and then measure around the room to find the best response and put the new sub there. Given the layout, I can't see you putting 2 VBSS under your L&R. I also wouldn't waste my time with 1 IB sub. Your room volume would be calculated using the LR, Kitchen and hallway. Basically all open space(s)
Could you build a sub into the space under the shelf, where you marked for IB?(in place of the 2 lower doors)
How about in front of that air freshener?
Are you going to remove the Polk when you get new subs?
How big of a cabinet can you build/have? That would help with a sub recommendation. $250sub, $300amp and materials, would be right at your budget.
JohnDean is online now
post #3 of 41 Old 01-08-2020, 01:57 PM
Quoted: 280 Post(s)
Liked: 128
wookiegr is online now
post #4 of 41 Old 01-08-2020, 02:23 PM
Quoted: 267 Post(s)
Liked: 335
I don't know if you would be interested in moving your couch off the wall about 10-12 inches... But you could always grab 4 or 8 of the $30 JBL subs and build a few boxes to put behind the couch. That would probably give you the most spl for the money I would think, especially with how open you space is. Say $140-280 for the subs after tax, then grab an iNuke 3000 or 6000 depending on how many you go with, and you've got yourself a heck of an upgrade. Hard part is waiting for them to go on sale... No telling when they will again. Just a thought. Check out the JBL thread Here
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva XPA-7 Gen3 | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Three Stereo Integrity HS-24 mkIII's sealed | Sinbosen FP20000Q
YouTube Channel for builds and reviews Life Of Bliss YouTube
blister64 is offline
post #5 of 41 Old 01-09-2020, 05:21 AM - Thread Starter
5js
5js's Avatar
I can do that. What would I be looking for "best response"? The most boost?
Yes, I could build a sub into the space under the shelf. That's where I would build an IB if that's what I end up doing. If I were to do that I would install a manifold that would accept two IB's but would start with one till I could afford a second. I could put a sub in front of the outlet as well, but if I am not going with an IB and was going to have a box or boxes, my initial preference would be two boxes under the L & R speakers. But, I'm not hard over on that and could go with a single box located somewhere else. Why do you not recommend the two VBSS's or an IB?
Yes. That would be the plan. That sub only has a 8" driver and just just work for movies.
Well, I could build one as big as a refrigerator, but would prefer not to go that way.
5js is offline
post #6 of 41 Old 01-09-2020, 05:23 AM - Thread Starter
5js
5js's Avatar
Originally Posted by wookiegr View Post
Aren't those pics of your living room?
Yes. I just wasn't sure if I needed to include the dining room/kitchen and hallways in my calculations for volume as they are open to the sound.
5js is offline
post #7 of 41 Old 01-09-2020, 05:28 AM - Thread Starter
5js
5js's Avatar
Couch is currently off the wall 19", so that would be a possibility. I check the linked thread out. (behind the couch is a picture window with vertical blinds so I have my surrounds on the floor behind the couch firing upwards).
EDIT: Reading through a few pages of that post I read references to near field subwoofer. Is that type of sub more the feel of LFE (visceral feel) or is sound quality just as good? I ask because I would trade sound quality of the subwoofer over visceral feel. Reading more posts I think this is referred to in the posts as TR (?).
5js is offline
post #8 of 41 Old 01-09-2020, 11:32 AM
Quoted: 267 Post(s)
Liked: 335
I mean you are definitely going to get the visceral effect with them being closer, but I can't speak as much on the sound quality. I've experienced near field subs before, and I didn't think they sounded bad at all. There were 5 UM18s under the screen and 3 UM18s right behind the seating. That experience was a turning point for me... Showed me what was possible in a home theater! You could always put 4 up front (2 on either side of tv) and then 4 along the back of the couch in a line. Would make the box lower for you to set your surrounds on and give you both a regular sub placement as well as near field. Good thing about those subs is there are lots of options you can look at since they are so cheap. And since you already have the room back there, you're not looking to alter your space at all to fit them.
There are some real believers in those JBLs though, lots of people only use those and say they are extremely happy. I'll know soon enough, I have 16 waiting for me to build boxes for behind my couch
post #9 of 41 Old 01-09-2020, 01:24 PM
JohnDean's Avatar
Quoted: 566 Post(s)
Liked: 262
You'd be looking for the place with the flattest overall response. Then if you put your sub in that location the MLP would have the best response.
VBSS is more of a midbass driver. I'd recommend it if you were adding to existing subs that already produced 30hz and below. As far as IB, I just think you'd be underwhelmed with that much open space and only 2 drivers.
That's a clean looking room, It appears to me if you put them up front under your L&R they'd be sticking way out into the walkway infront of the TV.
post #10 of 41 Old 01-10-2020, 11:31 AM - Thread Starter
5js
5js's Avatar
Thanks for the response. I am hoping to spend some time this weekend learning REW and getting some general characteristics of my room (reflections, etc). I will be testing different sub locations as suggested.
The current Polk PSW-250 just isn't cutting it for music and especially HT. It's only 50W with an 8" woofer and rated frequency response is 40-160 Hz. Not sure how much SPL i'm getting, but I suspect not a lot. What frequency response could I expect with the VBSS? What other diy sub would you recommend for ~$300 that would meet my needs of clean audio for music and still supporting LFE for HT? I do want something with adequate SPL but don't need to blow my windows out.
Yea, that is the same concern I am having. I just don't think two VBSS would look balanced in that location. By the outlet / notional IB install area isn't ideal either (depending on the size) as that would be where the Christmas tree is in the pic below. The only other place I can think of for a larger box would be at the end of the couch where the current sub is. The only concern is that there is a picture window (w/vertical blinds) behind the couch.
So - my options are boxes under the L & R speakers - but that wouldn't look real clean. An IB integrated into the cabinets on the end wall. A large box where the Christmas Tree is or at the end of the couch (If I were to use these locations I would like disguise the sub in some fashion - but that would depend on what size box I need.) I also think I could fit a large but really skinny box behind the couch - but I'm not sure this would be good for music. I have even considered a thin tapped horn (something like a Tangband Tapped Horn)
I think my next step is to figure out if I can make an IB work, or if not an IB, what diy sub is recommend with my requirements and budget - and then decide what I can do to integrate the box into the living room.
5js is offline
post #11 of 41 Old 01-10-2020, 11:34 AM - Thread Starter
5js
5js's Avatar
If I see the JBL's on sale I'm going to grab some. If I don't end up using them on this system I can use them in my den in the basement.
5js is offline
post #12 of 41 Old 01-10-2020, 11:50 AM
JohnDean's Avatar
Quoted: 566 Post(s)
Liked: 262
Based on what you have now, I think a Ultimax 18 in a 4cuft sealed box would be impressive to you. A 22" cube is relatively small compared to ported options and you could add another one later if you wanted. I have no doubt a VBSS would be better than what you have, I just prefer the 15-30hz range for HT and the VBSS is rolling off by that point.
I've always wanted to try an IB, but the general idea is that it takes several more drivers to get the same performance you get with sealed or ported. I'd say in your room you'd want 4 IB drivers to start coming close to what you'd get from the other alignments.
jevchance likes this.
post #13 of 41 Old 01-10-2020, 12:04 PM - Thread Starter
5js
5js's Avatar
Thanks for the response. I had looked at the Ultimax 18 as well. Guess I should put that back on my list of options. I do like the thought that I could integrate an IB and not see it - but the 18" drivers are close to $300 each...
5js is offline
post #14 of 41 Old 01-10-2020, 01:00 PM
Quoted: 267 Post(s)
Liked: 335
Not a bad idea. Yea I figured even if I don't end up using these in my next space (looking to move in a year) they were cheap enough that I could throw them in other areas for a nice boost. I would look into the "magic cube", which just means you are able to wire the subs back to 4 ohms after hooking up multiples. The cube is like 2x2, 3x3, 4x4... and so on. So essentially 4, 9, 16 drivers can all be wired back to a 4 ohm load when done correctly. You can do it with 8 drivers as well if I remember correctly. Just do some research/planning before you buy them
post #15 of 41 Old 01-13-2020, 05:17 AM - Thread Starter
5js
5js's Avatar
First time using REW. Tried the sub in various location around the living room. By the left speaker seemed to show the flattest response, but I wanted to post all the graphs as I'm not positive what I'm looking for. The first graph shows the original sub location at the end of the couch in green, the sub by the L speaker in red, and by the R speaker in blue. I did notice that by the L speaker I have a bit of a boost at 38Hz and a sharp notch at 82Hz (whereas by the R speaker the notch is at 98Hz). I also included a waterfall with the sub at the L speaker. All of the waterfall show the ridge at 38Hz. Seems like my room like to resonate at that freq. Finally, I have an RTA graph of the noise floor before taking measurements. (not sure what the 90Hz line is but it was always there).
I understand the characteristics will most likely change if I had a sub that went a little lower (likely would excite other room modals), but if there anything I can glean from these tests? Are there other things I should look at to evaluate the sub and locations?
The original Sub location at end of couch and by each front speaker (positions 1, 5, 6)
Sub inside notional IB cabinet (position 2)
Sub just outside IB cabinet (position 3)
Sub by outlet near IB cabinet (position 4)
Sub by R speaker (position 5)
Sub by L speaker (position 6)
Sub by hallway outlet (position 7)
Sub in "coffee table" location (position 8)
Sub by L speaker waterfall (at position 6)
Noise floor RTA
Name:	Sub end of couch - original location.jpg
ID:	2669146   Click image for larger version
Name:	Sub inside IB cabinet.jpg
ID:	2669148   Click image for larger version
Name:	Sub just outside IB cabinet.jpg
ID:	2669150   Click image for larger version
Name:	Sub by  outlet near IB.jpg
ID:	2669152   Click image for larger version
Name:	Sub by R speaker.jpg
Name:	Sub by L speaker.jpg
ID:	2669156   Click image for larger version
Name:	Sub by hallway outlet.jpg
ID:	2669158   Click image for larger version
Name:	sub coffee table locaton.jpg
ID:	2669160   Click image for larger version
Name:	Sub overlay L R Orig.jpg
ID:	2669162   Click image for larger version
Name:	Sub Left no trap Waterfalls.jpg
Name:	Initial Noise Floor RTA 1-11-2020 daytime.jpg
5js is offline
post #16 of 41 Old 01-13-2020, 06:52 AM - Thread Starter
5js
5js's Avatar
To show sub locations tested
5js is offline
post #17 of 41 Old 01-13-2020, 08:57 AM
Augerhandle's Avatar
Quoted: 1392 Post(s)
Liked: 1353
Those sharp downward spikes shown in the 4th, 5th, 6th, and 7th graphs are likely phase issues. Re-run the sweeps with reversed polarity, and then you can tweak the response with delay settings.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #18 of 41 Old 01-13-2020, 09:20 AM - Thread Starter
5js
5js's Avatar
Originally Posted by Augerhandle View Post
Those sharp downward spikes shown in the 4th, 5th, 6th, and 7th graphs are likely phase issues. Re-run the sweeps with reversed phase, and then you can tweak the response with delay settings.
I will reverse phase and re-run to see what it looks like.
What do you mean by tweak the response with delay setting? What difference is the response would I look for? I'm going to replace the sub anyway, but I am interested in learning what changes affect what.
5js is offline
post #19 of 41 Old 01-13-2020, 09:28 AM
Liked: 1353
Sorry, I forgot you have a store bought sub. When you build a sub, you can use the software in the amp to adjust the delay, which in effect fine tunes the phase relationship between speakers. Reversing polarity adjusts phase by 180° only, which may or may not improve the response curve.
Last edited by Augerhandle; 01-14-2020 at 12:01 PM. Reason: Edited for clarity (phase vs polarity)
post #20 of 41 Old 01-13-2020, 09:31 AM - Thread Starter
5js
5js's Avatar
Sorry, I forgot you have a store bought sub. When you build a sub, you can use the software in the amp to adjust the delay, which in effect fine tunes the phase relationship between speakers. Reversing polarity reverses phase by 180° only, which may or may not improve the response curve.
Gotcha. Well, I do the phase test just to see how it affects the response. Once I decide what sub to build and get a separate amp I'm sure I'll learn a lot more about the software settings to eq the sub.
5js is offline
post #21 of 41 Old 01-13-2020, 01:09 PM - Thread Starter
5js
5js's Avatar
John - how does the Ultimax in a 4cuft sealed box compare with some of the ported builds using this driver (mini marty, etc.)?
5js is offline
post #22 of 41 Old 01-13-2020, 07:39 PM
joker927's Avatar
Quoted: 56 Post(s)
Liked: 35
I didn't read every post but saw your couch was 19" away from wall. At least one user in the VBSS design thread has a thin design that might be just what you need.
joker927 is offline
post #23 of 41 Old 01-14-2020, 07:56 AM
desertdome's Avatar
Quoted: 1546 Post(s)
Liked: 1847
. . . Reversing polarity reverses phase by 180° only
Phase is a time function and cannot be "reversed." Only polarity can be reversed.
Ponderosa Theater
High Impact AV
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
-StormAudio ISP 3D.32 Elite AVB; Cherry Megaschino amps; JTR Speakers Noesis 215RM's (5), S8's (10), & Captivator S2's (4); JTR NX7; Lumagen 4442; JRiver Media Center
desertdome is online now
post #24 of 41 Old 01-14-2020, 09:18 AM - Thread Starter
5js
5js's Avatar
changing the subs polarity from 0 to 180 will invert the phase, correct? (still have a LOT to learn - just want to make sure I'm an understanding things so far - phase is one area I haven't spent much time trying to understand - but plan to in the near future).
5js is offline
post #25 of 41 Old 01-14-2020, 09:42 AM
Quoted: 3073 Post(s)
Liked: 13092
If they are single sub-only sweeps, which they appear to be, then adjusting phase should make no difference since there is no phase interaction with other speakers or subs.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #26 of 41 Old 01-14-2020, 10:20 AM
desertdome's Avatar
Liked: 1847
That is not correct. Here is one fairly simple explanation: Polarity? Phase? What is the difference?
One technique to mic a snare drum is to have one mic above the drum head and one below the drum head. The polarity of the under head mic needs to be reversed relative to the top mic because the wave from the bottom of the drum head is opposite the top of the drum head. If the microphones are at different distances, the waveforms are being recorded at different times relative to each other. They are out of phase - one waveform is delayed vs the other. You align their phase by adding delay to the closer microphone. You can see that changing the polarity does nothing to help with the phase issue. Changing polarity is one tool that changes how waveforms interact with each.
Ponderosa Theater
High Impact AV
post #27 of 41 Old 01-14-2020, 10:56 AM
Liked: 1353
Poor wording on my part (to be fair, it is shown as a "Phase" switch on my amp). I stand corrected, and will edit my post. Thank you.
post #28 of 41 Old 01-14-2020, 11:05 AM
Liked: 1353
Agreed, except I strongly suspect he is running the sweeps with all speakers connected.
post #29 of 41 Old 01-14-2020, 11:12 AM - Thread Starter
5js
5js's Avatar
unsure what you mean by connected. There is only one sub and each sweep was done one speaker at a time.
5js is offline
post #30 of 41 Old 01-14-2020, 11:23 AM
Liked: 1353
Were your other speakers disconnected?
